- Sick Disco1 V8
Sick Disco1 V8
Guys I need some advise please..
The disco is 3.9 Efi,she starts fine and idles with a bit of a shake,on revving up she starts going crazy with some backfire through the intake
I have changed the following
New coil
New amplifier
New distributor cap and rotor and leads
New plugs NGK BP6es
Airflow meter replaced and checked with multimeter
Fuel pressure 2.3 to 2.5 bar at idle at the rail
New fuel filter
Disrtibutor has no play
Firing order is right
Fuel temp sensor and water temp sensor checked with multimeter,all ok
Alternator checked
Could it be timing? If I get my nr 1 at TDC my marks on my crank pulley is at the bottom! That doesnt seem right
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
