Solar panel on a closed trailer top tent? - Page 2
Results 21 to 40 of 44
  1. #21
    Jun 2012
    Klerksdorp
    Thanked: 64
    Default Re: Solar panel on a closed trailer top tent?
    oradba69, I like that idea! you can even then add a tilt mechanism to maximize your angle to the sun (only used when camping off-course )
    BruceT, very true. the above should cover that as well
    I'm seeing another connect-it use coming to mind!
    2009 Toyota Fortuner 3.0 d-4d 4x2
    Custom off-road trailer with Echo TTT
  2. #22
    Senekal
    Thanked: 90
    I had 2 x 80w glass panels fitted in aluminium mounting frame (http://www.bushpower.co.za/products.asp?pc=13) before , had it fitted on the roof rack
    It works perfectly except it was heavy to install it when needed , the vehicle have always be to be in the sun when charging is needed when stationary and about nothing else could be loaded on the roof rack
    I have now a few of 100w flexi panels (think it same as Stranger, also got it from forum member ) and it works satisfactory for my needs as it is much lighter and less bulky
  3. #23
    Jun 2013
    Thanked: 2410
    My point about the shade, panels fixed to the vehicle needs to be in the sun, so you now get a hot fridge competing against your consumption.
    BMW R1200R
  4. #24
    Jun 2012
    Klerksdorp
    Thanked: 64
    I like the idea of a loose frame over the tent. With a good design, it will make the putting on and taking off quick. and you then also have the option of maybe using the frame to carry a small kiddies bike etc. one day when the solar is not used for that trip.
    Will also be easier to make it theft proof with a frame
  5. #25
    Thanked: 271
    Depending how your trailer look, one can even make this frame swivel to create a kind of awning.
  6. #26
    Jun 2015
    Thanked: 32
    Why not just charge from the car?
    If you don't want to change the cars system it can work. Build a sturdy frame and strap it to the top of the tent.
  7. #27
    Jul 2013
    Thanked: 263
    What about a geyser drip tray to fix the panel in , made of plastic sturdy an cheap.
    Strap it to the tent with the straps of the tent cover.
  8. #28
    Thanked: 1041
    Just remember you also need ventilation under the panel if using glass panels.
    Why?
    I have seen many panels mounted on a flat surface with no ventilation to the underneath.
  9. #29
    Hillcrest, Malaysia
    Thanked: 5885
    Why?
    Simply, just to keep the panel cooler when stationary? Cooler panels generate more power than hotter panels.
    But I think the difference would be hardly noticeable.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  10. #30
    Bosveldsig, Nylstroom/Modimolle
    Thanked: 177
    We store our panel between the TTT and the trailer.
    Just require brackets to lift TTT and a envelope made from 3 ply where the 130 W panel fits in.
    Four RED BH plugs and 10m lead to connect the panel to the trailer.
    Tried the panel on top of the TTT, it moves on bumpy roads - require some sturdy way of keeping it properly attached.
    Using the NL solenoid to charge while driving, does not charge the battery fully but keeps it going while traveling.
    Danie & Marinda - die wiele is rond, dus moet hulle hardloop - afgetree nou leef ons net.
    2017 BL - Kewer B1115 RUS WA GP - bos en kamp tyd
    2016 Ford Fiesta Ecoboost - daaglikse ryding
    2013 Ford Ranger 3.2 DC XLT 4x4 - nuwe rondloop ry ding, nou sleep ons! (2017)
    2011 Echo 4, die RUSWA-ZN - (verkoop 44 000 km)
    2010 Ford Ranger 2.5 DT DC XLT 4x4 - rondloop ry ding met "bietjie ekstra" krag (Verkoop 177 000 km)
    2005 Chev Aveo - Afgeskryf (2016 130 000)
    2005 Opel Corsa 17DTi - Geruil (warm enjin 180 000)
    2003 Opel Corsa 17DTi - Geruil (warm enjin 150 00)
    2000 Nissan Hardbody - Geruil (pyne by die duisended 52 000 km)
    1998 Opel Kadett - Dogter se wiele geword in 2003 (baie warm enjin 116 000 km)
    1990 Datsun 1800 short wheelbase - Pa se ou plaas bakkie, na die Nissan die pad gevat het met sy probleme in 2003 (117 00km)
    1990 Hilux 2.4D - en hy kon loop, pomp en top gewerk aan.
    1984 Opel Commondore - het gehardloop
    1983 Safary 3 karavaan - verkoop en begin tent in 2000 (51 000 km)
    1980 Ford Granada 3.0 - warm enjin afgeskryf
    1969 VW 1600 TL - geen einde nie, warm enjin en geruil
    1968 VW 1600 L - geen einde en baie warm enjin, verkoop in 1998 (328 000 myl/525 000 km)
  11. #31
    Jun 2012
    Klerksdorp
    Thanked: 64
    my dak rak is redelik vlak en gemaak van staal plaat met gate in gesny, so ek kan nie die spasie daaronder benut nie. miskien is dit tyd om dit te verander...
