Discovery 1 Disco D1 4" or 3" coils
Results 1 to 9 of 9
    Dec 2012
    Default Disco D1 4" or 3" coils
    Hi There all, I recently bought myself a Disco 1 3.9 V8, I have done some work on it and have replaced a few things ( HT leads, ignition coil, distributor cap, service including oils,coolant and etc ), work on the suspension done was most of the bushes are replaced, 2.5" body lift, 33" tyres, heavy duty coils ( which I want to change to 4" or 3" ), deleted the rear stabiliserz, 2 " coil spacers. I still have a few things to do ( 2" turrets, cranked rear trailing arms ). Where can I get 4" or 3" coils ? ( body damage when I flex hence want to change to longer coils), HAs anyone done this upgrade to 4" coils ? what should I be aware off and look out for ? Will appreciate your advice and suggestions..
    The race of life is not for the swift, it is for those who endure the pace '99 Land Rover Discovery 1 3.9 V8 33" General Grabbers ( Lots of custom suspension set-up )'07 Nissan hardbody 4x4 3.3 V6 ( 33"BFG Goodrich M/T,2.5" mm body lift,62 mm stainless steel exhaust with viper branches, 2.5" Custom Suspension lift )06 Kia sorento 2.5 CRDI 07 Isuzu kb 350 V6 (EX ) ( Sold )'11 Peugeot 308 1.6 comfort( swambo's taxi )[/ ( Sold )'14 Mercedes B-Class B200 cdi ( night package ) (swambo's taxi )-sold'15 Mercedes A-Class A200 cdi EX ( swambo's taxi )
    Ruimsig
    Thanked: 3142
    Default Re: Disco D1 4" or 3" coils
    Great choice, sorry I sold my D1 V8
    I cant advise on the coil info you require but I can point out an important Forum Rule and that is you cant mention all of the mods you have done unless you post PICTURES
    Otherwise, they never happened
    New Germany
    Thanked: 421
    If you do longer coils you must also do the bump stops as well you need to extended bump stops
    Dec 2012
    Some pics of her. Click image for larger version.
ID:	543679Click image for larger version.
ID:	543680Click image for larger version.
  5. The Following 3 Users Say Thank You to budo'z For This Useful Post:
    Ruimsig
    Thanked: 3142
    Looking the business
    Thanked: 10058
    and be careful of your pinion angles and caster...........
    Dec 2012
    Thanks noted
    Mar 2016
    Thanked: 1883
    Anything more than 2" coil lift you need castor correction mods as well
    Mar 2018
    Goba
    Thanked: 139
    On that kind of lift there is a serious lot of mods to be done.
    Extended break pipes (Steel Braided)
    Extended bump stops
    Cones in Coils to prevent dislodging.
    Angle correction on both diffs (Bent Radius arms and shortened trailing arms) or adjustable trailing arms which breaks !
    (The off center bushes do not correct your pinion angle enough)
    Remove or lowering of front sway bar (The Prop shaft tends to bounce on the sway bar with extreme travel)
    Replace front prop shaft with Double Cardan (D2 prop shaft)
    Wide angle rear prop shaft with U joints on both ends (The rubber flex coupling do not last)
    You might also have a wider turn circle.
    I did a 2'' lift with Terrafirma Heavy duty coils and big bore +2 shocks and wanted to go higher by extending the body mounts on the diffs but it did not work out well and went back down again to only 2" and heavy duty coils
    (Had a very bumpy ride when not loaded) and at the end of the day the ground clearance of the diff is the same and only higher with bigger tyres
    But it looks mean.....
    1997 Discovery 1 300 TD i ...Old Faithful
    2006 Discovery 3 2.7 TDV 6...not sure yet ?
