Tent pegs for sandy conditions (advice needed) - Page 2
Results 21 to 40 of 44
    May 2013
    JHB
    Default Re: Tent pegs for sandy conditions (advice needed)
    Quote Originally Posted by SinWolf View Post
    What is a good pen to use on a beach? For a gazebo ?
    Bury an empty bottle (buddy coke, water, whatever) filled with sand and tie the cord to the bottle. Just remember to clean up afterwards.
    Tentco has a variety of pegs, including spiral sand pegs @ R15.00 each, available.
    Tentco tel no 011 397 6451
    Seen on their website
    Storm Straps
    Straight Pegs
    Size: 200mm x 4mm - Medium (5 per Pack)
    Size: 300mm x 5mm - Large (5 per Pack)
    Anchor Pegs
    Size: 550mm x 8mm - X-Large (1 Peg)
    Ground Sheet Pegs (5 per Pack)
    Spiral Sand Pegs (1 Peg)
    Garsfontein, Pretoria
    This Toughstake is a very good patent, the idea of having the anchor point deep in the sand makes good sense. You can make it from 76x76mm Angle alluminium and a lenth of about 30cm.
    https://www.youtube.com/watch?v=DXb2qLvtVx8
    '02 Toyota Prado 3.0 td VX, SAC intercooler, Kumho KL78 A/T's. DIY roofrack and rack system.
    "Good judgement come from experience, experience come from bad judgement"
    Aug 2007
    George
    I saw a guy December who had 4 square pieces of teflon about as big as a tile (300 by 300), hole in the middel of each and with a cable that s about 500 mm long through the hole. he digs a hole and put them in and cover is up then ties the rope of the gazebo to the cables end. worked well!
  5. #25
    Quote Originally Posted by Dr Jones View Post
    Make yourself a few sandbags, I like the plastic bag idea, fill them and simply fasten the tent to them. It works quite well in places like the Richtersveldt
    Nice idea yes,and everybody should actually have a sandbag or 6 when overlanding. Multiple uses, take up no space.
  6. #26
    Quote Originally Posted by WernerS View Post
    Nice idea. I cannot help but think that he should have the V pointing in exactly the opposite direction for more effectiveness.
    Make it happen!
    2018 Mobi Lodge
  7. #27
    mafikeng
    Got some sand pegs from Outdoor Warehouse they were angle iron type with a washer on top thru which you then knock in angled tent peg (does this make sense )
    Sent from my SM-G900H using Tapatalk
  8. #28
    v-town
    Quote Originally Posted by Toccata (Roelof) View Post
    Exactly what i was thinking !
    Sent from my SM-N920C using Tapatalk
  9. #29
    Feb 2008
    If you take 1000mm rebar tent pegs with, where do you pack the branawyn?
    Nissan Sentra 160GX (105kw)(Sold)
    Mercedes-Benz C180K
    Yotota Fortuner 4.0V6 (Sold)
    Freelancer 2 SE
    PS Shogun
  10. #30
    Clanwilliam
    The easiest and cheapest option in sandy conditions is just to use big rocks for anker points. Or smaller rocks on top of normal pegs.
    Otherwise the longer the pegs the better.
    Those spiral pegs are useless
  11. #31
    Quote Originally Posted by HiluxRoux View Post
    We took sandbags.. filled them with sand, dug a hole in the sand, tied the lanyard around the sandbag, and buried it.
  12. #32
    Jan 2016
    king william's town
    What may also work is using three different pegs one after the other in a row. The first one has to pull against the second and the second against the third before it can pull out.
    There is a similar recovery technique used to anchore a vehicle with iron standards for winching yourself out of soft sand.
  13. #33
    George
    I use 400mm long pieces of floor board to anchor our gazeebo on the beach. Drill a hole through the middle and tie the anchor strings through it. Bury the planks in the sand as deep as necessary. If you forget the planks, collect a few sticks.
    A mod on this could be to tie a short piece of strong chord through the planks and attach a wire hook to it. That way you your tent's guy ropes are easier to adjust.
    Tyrannosaurus R5 and a second hand British Tata
    Quote Originally Posted by 2beFree View Post
    Jan your signature says it all
  14. #34
    The long spiral turn in flexible pegs which are available from most outdoor places work best. Never travel without it. Even in Kunene mouth where it is believed where the wind is born, they work well.
  15. #35
    Sandton
    www.maxcons.co.za have some ideas
    2013 Discovery 4 SDV6S
    2008 Discovery 3 TDV6S (SWAMBO)
    Imagine Comfortvan
  16. #36
    I made some from angle iron approx 300mm long.
    Cut at angle on one end for the sand.
    Drilled hole in the top to hook something for the rope to be attached.
    Eventually weld a piece of square tubing in the inside 2/3 of the length to fit a L shaped peg.
    Just knock the L shape and angle iron in same time as the square tubing get sand in that is compacted rock hard.
    It works well in sand.
    Used them in real sandy areas, De Hoop in Rigtersveld they stayed in.
    In the Kgalagadi normal L shape pegs work well provided they are long.
    Also add some spring/elastic material between peg and rope.
  17. #37
    King Williams Town
    I wonder if big washers at an angle welded to a shaft would work. You then screw in the peg. Did a silly drawing.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  18. #38
    Mooi River
    Angry Re: Tent pegs for sandy conditions (advice needed)
    The best tent peg for soft sand is a brick. Wrap the tent cord around it and bury the sucker.
    Now we're talking - but who carries all those bricks around? Just tie the rope around the middle of the peg, or a stick, and bury that sideways. I've never had one of those pull loose. and then you can always tie up to a nearby Rosyntjie bush or even a driedoring (don't mess with a swarthaak.)
  19. #39
    Feb 2008
    Quote Originally Posted by cptfly View Post
    We will be camping in the Kgalagadi / Kalahari region which has some sandy camping conditions. How do you ensure your tent peg stay secure in the sandy conditions. Do you use longer tent pegs ? Feedback will be appreciated.
    I see you're in Parow - if you go to Cape Twines and Packaging (also called Cape Bag Group) at 177 Alfred Road, Woodstock, they sell the woven polpropylene military sand bags (the ones the road works guys use to weigh down their warning chevrons etc). Cheap, and very effective in soft sand - just half fill them with sand and tie them to your guy rope. Also very useful for creating a track when stuck in soft sand.
    Tony Weaver
    1991 Land Rover 110 Hi-Line S/W 3.5l V8 carburettor
    Cooper Discoverer STT tyres, four sleeper Echo rooftop tent
    2012 Mitsubishi Outlander.
    Previously Land Rover 1968 SII, 1969 SIIA, 1973 SIII, 1983 Toyota HiLux 2litre, 2006 Land Rover Freelander TD4 HSE.
  20. #40
    Dec 2010
    Uvongo
    Good Old Spar/Shoprite plastic bags filled with sand.
  1. Help needed - tent removal from a Compact II
    By Ubbo in forum Trailers, Caravans, Towing etc
    Last Post: 2015/09/09, 07:31 PM
  2. Advice needed on modifying Howling Moon 2010 Trailer Top Tent
    By Jan M in forum Trailers, Caravans, Towing etc
    Last Post: 2012/01/17, 03:38 PM
  3. Replies: 14
    Last Post: 2010/04/16, 05:07 PM
  4. Unit Standards Registered
    By 4x4offroad in forum 4x4 Training / Certifications
    Last Post: 2009/01/10, 12:02 PM
