Results 1 to 20 of 23
Thread: Amarok battery
    Thanked: 19
    Default Amarok battery
    Looks like my Amarok's battery is dying. After only 2 years and regular charging with my C-Tek. I'm not impressed. Phoned the dealers - price for a new one is about R2500. All he can tell me is that it is a 72Ah.
    I can't get to the manual now and I'm not finding the correct info online (some sites mention a 95Ah).
    Can someone please help me with the correct model number to ask for when getting alternative quotes?
    Thanks!
    2014 Amarok DC 4Motion Auto
    Conqueror Conquest
    Thanked: 5662
    Default Re: Amarok battery
    Quote Originally Posted by PierreJJ View Post
    Thanks!
    Hi Pierre,
    Where did you get the quote from?
    I usually use Cymot. They have a list with all the cars (model nr etc.) and the battery to fit. Sorted Swambo's polo like that.
    Remember VW fuse box is directly connected to the battery. Bit more work than just replacing but I assume you know that.
    Gert Grobler
    VW Touareg V6 Tdi Escape; Land Cruiser 105
    Bush Lapa Boskriek 816
    Thanked: 3030
    The amarok has an intelligent charging system built into the vehicle.
    The charging cycles are custom tailored to the required factory battery.
    Go to the dealer, give them your VIN and get a genuine battery. It will last you a long time and actually workout cheaper in the long run. My touareg battery I replaced lasted 8 years (based on the date stamp).
    JHB
    Thanked: 137
    Hi Pierre
    I replaced my battery just before a trip to the Kgalagadi as a precaution. The original battery is well over 4 years old, but was showing signs of failure on cold mornings, hence the reason to replace.
    The standard battery, in Varta's codes, a B13 hold down, battery an E44. This is a 77ah unit, with a footplate for mounting. I got quoted R 1872 for this unit.
    I went to Deltec, to see what battery they had that would fit the standard mounting points.
    The unit I decided on is an H3, which is a 100ah battery as shown in the picture attached, cost was R2400.
    The standard battery is about 80mm shorter than this battery, and VW has a spacer piece to make up for the size difference.
    The H3 fits in the standard battery holder, mounted on the footplate, with no modifications needed.
    See below link to the Varta website.
    http://www.varta-automotive.com/en-g...ilver-dynamic/
    It is a darn mission to get the battery out though, you have to remove 3 bolts holding the ECU, and shift it out of the way to access the footplate hold down bolt.
    2012 Bi Turbo 4Motion, on Bilsteins with a 50mm suspension lift and 20mm body lift. 76mm pipe and software.
    Thanked: 3030
    JHB
    Thanked: 137
    If you do go bigger or different, get someone to code it in for you via VCDS. It will lengthen the battery life.
    Oh damn Marius, just ANOTHER reason to fork out the R5.5k for a darn cable...
    Thanked: 3030
    Quote Originally Posted by JohnBoy View Post
    If you have a modern vw/audi, that cable is worth it's weight in gold. Mine has paid for itself many times over.
    Thanked: 19
    Nys & Marius - the quote I got was from Autohaus and they did ask for the VIN number.
    In my experience the OEM batteries always last longer, that's why I don't understand that my original battery only lasted 2 years.
    JohnBoy - I really like the idea of a 100Ah Varta at the same price as the 77Ah OEM but I don't know of any Varta agents in Windhoek
    Conqueror Conquest
    Thanked: 19
    Interesting... phoned Zimmermann now... price for the battery is the same (also 72Ah) BUT... they have an 'economical parts' option - also genuine VW part and same quality (salesman talk) at R1330
    Conqueror Conquest
    Thanked: 5662
    Go speak to Oom Zimmerman himself or ask for Gert (no, not me).
    Sure they will be able to tell you the right story
    Gert Grobler
    Thanked: 19
    Thanks. I'm a firm believer (and skeptic) when it comes to 'too good to be true', but at that price, even if it only lasts 12 months, it's still a bargain...
    Conqueror Conquest
    Thanked: 3030
    Thanked: 19
    OK, long story short, the battery is also covered under the vehicle's 3 year warranty and Autohaus will replace it as such.
    Thanks for all the replies and good advice!
    Conqueror Conquest
    Thanked: 5662
    That is good to hear
    Gert Grobler
    Melkbosstrand
    Thanked: 268
    Sorry to resurrect, but I'm interested in the above statement...
    Is this the standard VW warranty?
    My battery is dying, so need a replacement soon
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
    Dec 2013
    Reebok, Mossel Bay
    Thanked: 90
    Pierre,
    Just curious; want to understand.
    Your Amarok is 2014 (about 4 yrs), but battery is 2 yrs old; so this must be 2nd battery failure??
    My VW's normally run 6 - 8 yrs on a battery.
    My Amarok is also 2014, and no problems yet.
    Sure there is not a tracking unit that starts sucking up the amps while standing??
    My son had such a problem on Touran.
    Herman Meyer.
    2014 Amarok DC 4Motion Auto ,
    2015-02-03: Bush Lapa Miskewer 394.
    2012 VW Polo Sedan 1.6 A/T.
    Dec 2013
    Reebok, Mossel Bay
    Thanked: 90
    Sorry, did not notice these are old posts.
    Herman Meyer.
    Melkbosstrand
    Thanked: 268
    Quote Originally Posted by hermanm10 View Post
    Pierre,
    I've only just fitted a tracking unit, and it's supposed to have it's own supply, so I guess mines just a failure.
    Going to the agents tomorrow morning to get it checked out...
    My fault for resurrecting...
    Melkbosstrand
    Thanked: 268
    Quote Originally Posted by BobMabena View Post
    To answer my own question, yes, standard VW warranty... they will replace the battery, after running a bucket load of tests...
    Waiting on the outcome of my tests.
    Jul 2013
    Thanked: 420
    Mine installed is a 658 C 100ah.
    Why 100ah only the previous owner will know, but I`m not complaining.
