Garmin Foretrex PC interface cable, RS232 serial port connector
Results 1 to 2 of 2
    Lubumbashi
    Thanked: 12
    Default Garmin Foretrex PC interface cable, RS232 serial port connector
    Good evening,
    I am looking for a Garmin Foretrex 101 interface cable, RS232 serial port connector. Should look something like this:
    The next step would be to search for a RS232 to USB converter .......
    Please advise.
    Regards,
    Kinnie
    Mar 2016
    Netherlands
    Thanked: 194
    Default Re: Garmin Foretrex PC interface cable, RS232 serial port connector
    I guess your best option would be to look for it on Ebay (or on Alibibaba). There are several Chinese firms that supply such cables. I bought one several years ago to connect an old Garmin unit to my pc. It took a lot of trouble as the cables did work but they needed old drivers as well. And old drivers don't always work with new operating systems. Luckily the new Garmin units all use USB directly.
    Regards,
    Hans
    http://www.wildpicture.com/
    Overland trips with rented 4x4's in South Africa, Botswana, Nambia, Zimbabwe, Zambia
    (Toyota Hilux DC, Landrover Defender 110)
    1999-2005 Suzuki Jimny JLX 4x4
    2016- Suzuki Jimny JLX 4x4
  3. The Following User Says Thank You to Wildpicture For This Useful Post:
