Trailer spares/parts/accessories trade sale thread - Page 2
Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 21 to 40 of 107
  1. #21
    Default Re: Trailer spares/parts/accessories trade sale thread
    Quote Originally Posted by Pietervdw View Post
    Good Morning
    I am looking for 13" trailer rims 100 pcd for venter trailer.
    Back off set not more than 75mm.
    Willing to arrange collection in Gauteng area.
    Thanx
    Hi Pieter, I've got 3 x 13" 100 pcd rims and tyres I took off my caravan if you're interested.
    I'm in Edenvale. Drop me a pm to arrange for collection.
    Cheers,
    Jacques
  2. #22
    Lephalale
    Thanked: 9
    Quote Originally Posted by Schicks View Post
    Cheers,
    Jacques
    Thanx Jacques
    Is it the deep dish rims.
    As the swallow dish will rub on the body.
    Thnx
  3. #23
    Thanx Jacques
    Thnx
    They're the standard shallow dish type so probably won't work for you
  4. #24
    Lephalale
    Thanked: 9
    Morning
    Thank you for the reply.
    Shallow dish will not work as I don't want o make use of spacers or extend axel.
  5. #25
    Trailer/caravan rubberide axle for sale. AL-KO 1500kg load capacity. 2500kg brake capacity. R3000 or to swop for rooftop tent or 40l fridge
ID:	429272Click image for larger version.
  6. #26
    Sep 2010
    Goeie dag. Conqueror Supra 1 en 2. Ek is op soek na 'n volledige stel tent "rods" Ek het die boswa 2 dehans gekoop en die tent "rods" ontbreek . As jy dalk weet of kan verwys sal ek dit waardeer. Het met conquerror reeds geskakel vanaf 9 des 2016. diens is baie power. het nog niks gekry van hulle. baie dankie.
  7. #27
    Jan 2017
    Brackenfell
    Thanked: 17
    Hi Gents
    I want to beef up my trailer but don't have a lot of bucks, I want to raise it a bit from the current height and put 195/R14 tyres and rims on apart from its current 155/80/13 rims and tyres it has on now.
    It came out with a Burquip Axle with load rating capacity of 900Kg, so its not tooooo shabby.. however, I can put spacers under my suspension to lift it slightly, but I want broader tyres for better off-road capability over sand etc if needed.
    Any suggestions or advise? Burquip says I must buy a longer axle if I want to put 14 inch rims and tyres on over the 13 inch rims and tyres... now I am not sure, but is this not just a ploy to sell me a nex axle? I dont have the bucks for a new axle as they are expensive, and I am already thinking of buying the Rims and tyres which is gonna cost me well over R3K.
    Please guys, any advice would be appreciated!
    Regards.
    Oz
ID:	436140   Click image for larger version.
ID:	436141   Click image for larger version.
ID:	436142   Click image for larger version.
  8. #28
    Jun 2012
    Klerksdorp
    Thanked: 64
    Quote Originally Posted by Oz-Meister View Post
    Hi Gents
    Regards.
    Oz
    Hi Oz. It all depends on the offset of the rim you will be using with these tires so that you still have about 5cm clearance between tire inside wall and the trailer/chassis. See the pic attached and do some measurements.
    2009 Toyota Fortuner 3.0 d-4d 4x2
    Custom off-road trailer with Echo TTT
  9. The Following User Says Thank You to konstanddp For This Useful Post:
  10. #29
    Jan 2017
    Brackenfell
    Thanked: 17
    Hi Konstaddp
    The diagram is very helpful thanks a mil...
    Ja Burquip said the current 155/80/13 has a 85mm spacing where the 195/R14 has a 120mm spacing....
    It is probably what it is... But 35mm exstra between the body and centre of the wheel is alot of space for going one rim size up... it probably is'nt because of the rim size, but because of the width of the proposed tyre... the 195mm
    Would there be nothing else one can do except buying a wider axle? Like perhaps putting in spacers to make it wider as per say...
  11. #30
    Jun 2012
    Klerksdorp
    Thanked: 64
    Hi Konstaddp
    spacers will work, but even better, you do get rims with different offsets. Maybe rather see if you can order rims with a 'deep dish' design or a specific offset if possible
  12. #31
    Jan 2017
    Brackenfell
    Thanked: 17
    Hi Guys
    I recently upgraded my Trailer with wider axle and larger tyres, also changed the mud-guards, so I have an Burquip 900Kg Axle, 3 x 13-inch rims with tyres in very very good condition (90%) Tread and 2 x 13-inch mud-guards white, for sale all for the low low price of R2200
    Please send me a PVT message if interested, I am in Brackenfell thanks peeps.
    Oh, it came off a 6 foot Camp Master Town & Country Multi Trail Trailer
    Shap Shap...
  13. #32
    Aug 2010
    Durban SA
    Thanked: 37
    Quote Originally Posted by Blackie View Post
    I have a 40L plastic water tank, similar to the one in the link below, just dark green colour. Took it out of my trailer as I do not use it.
    Will swop for a recovery strap / R200 cash.
    https://www.makro.co.za/diy/pioneer-...r-tank-40666EA
    If you where only closer to Durban i would take it from you
  14. #33
    Jan 2017
    Brackenfell
    Thanked: 17
    HI Guys
    Previous post on the 900KG Axle, 3 x 13 inch rims and tyres plus mud guards for R2200...
    Dropped to R1600...
    Let me know if you want foto's thanks.
    Oz
  15. #34
    Sep 2014
    Wilderness
    Quote Originally Posted by konstanddp View Post
    I have a set of steel 15" mud guards for a trailer, new and unpainted. R300 for both, collection in Klerksdorp
    Still available?
  16. #35
    Jun 2012
    Klerksdorp
    Thanked: 64
    Quote Originally Posted by RobYosh View Post
    Still available?
    Yes it is
  17. #36
    Nov 2014
    West Rand
    @konstanddp, if for some reason Robyosh dont want them. Im also in the market for unpainted mud guards.
    So if he does not take, 2nd dips please ?
    FRIKI5YSTER
    2016 Ford Ranger 2.2 D/C
    2014 Ford Ranger Supercab
    2012 VW Cross Polo
    [email protected]
  18. #37
    Jun 2012
    Klerksdorp
    Thanked: 64
    Quote Originally Posted by johant View Post
    no problem Johan
  19. #38
    Thanked: 135
    My needs have changed and I need to build a roof rack for my trailer, the bikes will go on a rear mounted carrier. So my Bicycle rack is up for sale. It can take 5 bikes.
    I has been spraypainted ans well as "Stone chipped". It will fit a 6 or 7 foot trailer
    I am open for any offers
ID:	440477   Click image for larger version.
ID:	440478   Click image for larger version.
    (CURRENT) NEW TRITON 2.4 DC MY19 AUTO
    (CURRENT) PAJERO LWB GLX 3.2 AUTO 4X4
    (SOLD) TRITON 3.2 AUTO 4X4
    (SOLD ) PAJERO SPORT 3.2 AUTO 4X4
  20. #39
    Thanked: 16
    I have n Alco 900kg braked rubber suspention for sale R2000 it is ex slipstream with 13 inch rims. will post foto tomorow
    Dankie
    Nico & Mandy
    2017 Mahindra S10 Scorpio D/C
    2018 Double trouble
  21. #40
    Melkbosstrand
    Thanked: 149
    Not sure if this is technically a trailer accessory, but I'm looking for a bike rack I can strap to the spare wheel of my Companion...
    In the Cape Town area....
