Amarok External Thermometer: Location?
Results 1 to 9 of 9
    Richards Bay
    Thanked: 28
    Default Amarok External Thermometer: Location?
    Hi all
    Can anyone tell me where the Amarok 4Motion's external temperature sensor is located? I find it fairly accurate most times, but while driving slowly (usually in the game reserve) I find that the temperature shown is unrealistically high. Obviously there is a lack of air circulation around the sensor, or it is too close to the road surface, or both, or something else that affects it at low speeds ...
    Just curious.
    Willem
    Dec 2009
    Thanked: 53
    Default Re: Amarok External Thermometer: Location?
    It is located ahead of the radiator, behind the lower front bumper grill.
    Current:
    2019 Tiguan Allspace 2.0TDI 4Motion DSG R-Line
    2019 Cross Up!
    2016 Metalian Maxi
    Richards Bay
    Thanked: 28
    Will go look for it - thanks.
    Oct 2007
    George
    Thanked: 40
    Facing the vehicle, on the lower right hand side, in the bottom grille.
    2013 Land Rover Discovery 4 3.0 SDV6 HSE (14 Julie 2017)
    2013 VW Amarok DC 2.0 BTDi 8-Speed Auto (1 Maart 2013 - 16 Julie 2017)
    2009 Mercedes C220 CDi
    2006 Desert Wolf Leo
    2004 Mitsubishi Colt 2.8TDi DC 4x4 Rodeo (Junie 2004 - Febr 2013)
    2004 VW Polo 1.4 TDi (Verkoop)
    Richards Bay
    Thanked: 28
    Thanks Attie
    Nov 2008
    Thanked: 44
    Weird - my Amarok does exactly the same... I was driving in traffic yesterday and then it just goes up and up - from 21 degrees to 28 degrees in a few minutes. When you start driving it goes down again. Wonder if it is the sensor that is crazy?
    2013 Amarok d/c TDI 103kW 4motion
    Oct 2012
    otjiwarongo
    Thanked: 117
    Quote Originally Posted by phuma View Post
    it is normal!!
    2017 VW Amarok BiTDi 4Motion D/Cab
    2012 VW Touareg V6 TDi Bluemotion
    2019 Bushlapa Miskruier 1616
    Nov 2008
    Thanked: 44
    Haha. If we all have the same symptoms then it is probably within parameters for the Amarok.
    Normal, no :-) My Golf does not do this.
    Dec 2013
    Thanked: 83
    According to the Manual it can show higher temperature due to engine heat at slow speeds.
    From my experience it is engine heat, and/or if the sun was shining from the front while stationary.
    I think you need constant speed of at least 60 - 80 km/h for some time to get reliable air temperature readings.
    And I think that is the case for most vehicles.
    Herman Meyer.
    AG0017 ORRA AG38
    2014 Amarok DC 4Motion Auto ,
    2015-02-03: Bush Lapa Miskewer 394.
  10. The Following User Says Thank You to hermanm10 For This Useful Post:
