Results 1 to 19 of 19
    Teen die Berg langs die See
    Thanked: 298
    Default My Venter trailer Bicycle Carrier solution
    I decided to build a Bike rack for my trailer, I built it to carry 3 bikes. Then a day later decided, there's space for 5, and the baby will have a bike soon some day and changed it again. It worked out at about R 350, bolts etc included. I had primer paint left for the extra pieces i added the second time round, I must go get white paint to finish it this weekend. I used 25x25x2mm Sq tubing, (4x1 meter pieces). And I used 40x40x2mm Angle iron (4x1 meter pieces). Its light enough for the lid to stay open (without the bikes) Used threaded rod to secure the front forks of the bikes, The loos front wheels i will just cable tie to the bikes frames. To take off the three bikes front wheels takes a minute, so there no real hassle. The back wheels will be secured with a big cable tie around the angle iron.
    Maybe the idea(although simple) can help or inspire someone that needs the same type of thing, and doesn't want to spend R 3500 to buy one. I tried using the least amount of steel for weight, so no frame or anything extra.
ID:	413085   Click image for larger version.
ID:	413086   Click image for larger version.
ID:	413087   Click image for larger version.
ID:	413088   Click image for larger version.
  2. The Following User Says Thank You to Bostokkelos For This Useful Post:
    Thanked: 298
    Default Re: My Venter trailer Bicycle Carrier solution
    Some more angles.
    The second time round I decided to lift the front mounting points of the two newly inserted tracks with 150 mm, so that the extra bikes handles will be higher and not touch the middle one.
ID:	413090   Click image for larger version.
    Jan 2015
    Harare
    Thanked: 48
    Looks good.
  5. The Following User Says Thank You to nhoro For This Useful Post:
    Dec 2012
    Secunda
    Thanked: 287
    Puik gedoen bou meer jy gaan goed geld maak
    JHB
    Thanked: 215
    Very nice. I need to practice my welding a bit before I can make something like that...
    Thanked: 298
    Im no welder....but I can grind!!lol thanks
    Thanked: 298
    A while back i changed the bicycle carrier so that one doesn't have to remove the front wheels. I added vertical sq tubing bars that can fold down,
Name:	New RR 2.jpg
ID:	453632   Click image for larger version.
    Jul 2013
    Thanked: 420
    Waar stoor jy die voorwiele van die fietse?
    Sorry sien nou eers die mod vir die wiele.
    Thanked: 298
    Dis juis die ding, ek haal dit nie meer af nie. ek sit die fiets net so op die sleepwa, slaan die support op in die middel en cable tie die twee wiele vas, en die frame van die fiets cable tie ek aan die reggop sq tubing pyp vas dis al. Ek sit n stukkie pool noodle aan die sq tubing bar vas om die fiets te beskerm.
  12. The Following User Says Thank You to Bostokkelos For This Useful Post:
  13. #10
    Thanked: 2887
    If you need back up transport that is the way to do it.
    Baie spiekeries
    Henk
    Follow us on Facebook
  14. The Following User Says Thank You to hbannink For This Useful Post:
  15. #11
    JHB
    Thanked: 23
    Finally tyd vir my om ook die te doen
    Het jy enige tekeninge of af meetings op die nuwe design wat ek dalk kan gebruik
    Watter dikte staal het jy gebruik 1.6mm of 2mm?
    Baie dankie
  16. #12
    Thanked: 298
    HI
    2.0 mm vir alle staal.
    Ek het ongelukkig geen tekeninge of iets nie,
  17. #13
    JHB
    Thanked: 23
    Finally gedoen. Dankie vir idee
    Wonder net as my angles nie te klein is
  18. #14
    JHB
    Thanked: 215
    I used some aluminum pieces I had on hand.
    Channels were salvaged from my neighbors jacuzzi cover...
  19. The Following User Says Thank You to Mambo For This Useful Post:
  20. #15
    Thanked: 598
    Ek is bly ek het die thread raak gelees, baie goeie idee en goed geexecute!
  21. #16
    Thanked: 298
    Quote Originally Posted by Heino13 View Post
    Dalk n bietjie kleinm maar dis niks. Trek elke wiel lekker styf vas met n sterk cable tie, sit pool noodle om die vertikale sq tubings wat jy ook vastrek met cable ties, en hy sal hou
  22. #17
    Thanked: 298
    Hier is n foto
  23. The Following User Says Thank You to Bostokkelos For This Useful Post:
  24. #18
    Montana Park
    Thanked: 169
    Hi Bostokkelos.
    Ek weet dit is nou al amper 'n jaar later, maar ek is nou in die situasie waar ek presies so 'n fietsrak op my waentjie gaan moet monteer.
    Ek hou baie van jou uitleg en wil net weet of jy enige probleme ondervind met die waentjie se deksel, waar die boute van die fietsrak deurgaan? Ek neem aan jy het die deksel met 'n "flatbar" aan die binnekant ge"sandwich", maar veroorsaak die vibrasies en beweging nie die gate om ovaal se word nie? Ook, het jy slegs die buitenste twee dwarslatte op die deksel vasgebout, of al 4?
    Life's a journey..................even longer by foot
    2018 Ford Everest 3.2 XLT
    2006 Mazda Drifter X 2500 Td D/C (Ossie) - Sold
    1993 Mercedes-Benz 190E 2.3 Sportline (VERY plat kar) - Sold
  25. #19
    Thanked: 298
    Hi, ek het al die dwars balke vasgebout. Flat bar aan die binnekant net in die middel van die deksel. Op die kop kante het ek groot dik washers gebruik met Riv nuts. Geen vibrasies of niks nie nee.
  26. The Following 2 Users Say Thank You to Bostokkelos For This Useful Post:
