www.tacqm.co.za Water Security
www.tacticalquartermaster.co.za Water Security
I try avoid selling our products by use of fear, uncertainty, however in this case it is simply a fact.
Below are pics of water filter that are used with the our Water Filtration systems, sent to me by a customer (and friend)
The pics show clearly the amount of debris, dirt and who knows what else is in our water!
(The location is one of the Northern Suburbs of JHB and is a home for two adults and a child.)
It is a fact that our water infrastructure is old and decaying.
The water quality might be acceptable when it leaves the water utility company, the pipes that it travels to get to our taps are not.
Above:
The White filter on the left is an unused Filter.
The center filter is the same filter about 2-3 months old.
The right filter is the ceramic filter. It is white when new. This is the final stage filter that does most of the fine work to get the water clean
The left is the ceramic filter, the right is a new unused ceramic filter.
Notice the elongated white mark on the used filter.
This is the result of using a fine grit sand paper to remove the discolouration caused by pollutants, to restore the filter and extend its life span.
The ceramic body is about 10mm thick, so it will last a long time
We sell a range of water filters and as important, spare cartridges.
Secure your Water Security for your family.
For more info, prices & specs, please see:
Water Security
www.tacticalquartermaster.co.za we are ONLINE, deliver Nation-Wide, Door2Door OR you are welcome to Click’nCollect.
Feel free to contact us at [email protected] or [email protected]
Camo
- You may post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
