Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 47
    Gaborone
    Thanked: 1162
    Default Cleaning your braai grid
    Do you clean your braai grid after each session?
    Do you clean your braai grid monthly?
    Do you use a wire brush?
    Do you use half an onion?
    Or do you clean nothing and just keep using that puppy again and again and again and again?
    Personally I have started cleaning mine in the shower, after each use!
    1997 Discovery 1 300tdi - Pussy Galore
    1996 Discovery 1 V8 - Mr Creosote
    De Kelders
    Thanked: 135
    Default Re: Cleaning your braai grid
    Over the flames to burn off the old fat. Then a brush with a wire brush. That is all.
    Andre Botha
    2006 Pajero 3.8 GLS LWB, Gomad bash plates. Monroe Adventure shocks.
  3. The Following 4 Users Say Thank You to Andre For This Useful Post:
    Keurboomstrand
    Thanked: 15
    Dishwashing liquid with boiling hot water for the stainless steel grid after each braai. Swambo threatened to also just "clean" the dishes over the fire.
    2007 Land Rover Freelander 2. Not my best - my only!
    2006 VW Jetta 5 2.0 Tdi
    Bush Lapa Vlooi - SOLD!
  5. The Following 3 Users Say Thank You to Pieter Hugo For This Useful Post:
    Feb 2015
    Noordhoek, Cape Town
    Thanked: 2457
    Quote Originally Posted by Pieter Hugo View Post
    Like this, I always braai on a clean grid. Always. I'm not a savage!
  7. The Following User Says Thank You to Chris Stoffel For This Useful Post:
  8. #5
    Feb 2012
    WC
    Thanked: 22
    Greetings,
    There is some opinion that a broken piece of bristle from a wire brush can cause serious problems if swallowed. Maybe not something one hears about, but nasty all the same.
  9. #6
    Thanked: 17104
    Quote Originally Posted by Andre View Post
    x 2
    Use brass
    Builders has some nice ones
    Jakes Louw
  10. #7
    Jan 2016
    Pinetown
    Thanked: 438
    Throw it on the flames. Thats about as clean as I need it to be.
    Si Vis Pacem Parabellum
    2012 Hilux 2x4 D/L
    A few basic mods.
  11. The Following User Says Thank You to Wandering_Soul For This Useful Post:
  12. #8
    Langebaan
    I put the normal steel one on the fire, wire brush and wipe with news paper before meat goes on.
    I also have a stainless steel one with the slide down handle, put that in the dishwasher
  13. The Following User Says Thank You to Mauritz Viljoen For This Useful Post:
  14. #9
    May 2021
    I'm in the class of braai devotees who think cleaning grids is only for interior decorators and people who call their wife "Sir". I also hate spending money on stuff I can do or make myself. More specifically, upwards of R800 for a shallow plastic box.
    Recently, however, someone shamed me by drawing attention to my very grungy braai grid. So here's my solution: build a shallow box from cheap hardboard with wood spacers wide enough to admit your grid, keeping one end open to insert the grid (duh).
    Place the grid in a waterproof garbage bag, insert it carefully into your homemade cleaning box, standing it upright, then pour in the Sunlight/water mixture (or whatever) and leave it for a day or two for the gunge to (theoretically, anyway) float away. Spend the R800 you saved on interesting fermented beverages.
  15. The Following 3 Users Say Thank You to Pragmatist For This Useful Post:
  16. #10
    Jun 2019
    Thanked: 52
    1. 1st pass below immediately after braaing.
    2. Then a quick spray down with water, and clean with sunlight if necessary.
    3. Next braai, put on hot braai and wire brush clean to get a nice sear on the steak or chops.
  17. The Following 12 Users Say Thank You to Absie For This Useful Post:
  18. #11
    Sep 2016
    Thanked: 5213
    Interesting product https://gridbuddy.co.za
  19. The Following User Says Thank You to Roberto Betta For This Useful Post:
  20. #12
    Dec 2018
    Thanked: 1528
    R1k . No thanks.
    I saw a similar product at plastic warehouse for R350 and even then I thought it's a lot for a piece of plastic.
    Quote Originally Posted by Roberto Betta View Post
  21. #13
    Cape Town Southern Suburbs
    Thanked: 1509
    R1200 for the 700cm and R1500 for the 1m one.
    I personally have never seen anyone that dedicated to a clean grid other than scraping the crud off the top.
    And even if you do want it sparkling clean no wash box with some degreaser and a few integrated brushes will get it clean. You need to put your back into it with metal scrapers, screwdrivers and wire brushes, to get that welded on carbonized stuff off.
  22. #14
    Thanked: 2929
    Chuck the grid on the fire
    Steel brush just before the meat goes on.
    Anything more than that, you may as well wear gloves.
  23. The Following 4 Users Say Thank You to MariusFourie For This Useful Post:
  24. #15
    Thanked: 831
    Or put your meat in a pan on the stove.
    Dad built me a stainless braai with a mild steel grid.
    After every braai I do not clean it. The fat protects the mild steel against rust and the braai is 7 years old.
    My ryding: 'n Ding met 4 rubber sirkels en n enjin wat nou en dan aangedryf word met al 4 sirkels
  25. The Following 3 Users Say Thank You to IcePick88 For This Useful Post:
  26. #16
    Wartburg
    Thanked: 2518
    And wear a mask and use hand sanitiser before and after touching the meat....
    Mike Lauterbach
  27. The Following User Says Thank You to mikeml For This Useful Post:
  28. #17
    Thanked: 2544
    And after ths you need to buy the Gridbuddy cleaner @ R999 to clean the Gridbuddy after every grid wash!
    A wise man understands, an intelligent man knows, but a fool pretends to know.
    Luka Geertsema
  29. The Following User Says Thank You to Luka For This Useful Post:
  30. #18
    Feb 2020
    Melkbosstrand
    Thanked: 44
    Interesting no one has mentioned news paper. I expect it is mostly because no one reads them any-more, or use them to light a fire.
    When I was a laatije, if you couldn't light the fire with newspaper you were a light weight... Same newspaper was used to clean the grid.
    Sommer so.
    1995 Defender 110 300tdi (nick-named Alfie)
    1978 Mercedes Benz 450SL
    2000 Volvo V40 T4 (on the market - What offers?)
  31. The Following 6 Users Say Thank You to CraigWatt For This Useful Post:
  32. #19
    Wartburg
    Thanked: 2518
    Quote Originally Posted by CraigWatt View Post
    Sommer so.
    Post #8. I also only use newspaper after burning the grid on the fire. But I'm just about out of newspaper, so will probably have to get a bronze or stainless wire brush. Because of low newspaper stocks, I had to resort to firelighters for starting the fireplace fire....had two already this autumn
    Mike Lauterbach
  33. The Following User Says Thank You to mikeml For This Useful Post:
  34. #20
    Feb 2020
    Melkbosstrand
    Thanked: 44
    Sorry, I missed that.
    Funny though, fire-lighters these days are less expensive than most newspapers except the free community ones which are stuffed with adds on shiny paper which aren't good for anything..
    Weird world.
  35. The Following 2 Users Say Thank You to CraigWatt For This Useful Post:
