Smoke from diesel tank when opening???
Results 1 to 13 of 13
    Witbank
    Default Smoke from diesel tank when opening???
    Last nignt I openned the filler cap on my 2006 ML320 Diesel and a lot of white smoke came out as the pressure released ,it kept coming out as long as I put fuel in ,it was just about 1/4 tank when I started filling ,car was driven and the ambient temp. was a little bit lower than normal +-14C ,did anyone else experience this before.
    Thanked: 194
    Default Re: Smoke from diesel tank when opening???
    Might be that the diesel from the underground storage was very cold.
    Find the solutions, not the problems.
    Witbank
    The smoke come out before I started to put fuel in.
    Thanked: 9353
    Next time smell if it's smoke or steam.
    Witbank
    Well if it is either one ,where is it coming from and what can cause this ,I think it might be to do with the temp. and pressure difference ,what I want to know is if someone else seen this before or experienced it before on a diesel vehicle.
    May 2015
    Somewhere...
    Thanked: 285
    As you say the vehicle had just been driven, it might be that the fuel return had put a lot of hot fuel back into the tank which had cooler fuel in it. How hard had you driven the vehicle before opening the cap? The harder you drive a diesel, the more unused fuel is returned to the tank, if I am not mistaken.
    No, I have never experienced this before, so I am just theorising. Might also have something to do with relative humidity, ambient temp etc together with excess moisture in the tank, which steamed when hot fuel was added to it. Diesel has moisture in it already, hence the need for a water trap in your fuel system.
    Has the vehicle ever stood for extended periods with less than a full tank? If it has, the remaining fuel sweats and coats the tank with water vapour. In the long term, you will have layer of algae growing in your tank underneath the remaining diesel.
    1998 Defender 90 TDi 300 for Africa.
    2014 Ford Fiesta 1L EcoBoost petrol for Europe.
    Swambo and I have a little travel blog: https://www.thetravellingchilli.com
    King Williams Town
    Thanked: 848
    Check your fuel pipes aren't running next to a hot surface maybe. Are your tank.breathers not blocked.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Thanked: 9353
    Quote Originally Posted by WTaute View Post
    I've never heard of or seen this.
    common rail diesels return highly pressurised fuel back to the tank and this can get very very hot.
    If you have very little fuel in the tank, all the diesel will reach a high temp very quickly. Residual water in the tank will vaporise and form steam.
    THAT BEING SAID: you shouldn't have that much water in your fuel tank...........
    Thanked: 2252
    Hot breath on a cold day.
    The fuel in your tank is rather hot after a drive.
    Thanked: 135
    Fuel is hot after drive, the return pipe took back some warm sous
    (CURRENT) NEW TRITON 2.4 DC MY19 AUTO
    (CURRENT) PAJERO LWB GLX 3.2 AUTO 4X4
    (SOLD) TRITON 3.2 AUTO 4X4
    (SOLD ) PAJERO SPORT 3.2 AUTO 4X4
    Thanked: 2252
    diesel floats on top of water so any moisture will be picked up first by the pickup and either stop in the filter or go through to the injectors......
    See why filters and water traps play such an important role. The bad stuff gets picked up first.
    Apr 2011
    Thanked: 918
    Remember that in any CRD engine the diesel gets pumped by the high pressure pump in to the common rail at between 1000bar-2000bar (15000Psi-2500Psi).
    That is one mo.r of a pressure and diesel heats up to something like 70degC (actually much warmer but gets cooled by the diesel cooler again before it reaches the tank, IIRC) in this process. Only a small amount of that diesel gets used and the rest gets send back to the tank via the diesel return pipe.
    When outside temps are so low (+_14degC) it will look like vapor/smoke.
    Witbank
    Yip ...I think it is the Temp. and Pressure Difference.
    Thanks.
