Pitching of a TTT - gas strut supports?
Results 1 to 16 of 16
    Stellenryk, Bellville
    Thanked: 290
    Default Pitching of a TTT - gas strut supports?
    Being short, I always find it a challenge to open the TTT taking care not to bend the aluminium frame in the process. I have subsequently made myself a support by using a telescopic aluminium pole, as used for swimming pool brushes, attaching a piece af alu angle at the front. This is then positioned in the middle of the tent roof, with one of the horizontal alu poles inside the alu angle, and the tent is then pushed open.
    However I recently saw an advert on Gumtree where it appears that the guy has fitted a gas strut on either side from the tent base to the middle aluminium upright pole of the frame. From the picture it was clear that this was to push the tent open, and I suppose when closing, one would need some tie down to hold it closed. I added a photo now, the frame of this tent looks identical to the Tentco TTT except that the Tentco frame is on the outside, which should make it better fitting a gas strut.
    Did anyone try this and can confirm that it is actually working? Don't want to go through the trouble in fitting them and they do not help at all.
    Last edited by Blackie; 2016/07/13 at 11:56 AM. Reason: Added a photo of the gas strut
    Dual battery system
    57 mm freeflow system
    General Grabber AT3's
    Jun 2012
    Klerksdorp
    Thanked: 64
    Default Re: Pitching of a TTT - gas strut supports?
    Comes standard in Echo tents. Position is a bit different though. Don't think I will be able to lift it without them
    2009 Toyota Fortuner 3.0 d-4d 4x2
    Custom off-road trailer with Echo TTT
    Thanked: 290
    Thanks for the response.
    Yes, the Tentco frame is a bit different than the Echo, the bottom room of the Tentco does not have a frame attached to the main tent frame.
    Think I might just give it a try seeing those gas struts are not that expensive and can be re-used if not working. Will try to practice a type of clamp that goes around the aluminium pole and then attach the strut to that, thereby not weakening the pole by drilling a hole through it.
    Dual battery system
    Jun 2012
    Klerksdorp
    Thanked: 64
    Give it a try, can only help. Just take it slow when testing. Long time ago one of the struts twisted and unhooks, almost tearing the tent. they can be quite tough to push in
    Jun 2012
    Klerksdorp
    Thanked: 64
    It also bent the frame a bit, but was fixable
    Thanked: 290
    Tks for the advice. Yes, my intention is to buy the ones being used for a canopy as they are not that much pressurised and should not be too hard to push in again when closing the tent.
    Dual battery system
  7. The Following User Says Thank You to Blackie For This Useful Post:
    Thanked: 175
    old thread but did you manage to do this mod, im thing of a similar idea, I'm 5'5
    Hilux 2700i s/c 4X4 with a few extras ...............
    Thanked: 290
    Quote Originally Posted by ismail View Post
    Not yet, I have been using an aluminium extension pole with a T at the top to push the tent open until now..
    Dual battery system
  10. The Following User Says Thank You to Blackie For This Useful Post:
    Dec 2007
    Thanked: 117
    I have a HUGE TTT on top of my Metalian Maxi.
    It was always a struggle to open the tent.
    Took it to Bushwakka in Worcester who did an excellent job in fitting gas struts.
    I still use a pole to assist with the lifting but MUCH easier now.
    I would recommend it.
    Metalian Maxi
    Aug 2010
    Thanked: 38
    Quote Originally Posted by 4x4 wannabie View Post
    What tent do you have on your Maxi?
    Pete
    Living the dream baby, living the dream......
    2011 Jeep Wrangler Unlimited Sahara 3.8
    1999 Jeep Cherokee Country 4.0 - SOLD
  13. #11
    Thanked: 175
    good idea that, could you post a pic of the mounting, doesnt look to bad to DIY.
  14. #12
    Dec 2007
    Thanked: 117
    Quote Originally Posted by Jeep dream View Post
    It was custom made by Christies Sports - to fit a king size mattress on top and it has a larger "tent area" at the bottom.
    Will do , but will only be able to take pics again when camping.
    Metalian Maxi
  15. #13
    Aug 2010
    Thanked: 38
    [QUOTE=4x4 wannabie;4106135]It was custom made by Christies Sports - to fit a king size mattress on top and it has a larger "tent area" at the bottom.
    Thanks. Iíve got an Ultimate Overland tent on mine which looks similar in size to yours.
    Pete
  16. The Following User Says Thank You to Jeep dream For This Useful Post:
  17. #14
    Thanked: 175
    Sure thanks hopefully after next weekend ; )
  18. #15
    Thanked: 2159
    I would think twice before doing this, I have replaced enough aluminum poles due to breakage at the point of drilling holes. You drill a 6mm hole to mount the strut but in the process you take away a lot of the structural strength in the direction of most stress resulting in cracks and eventually breakage. If the frame is steel it should be ok
    The idea of the pole with a piece of angle works best in my book. My assistant opens the tents by means of a broom that he wedges in under the first frame and then gentle pressure on the oposite side to slowly inflate the tent. If you have a fly sheet above the tent you can make your life easier by attaching a set of webbing straps to the middle pole on either side and using this to pull up the tent
    Henk
    Follow us on Facebook
  19. The Following User Says Thank You to hbannink For This Useful Post:
  20. #16
    Thanked: 449
    I did a conversion to my tent on my Off Road Trailer which worked well.
    I agree with the comment above and took this into account when I did the mod.
    By ensuring the supporting bracket for the strut is at least 50 mm long and shaped to fit half way around the pole where it attaches to the tent pole, the load is spread over that area and thus there is minimal bending in that area.
    I sold it 2 years back and the new owner still has joy.
    Platkar 1: BMW 118 (SWAMBO)
  21. The Following User Says Thank You to Mitsu Fan For This Useful Post:
