Results 21 to 40 of 48
  1. #21
    Thanked: 119
    Default Re: My FJ Cruiser story
    Quote Originally Posted by Guillaume View Post
    Like!! :-)
    Where did you get the "switch: with the dual USB ports? (It is exactly what I need) Any idea if they are 1 amp or 2 amp USB ports?
    Guillaume
    I bought these through 4x4Direct, fits and works perfectly.
    http://www.4x4direct.co.za/en/power-...+usb&results=5
  2. #22
    Apr 2011
    Thanked: 19
    Quote Originally Posted by Adam Stander View Post
    Thanks!! I am going to order today.
    Did you have to cut any electrical wiring to install the USB plug, or does it plug into an existing open connection?
    Guillaume
    Guillaume
    Fortuner Epic 4.0 V6 AT
  3. #23
    Thanked: 119
    It has its own little harnes to plug and unplug after installation, but the wires have to be tapped into your wiring
  4. #24
    Feb 2016
    Thanked: 1007
    Very nice!
    Would like to see a photo of the inside looking back if possible.
    As promised, here are a few photos of the inside. As I said I'm still working on ideas. Did anyone else permanently remove their back seats and build in something for storage in its place?
ID:	403347   Click image for larger version.
ID:	403348   Click image for larger version.
  5. #25
    Thanked: 119
    Nice, so you actually still have loads of space for clothing, sleeping bags etc
  6. #26
    Feb 2016
    Thanked: 1007
    One of the big advantages of the RTT is I can leave all the bedding in the roof, so no more sleeping bags or pillows falling out into the dusty road
  7. #27
    Apr 2012
    "Zombie Lights" what do they do?
    Sent from my SM-N920C using Tapatalk
    2011 Toyota Fortuner D4D 4x4
  8. #28
    Feb 2016
    Thanked: 1007
    Quote Originally Posted by P-JAY View Post
    Courtesy lights between the rock sliders: I bought silicon pipe at a hardware shop, inserted LED strips in the clear pipe and sealed both ends with a gluegun. So now this 'light tube' is 100% air and water tight. Luckily for me there are support plates between the two rockslider pipes with the exact same diameter hole as the silicon pipe, so I worked the 'light tube' through these support brackets. I used my dome light inside the car as power source so the light tube goes slowly on/off as the dome light does when the car is unlocked/locked or the doors are opened/closed. The Zombie lights switch is just the switch I use to disable the light tubes if my doors are going to be standing open for a while. It makes a lot of light under and next to the car, helpful to dodge a puffadder or mud pool when climbing in or out at night
ID:	403358   Click image for larger version.
ID:	403359   Click image for larger version.
  9. #29
    Oct 2015
    Wow, I'm inspired. Going to upgrade my mods.. Totally awesome look
    2004 Golf 4 GTI - Just memories now (Sold)
    2005 BMW 330i E46 - best 18 inch rims ever (Sold)
    2006 Landrover Discovery 3, V8, 4.4l - Favourite weekend toy (Going strong)
    2007 BMW 330d M Sport E90 - The beast (Going strong)
    Tree-hugging techno ned junkie addicted to Drupal, gadgets, drills, SUV's, BIG screens, Cubanas, whiskey, Bespoke Projects & yes ofcuz, the outdoors...
  10. #30
    Thanked: 103
    Quote Originally Posted by MrTolbos View Post
    As promised, here is a few photos of the inside. As I said I'm still working on ideas. Did anyone else permanently remove their back seats and build in something for storage in it's place?
    Hier is soos myne agterin gelyk het.
Name:	IMG_4197 (Medium).JPG
ID:	403447   Click image for larger version.
Name:	IMG_4198 (Medium).JPG
ID:	403448   Click image for larger version.
Name:	IMG_4199 (Medium).JPG
ID:	403449   Click image for larger version.
Name:	IMG_4200 (Medium).JPG
ID:	403450   Click image for larger version.
Name:	IMG_4204 (Medium).JPG
ID:	403451   Click image for larger version.
Name:	IMG_4207 (Medium).JPG
ID:	403452   Click image for larger version.
Name:	IMG_4206 (Medium).JPG
ID:	403453   Click image for larger version.
Name:	IMG_4212 (Medium).JPG
    Moenie leef met die droom "ek gaan dit doen as ek eendag aftree" want dit mag dalk nie gebeur.
    2019 SYM Citycom S300i
    2019 BMW 1250 GS
    2018 Toyota Hilux 2.8 4x4 Raider.
    2018 Mercedes-Benz V-Class 250d Avantgarde
    2012 Dethleffs Esprit Motor-home.
  11. #31
    Thanked: 103
    Quote Originally Posted by BBK View Post
    Ek het my FJ verkoop maar het nog al die goed vir agterin.
    PM my as jy belangstel.
    2019 BMW 1250 GS
  12. #32
    Feb 2016
    Thanked: 1007
    Ek hou van jou jerry kan idee, dan nie nodig om die dak te oorlaai nie. Was jou platvorm onder die jerry kanne van gewone plywood?
    Ek sien daar loop 'n draad of kabel van agter die brandblusser af teen die kant van jou deur op na die dak toe. Was dit vir 'n radio/gps antenna?
    Ek het ook eers oorweeg om my yskas bo op laaie te sit, maar is die yskas nie dan te hoog nie?
  13. #33
    Thanked: 103
    Ja hy was, hy le hier in my Garage as jy wil kom kyk.
    2019 BMW 1250 GS
  14. #34
    Mar 2012
    Fourways
    Thanked: 440
    Always loved the FJ and what you have done is pretty awesome!!! Good going!
    Rob,
    D4 SDV6 HSE ARB Bullbar, Compos, BFG 265/65R18s, Big Country drawers, National Luna 52L, Dometic 50L, Spare Wheel Carrier, Roof Rack, Hardshell RTT, FR 50" LED Bar, Lift Rods, Mantec Snorkel, C-TEK Dual batt system, 270 Ostrichwing, Maxtrax, TXG Rock Sliders, IIDtool, shelf
  15. #35
    Nov 2012
    very nice and practical mods there!
    i would like to enquire where i can get those USB sockets from? I am in Durbs and would love to fit one in my Tuna.
  16. #36
    Feb 2016
    Thanked: 1007
    Quote Originally Posted by AJ_911 View Post
    I bought it via amazon on my previous trip to the states, but I know LA Sport in PE also had a few. Adam Stander said in a previous post he found it online at:
  17. #37
    Apr 2011
    Thanked: 19
    Hi AJ
    Have a look here: http://www.4x4direct.co.za/en/power-...dashboard.html
    R190 looks like a bargain!
    Guillaume
    Guillaume
  18. #38
    Aug 2015
    Langebaan ,CT
    Hi, have you still got the original roofrack ,as I need the horizontal beams urgently. You can mail me [email protected]. Regards Etienne. All the silver parts on mine is also black with snorkel etc.
  19. #39
    Thanked: 363
    Quote Originally Posted by Etienne Botha 0 View Post
    I have one that I'm not using anymore.
    Ross
  20. #40
    Aug 2015
    Langebaan ,CT
    Hi Ross
    I don't use this forum to often, so I hope I am doing this reply is to you.
    In which part of the country are you?
    If in WP, then I am interested.
    Rgrds
    Etienne
    [email protected]
  1. Replies: 21
    Last Post: 2019/07/03, 01:53 PM
  2. Is a FJ Cruiser a Land Cruiser?
    By PotholeDriver in forum Toyota
    Last Post: 2015/12/20, 06:36 AM
  3. Replies: 10
    Last Post: 2013/07/07, 09:16 AM
  4. De La Rey Cruiser
    By Bostokkelos in forum The 4x4 Pub
    Last Post: 2011/03/30, 09:18 PM
  5. Land Cruiser's 60
    By Bogaards in forum Toyota
    Last Post: 2011/03/08, 11:15 AM
