What Rocksliders?
Results 1 to 20 of 86
    Harrismith
    Default What Rocksliders?
    I'm looking to get some rocksliders for my Amarok. Would like to here from the members with experience of what to look for. Currently looking at Stofpad vs Seikel. Don't now of any other?
    Vanderbijlpark
    Thanked: 760
    Default Re: What Rocksliders?
    I have Seikel rock sliders, and they works brilliant.
    If I were to buy another Amarok, rock sliders will be the first accessory I will fit.
  3. The Following User Says Thank You to clubbie For This Useful Post:
    Thanked: 97
    I had non Seikel rock sliders on my previous Amarok and after they damaged the body work of my Amarok I removed them and fitted the Seikel sliders.
    They give you a much better ramp over angle and they don't damage the body when you use them.
    Seikel is also the only VW approved slider available.
    4x4 Groete
    Albert de Villiers
    Amarok BiTDi 4Motion
    Youtube Channel
    www.andre4x4.co.za
  5. The Following User Says Thank You to Trebla For This Useful Post:
    Oct 2008
    Ridgeworth, Bellville
    Trebla, waneer kom die plaaslik vervaardigde ekwiwalent van die Seikel sliders. Die Seikel sliders in vergelyking met ander fabrikate is omtrent dubbel die prys. Ek is ook opsoek na sliders maar die R12 000 (installasie uitgesluit) wat ek kwoteer is, is darem net te veel.
    _________
    2011 VW Amarok D/C 4Motion BITDI
    2000 Isuzu 280 4x4 DT D/C [SOLD]
  7. The Following User Says Thank You to juanv For This Useful Post:
  8. #5
    Jun 2007
    Somewhere
    Thanked: 112
    Quote Originally Posted by juanv View Post
    Kyk na Maniac s'n ook.
  9. #6
    Jan 2016
    Boksburg
    Thanked: 133
    these are ONCA Rock sliders on mine. You won't bend these...
  10. The Following User Says Thank You to Jason Willemse For This Useful Post:
  11. #7
    Thanked: 97
    Ek volg elke week op en sal julle laat weet sodra ek terugvoer kry dat die sliders beskikbaar is.
    4x4 Groete
    Albert de Villiers
    Youtube Channel
    www.andre4x4.co.za
  12. #8
    Thanked: 97
    Quote Originally Posted by Jason Willemse View Post
    These sliders caused the damage on my previous Amarok...
    4x4 Groete
    Albert de Villiers
    Youtube Channel
    www.andre4x4.co.za
  13. #9
    Jan 2016
    Boksburg
    Thanked: 133
    Quote Originally Posted by Trebla View Post
    This style, or the ONCA's specifically? It really would surprise me, as I did my homework beforehand, went and checked their manufacture, and found their design and strength to be the best available. They are heavy though. I've even hung up my rom on them... Not even a dent.
  14. #10
    Thanked: 97
    That exact style. Whenever the full weight of the vehicle was on them they moved slightly towards the body and then the support piece touched the body.
    4x4 Groete
    Albert de Villiers
    Youtube Channel
    www.andre4x4.co.za
  15. #11
    Jan 2016
    Boksburg
    Thanked: 133
    Ah... This I know, which is why I went they way I did. There are cheap knock-offs that aren't built to the correct spec. Even had these same pics in discussion with them. The real ONCA rocksliders are built incredibly strong. Total overkill.
  16. The Following User Says Thank You to Jason Willemse For This Useful Post:
  17. #12
    Apr 2011
    Sandton
    Thanked: 210
    Cheap knock-offs won't be ONCA and should not be sold as ONCA?
    '06 TJ Wranger | 4.0L Auto| 4.5" Lift | 35" Copper STT | 15" MT Classic II Black | 4.88 Gears
  18. The Following User Says Thank You to GasHog For This Useful Post:
  19. #13
    Thanked: 97
    Well these were made by ONCA so it might be that the first batch had a problem because I bought the set from them...
    4x4 Groete
    Albert de Villiers
    Youtube Channel
    www.andre4x4.co.za
  20. #14
    Harrismith
    What is the budget price of the ONCA. They look close to the Seikel.
    Trebla hoe lank nog vir plaaslike vervaardiging
  21. #15
    Jan 2016
    Boksburg
    Thanked: 133
    Quote Originally Posted by GasHog View Post
    Ok? Not sure of your position here.
  22. #16
    Thanked: 97
    Quote Originally Posted by Lewies!! View Post
    Sal weer opvolg as ek terug is in SA.
    Daar is geen slider wat soos die Seikel een is nie. Hier is n foto van die mounting
    4x4 Groete
    Albert de Villiers
    Youtube Channel
    www.andre4x4.co.za
  23. #17
    Jan 2016
    Boksburg
    Thanked: 133
    Pretty close... Around the 10k mark if I remember correctly.
  24. #18
    Apr 2011
    Sandton
    Thanked: 210
    Just saying that knock-offs of any kind should not not be sold or marketed as name brands.
  25. #19
    Thanked: 97
    Yes sure, but if you buy it direct from the manufacturer then it should not be a knock-off at all
    4x4 Groete
    Albert de Villiers
    Youtube Channel
    www.andre4x4.co.za
  26. The Following User Says Thank You to Trebla For This Useful Post:
  27. #20
    Thanked: 1184
    Hi Lewis.
    My sliders retail for R7900 and bolt directly to the chassis, not to the body. They also have high lift jack points in them, and are wide enough to protect the vehicle from gravel rash on the rear fenders.
    Contact me if you require more informations. 083 399 2046
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
  28. The Following User Says Thank You to Uys For This Useful Post:
