Restoring my 1971 Pinzgauer 710 M - Questions/Advise, Please - Page 2
Page 2 of 34 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 27 ... LastLast
Results 21 to 40 of 666
  1. #21
    Thanked: 12882
    Default Re: Found Interesting 4x4 : 1971 Steyr Puch Pinzgauer 710 M
    Quote Originally Posted by Chris Stoffel View Post
    Q20 down the sparkplug hole and turn the engin without the plugs to get the oil to all the places. If the oil presure light on the dash goes off then the new oil is where it should be and the oil film layer is restored and old oil is flushed away. Or something like this!
    Yep, penetrating oil for 3 days, turn over using a spanner on the crank, then spin without plugs to get oil pressure up.
    Only then reinstall the plugs and try start her.
  2. #22
    Jeffrey's Bay
    Thanked: 9352
    Just been looking at a few vids on Youtube. These seem to be really nice and capable toys!
    https://www.youtube.com/watch?v=qHgwsg1ZBJE
    Anton
    "At the end of the game, the King and the pawn go back into the same box." - Italian Proverb
    "The single most important component of a camera is the twelve inches behind it." - Ansel Adams
  3. #23
    Bethlehem
    Thanked: 4231
    Thanks, will do that. Just to recap (I'm VERY stupid with these things!!)
    1) Drain engine oil
    2) Put fresh oil
    3) Spray penetrating oil into spark holes
    4) Leave 3 days
    5) Drool
    6) Put new plugs and try starting her up
    If for some reason I do'nt get the correct spec oil for the 2,5 Pinz on the Net, what is a "safe allround" grade and make of oil??
    I just wanna get her started (or not) first, and then I'll hand her over to Oom Gys, our resident older car mechanic.
    Thanks again
    2008 Mercedes Benz CL 500........................"Bullet"
    2006 Mercedes Benz C 180K........................"Sussie"[/COLOR]
  4. #24
    Feb 2015
    Noordhoek, Cape Town
    Thanked: 2451
    1) Drain engine oil
    2) Put fresh oil
    4) Leave 3 days
    5) Drool
    Thanks again
    Do NOT start her up! Turn the engin without the plugs. Read the posts regarding this again! Post 21 NB!
  5. #25
    Bethlehem
    Thanked: 4231
    Some more info: The Red Highlight sounds interesting, I'd have thought that this may lack low-down grunt.8)
    Pinzgauer capabilities[edit]
    The Pinzgauer is a highly accomplished off-road vehicle. Its capabilities, in some operational scenarios, are better than that of the Humvee and the Land Rover Defender.
    45 approach and departure angles
    100% slope, or until tyres lose traction
    700 millimetres (27.6 in) fording depth
    Can climb down a 360 millimetres (14.2 in) wall
    43.5 side-slope
    1000/1500 kg of payload (44/66)
    335 millimetres (13.2 in) of clearance (lowest point when fully loaded)
    top speed (44): 110 kilometres per hour (68 mph); (66): 100 kilometres per hour (62 mph)
    Full engine power available at 4 kilometres per hour (2 mph)
    M body type carries 10 people (44), 14 people (66)
  6. #26
    Dec 2014
    Thanked: 1787
    Lovely vehicles, those. I saw one in Bellville a few months back, on CL plates.
  7. #27
    May 2008
    Thanked: 303
    You will be mightily surprised, that is an offroad monster.
    Replace the fluids, filters etc, make sure no surprise new leaks.
    Also remember to turn engine without plugs initially,
    Then, when confirmed loose, spin without the plugs
    Then only, fit plugs and try to fire up...
    Flip
    Flip
    Member: 4x4 Action Group - GP0026 & Suzuki4x4GP
    Awesome: Suzuki Jimny;
  8. #28
    Apr 2015
    Thanked: 61
    Quote Originally Posted by Flipside View Post
    Die oupa van die Unimog en die G-Wagon...
    Lieflike voertuig
    Flip
    Nie heeltemal waar nie. Unimog het in 1946 begin en die Puch Haflinger wat Steyr Puch se eerste 4x4 was eers in 1959. Die Mog is dus die Puch se pa.
    JK CRD
    Willys CJ2a
    Yamaha YZ250
  9. #29
    Thanked: 59
    Default Re: Restoring my 1971 Pinzgauer 710 M - Questions/Advise, Please
    Follow the process as many have stated to start it but also check that you don't have any fuel leaks, specifically out the carb - old man nearly lost one of the Alfas in his collection that had been standing the other day due to a carb leaking fuel. Thankfully he had a big fire extinguisher in the workshop.
    '99 Cherokee (XJ) 4.0 @ 143000km
    "Frankenstein" 5" lift | Nomad Bumpers | Safari Snorkel | Gorman rocksliders | Khumo 31x10.5x15 | Jerry can holders | 29Mhz Radio | Custom roof rack | Dual Battery | ARB onboard compressor
  10. #30
    Langs die rivier, op n berg
    Thanked: 2866
    As jy verkoop, is ek eerste in ry....
    Soos ek dit het kan jy pre 2001 nog LHD registreer. En in sekere gevalle dink ek nog tot 2004...
  11. #31
    Jun 2012
    Pretoria East
    Thanked: 278
    Oil, filter and plugs are not the biggest issue in my mind initially (as long as it has oil and there is no water in the oil). Your biggest concerns are (1) old petrol which you don't want gumming up your carbs and (2) a dry water pump seal and bearing.
    Drain all the petrol and dispose thereof. Willys workshop manual suggests adding a litre or so of acetone to 20l of petrol to dissolve the old petrol. Use, don't use it.
    Secondly, get water and a lubricant in the radiator. For me, Bar's leaks has really worked to soften the seals. One bottle only though.
    Then turn over the engine by hand with some penetrant in the plug holes (a bit of atf works too) and listen for noises. Remember, your engine only stood for a year, so 3 days' oiling seems unnecessary since this is what you do to an engine that has stood for many years.
    Now turn the engine with the starter (remove coil wire beforehand).until you have oil pressure (get some oil everywhere).
    Reconnect coil wire and go for the start. Once it starts, runs and has warmed up (cleaning the engine a bit and dumping it in the old oil filter), then drain the oil and replace the filter. Plugs are, if still decent, your last worry and can be reused.
    Sent from my SM-N915F using Tapatalk
  12. #32
    Thanked: 601
    Reenen as jy hom nie vat is ek 2e! Hehehe. Lekker speel Petri!
    Pieter
  13. #33
    Dec 2014
    Thanked: 1787
    Quote Originally Posted by locklaw View Post
    What he said is good, IMO.
  14. #34
    Thanked: 12882
    I had an Essex V6 rust up solid on me within 3 months due to a small leak in one cylinder.
    Any moisture in that sump could have caused havoc.
    I like to err on the side of caution.
    Use it, or don't, it was just free advice.
  15. #35
    Jun 2012
    Pretoria East
    Thanked: 278
    Understood and one can always be very cautious, but then when turning by hand you would have felt that motor being locked up or making noises. The small leak was invariably water so this you would have seen either in the oil or spurting from the open plug when the engine is turned.
    Either way, Petri is the man who gets to decide what he deems sufficient.
    Sent from my SM-G925F using Tapatalk
  16. #36
    Robertson/ Larissa, Greece
    Thanked: 3086
    Jelo, mentioning a Ford V6 in the same thread as some of Europe's finest is sacrilege!
  17. #37
    Thanked: 12882
    indeed
    I apologise
    I was younger and stupider when I had one
    perhaps little has changed except my age
  18. #38
    Bethlehem
    Thanked: 4231
    The Pinz arrived on Friday, VERY nice, I was pleasantly surprised to find it in better nick than even the pics suggested. Very complete, it even has the full sets of canvas tops to turn it into a pickup/bimini top/etc etc.
    The seats are like new, as are the back benches. Mileage is a true-looking 41606 km (Yes, 41606). It has a metal "military style" cooler box, lined with foam, behind the driver at the back, and 2 extra metal boxes for storing stuff next to it. VERY cool stuff!!
    I tried to change the LF flat tyre this afternoon, using a HL jack, and almost killed myself when the jack tilted over. Anyway.
    I cleaned out the interior, chucked the mattress/spade/axe/HL jack/bottle jack and a tonne of other goodies out the back, it looks even better.
    Sprayed Q10 into the plug holes as best I could - the engine is a flat 4, so it's difficult to get the Q10 in.
    VERY strange vehicle.....the dash has this 12 little lights, I guess they're some fuse box thing. Difflock levers all feel 110% on the hydraulics, as does the gear lever, the clutch feels fine, brake pedal is 100%, and the engine is completely dry. If you take the engine cover off, there's this huge "tunnel" in front of it, between the 2 front seats, where the engine cooling fan sucks in air. VERY VERY over-engineered car this!!
    The engine oil smells and looks great, levels are where they should be.
    But I'm sort of stuck:
    1) The Pinz is supposed to be a 24 Volt, and I found 24v spare globes at the back, so I assume it still is the original 24v system.
    1.1) How do I actually KNOW that it is 24v, and that the owner hasn't changed it to 12v??
    1,2) If 24v, I guess I'll need 2 batteries (there is space for 2 in the battery box)?
    1,3) How do I connect the 2 batteries, like which cable goes where if I want 24 Volts?? In plain language please, I know NOTHING about parallel/series etc etc connections.
    I'd like to get the battery(ies) and give this a swing. Rudi thanks for the advise on disconnecting the plugs first - I'll just swing it and see what happens.
    How do I turn the engine with a spanner....?
    Thanks guys, I'm gonna flood you with questions over the next few weeks. And pics.
  19. #39
    Thanked: 3086
    If 24V connect as follows: first battery's positive to vehicle's pos. then the same battery's neg to the second battery's pos and the second battery's neg to the vehicle's neg.
    Petri, to turn the engine jack up one wheel, put in top gear and turn the wheel by hand. Just make sure its not switched on, it might start!
  20. #40
    Thanked: 281
    Petri to connect 2 12v batteries for 24v place the the 2 next to 1 another with their poles opposite ie the one will have the positive to the front and negative to the rear .The next battery should be front negative and the rear positive .Then you connect a connecting cable between the rear + and - so that leaves you with the front + and - the + one will be towards your starter motor and the - 1 to earth or chassis hope you understand my explanation.
  1. Brakkeduine 4x4 Trail near PE.
    Last Post: 2017/11/13, 07:56 AM
  2. Females
  3. An interesting TJ Jeep Article.
    By Big Hilux in forum Jeep
  4. Another bash at The Rocky Mounatin 4x4 Trail
    Last Post: 2007/02/20, 01:19 PM
  5. Search Engines
    By benhur in forum General 4x4 Discussion
    Last Post: 2006/09/14, 09:42 PM