    (Jy moes daar gewees het toe ek die tent op hom moes vas sit, dit was nou pret! Baie *#@&$)@ LOL)
  12. #32
    Jun 2012
    Klerksdorp
    Thanked: 64
    Ek dink ek gaan die connect-it frame idee doen, soos 'n leer wat oor die wa loop. Gaan dit voor oor die tent laat krul om aan die tent raam/dak rak vas te maak. agter sal ek of dieselfde doen of net 'n ratchet strap.
    Vraag Danie, as jy twee ratchet straps gebruik, een aan elke kant wat na hul kante toe trek, hoe beweeg hy as jy hom 'n raam gee om goed vas te trek?
  13. #33
    Jun 2012
    Klerksdorp
    Thanked: 64
    something like this??
  14. #34
    Thanked: 177
    Quote Originally Posted by konstanddp View Post
    Ek het die probeer vasmaak bo op die tent met twee straps dwars en een oor die lengte.
    Toe ek my weer kom kry was hy besig om oor die een kant te beweeg.
    Moes ook een keer bietjie vining stop en die paneel het voorentoe oor geskuif.
    Toe maar die tent gelig met die brackets en raam met tussen in hout laai vir die paneel.
    Hy het nou kwaai bokspringe en rowe paaie in Namibia en Rigtersveld, selfs Akedispas oorleef sonder probleme.
  15. #35
    Addo
    Thanked: 253
    I'm busy building a roofrack and solar panel frame in one that will fold over my rooftop when it is fold up , when fold up the panels will be underneath and roofrack on top , when camping it will fold over to the towbar side with the panels on top and be able to turn it to always face the sun. I will be finished in about two weeks and will then post pictures for feedback and idees from everybody.
    Range Rover Sport SC 4.2 V8 ( FATBOY )
    Disco1 V8 ( LAZYBOY )
    Austin Mini 1380cc ( Finiky )
  16. #36
    Jun 2012
    Klerksdorp
    Thanked: 64
    Quote Originally Posted by lazyboy View Post
    Thanks Lazyboy
    I attach a pic of the roof rack that Echo added to their trailers from Nampo. It loosens in the middle and the one half flips to the front and the other half to the back
  17. #37
    Thanked: 177
    How high would that roof rack and items be, think trees and some low items will come in to play.
    Anybody completed their solution, another chap is also looking for a PV storage area.
    He is considering the lift of the TTT, similar to my one.
  18. #38
    Jun 2012
    Klerksdorp
    Thanked: 64
    Quote Originally Posted by Danie S View Post
    Still lower than putting it on the vehicle roof
  19. #39
    Thanked: 177
    My TTT is level with the roof of the bakkie.
    Not putting anything higher than 300 mm above the roof, got hit once not again.
  20. #40
    Jun 2012
    Klerksdorp
    Thanked: 64
    Danie, ek beplan om 'n rak te maak met connectits, net groot genoeg vir die paneel om die temptasie te voorkom om ander 'junk' op te laai. Die rak van Echo vir fietse is egter tempterend. Die 4 fietse agter op my wa maak die neus effe ligter en sleep minder lekker.
    Wat het jy op jou rak gehad en wat het gebeur?
  1. Bush lapa miskruier review
    By Jaco Kruger in forum Trailers, Caravans, Towing etc
    Last Post: Today, 09:47 AM
  2. HCDP dc-dc charger
    By Kobus Jacobs in forum Camping, Fridges, Accessories
    Last Post: 2018/12/22, 05:04 PM
  3. Trailer for Trailer Top Tent
    By Quiksilver in forum Trailers, Caravans, Towing etc
    Last Post: 2017/09/06, 01:00 PM
  4. town and country with trailer top tent
    By golfstok in forum Trailers, Caravans, Towing etc
    Last Post: 2015/07/19, 11:04 AM
  5. Solar system ...
    By Elders in forum Camping, Fridges, Accessories
    Last Post: 2013/02/27, 12:09 AM
