Suzuki Jimny suspension not level
Results 1 to 20 of 31
    Default Suzuki Jimny suspension not level
    Hi
    Can anybody give me some advice on how to level my Jimny's aftermarket suspension?
    A spacer was installed but did not fix the issue..
    The car also feels very unstable on rough roads now, as if the spacer is compressing the coil more than the rest of the coils causing instability.
    Any advice is appreciated.
    Jan 2015
    Thanked: 119
    Default Re: Suzuki Jimny suspension not level
    Which way is the car uneven? Front/back/left/right.
    Sometimes the springs are put in on the wrong side of the vehicle which causes the unevenness
    Sent from my iPhone using Tapatalk
    2009 Zook Jimny Sport - with too many extras to mention
    True fuel consumption is shown as FuellyData+7.4%
    Build Thread: http://www.4x4community.co.za/forum/...ead?highlight=
    The right side is lower than the left, not by much, but enough for it to be obvious and compounded when a driver is in the car.
    Kimberley
    Thanked: 18
    Might be the coils are the wrong way around?
    Jan 2015
    Thanked: 119
    Which kit is it?
    Thanked: 130
    My guess would be that the front rhs and lhs springs should be swapped. In many of the after market spring kits the drivers side spring is a bit longer to compensate for the weight of the driver.
    @ Rivar: I don't know if I am allowed to state the brand, but if you know your brands the shocks are white and the coils are blue lol.
    Thanks Marius I will have that checked out asap.
    The story they spun me was that the coils for the Suzuki's sometimes come out of the factory with different lengths. If that is to compensate for drivers weight, surely either the accredited installers or the salesperson/rep should point this out after I complained.
    Thanked: 130
    The coils should be marked as well.
    Ai jai jai... thanks again guys, I will have a look asap
    Jan 2015
    Thanked: 119
    Can't see why you are not allowed to state brand. But sounds like ProFender from LAS. I could be wrong though...
    I have jimnybits coils with avo shocks. The rear coils are the same length and result in the rear right sitting lower. Even changing springs from left to right resulted in the right sitting lower. Fitted a spacer and it's sorted now. Fronts were different lengths with the longer being on the right.
    Ok cool, I have Amada Extreme
    Jan 2015
    Thanked: 119
    Quote Originally Posted by aa3smit View Post
    Chat to Kobus. Have heard he is always willing to assist.
    I spoke to him, He sent the spacer. Met him again at a Bridgestone event, showed no interest in resolving this issue, hence this thread.
    Mar 2012
    Thanked: 101
    Wel that would be bad for them. The forum has quite a impact for future business for them.
    Kobus has however always seemed to be helpful and willing as far as I have seen. Maybe you got him on a bad day.
    I have efs in and have no such issues that I'm aware off. Been happy with it from day one and there's no weird feelings except for my panhardrod but I still need a lifting bracket for that.
    How much did you lift? Might also be your problem
    Sent from my E6553 using Tapatalk
    Creeper
    Jimny 1.3 - Radial cup Protectors, Front & Center Bash Plates, 50mm EFS's, Rock Sliders, Front Recovery Points, Snorkel.
    May 2008
    Edgemead
    Thanked: 16
    Can you please post photos of the height difference.
    Did you replace the shocks as well?
    What amount was the vehicle lifted by?
    If the vehicle was lifted did you install correction bushes?
    Marius Reitz
    Nissan Xtrail
    Astronomy and Telescopes
    Chairperson for ASSA - Cape Center
    • 13.1 inch custom built truss telescope on a dobsonian mount
    • 10 inch Meade SCT
    • 8 inch Celestron SCT Powerstar
    • 8 inch Skywatcher reflector on a Celestron CGEM mount
    • 8 inch Orion SkyQuest
    • 6 inch Orion reflector on a EQ5 mount
    • 5 inch Konus Maksutov Cassegrain on a EQ3 mount
    • 5 inch Alter Maksutov Cassegrain on a EQ4 mount
    • 15x70 Celestron Skymaster binoculars on a parallelogram mount
    Will do so asap.
    Shocks and coils, as well as correction bushes.
    2" lift.
    Right rear ground to top of wheel arch 79.7cm
    Left rear ground to top of wheel arch 81.5cm
    This is without a driver in the car.
    Thanked: 1453
    Couldn't it also be the correction bushes?....then again, your problem is at the back....maybe the coils I guess. Count how many turns on the rear coils.
    Sent from my iPhone
    Jan 2015
    Thanked: 119
    That's with the spacer?
    Front left is also about 10-15mm higher.
  1. My Jimny review...
    By Krutch in forum Suzuki
    Last Post: 2014/07/04, 09:28 AM
  2. Replies: 12
    Last Post: 2014/05/03, 06:58 PM
  3. Replies: 34
    Last Post: 2010/04/23, 05:22 PM
  4. 40th anniversary of the Jimny
    By wizerd in forum Suzuki
    Last Post: 2010/04/23, 08:38 AM
  5. SA Women vote Suzuki Jimny Tops
    By Sawdust in forum Suzuki
    Last Post: 2009/10/16, 10:43 AM
