Mercedes Tech.
Results 1 to 3 of 3
Thread: Mercedes Tech.
    Witbank
    Default Mercedes Tech.
    Does anyone know a Mercedes Technician that know what he is talking about...ML 320 CDI Engine ,2006 model...OM642.My car is jerking under acceleration and then goes into limp mode ,no engine light ,no DTC codes ,nothing ,if I unplug the exhaust back pressure sensor the problem does go away but tha car is very underpower until revs start to climb but atleast driveable ,kick down is available but still very lui....sometimes I plug the sensor back then the car perform as new...no jerking ,full acceleration ,no problems.Mercedes did a check on the car and we could not find anything wrong ,everything check out fine ,any help would be appreciated.Thanks
    Apr 2008
    Faerie Glen Pretoria
    Default Re: Mercedes Tech.
    Hi, contact Bulli, a forum member in this regard.
    He is a Jeep guy. The same engine was used in the Grands that is in your Merc.
    cell: 0625434275
    He is in Silverton Pretoria.
    Thanked: 86
    Hattingh Motors in Centurion 012 663 6477 Gerrie
    Ps 16:5
