Weber Q gas braai
Page 1 of 14 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 20 of 280
    Mar 2016
    Default Weber Q gas braai
    Who has used this gas braai?
    On Amazon they go for $200 but in SA anything from $275+ equivalent...
    That makes it a bit steep for camping braai maybe?
    Aug 2014
    Default Re: Weber Q gas braai
    Quote Originally Posted by Gerhard101 View Post
    I have had my Q200 for close on 10 years.
    I use it close on daily.
    What I like about it is that it's not the typical gas braai.
    I would compare it to a normal Weber running on Charka from a heat perspective. More controlled.
    Absolutely no gas smell whatsoever.
    Only cleaning done so far.
    Burner now getting a bit old. Bought a new one 2 years ago but not fitted yet. Old one still good enough.
    Base and Grid will probably outlast me.
    It also works wonders with a lamb rib on low setting with the lid closed.
    Expensive but will last forever and you will love the part that it's like using a normal Weber from a Heat and convenience perspective.
    I also have a Multibraai Gas unit but it's used more for typical high heat restaurant type of braais.
    Mar 2016
    Thanks for the info.
    I am thinking of the Q1200 as part of my cooking equipment when overlanding.
    Dec 2014
    somerset west
    absolutely recommend this braai. I have the q2200, slightly higher lid than 2000 for roasts. U must look at australian and nz websites for accesories, They have special trays for roasts etc. I have spoken to weber here. They do not import all the accesories that u can get. Also look at aussie videos for cooking tips. Steak comes out a treat
    Mar 2016
    Thanks Dave...
    Will have to go investigate the Q a bit more...
    Sep 2013
    nashville ,Tn ,usa
    Thanked: 49
    Baie handig
    Sent from my LG-LS980 using Tapatalk
    Mar 2016
    Een van my uitdaagings as ek tetug is by die huis is om daai biscuits vd Amerikaners te probeer maak.
    Dankie 100, ek sal een bestel by die huis.
    Senekal
    Thanked: 91
    Het ook 'n Q1200
    Soos gese bykans geen gas smaak of reuk nie
    Maak redelik maklik skoon.... .gebruik verfskraper om onderste braai gedeelte binne skoon te maak
    Moenie sterk skoonmaakmiddels op aluminium tipe allooi gebruik nie
    Q1200 werk met klein gasbotteltjie , gebruik 'n adapter om met cadac tipe gasbottels te werk
    Kamp soms self met myne , effe swaar , dink 'n spesiale krat waarin dit pas sal goed werk vir pak vir kamp
    Maak seker party Makro en ander plekke verkoop soms nog ouer modelle wat nie temperatuur meter het nie en ouer tipe aansteker , nuutste modelle se Temp meter is ovaal
    Die beste gasbraaiertjie wat ek nog gehad het ...........dit is hoekom hy bietjie duur is in vergelyking met ander
    Geniet hom !!!!
    Thanked: 1071
    Is R5500 vir die kleintjie met die termometer nie 'n bietjie rof nie?
    v-town
    Thanked: 32
    Quote Originally Posted by MonkeyPeeler View Post
    Het ook 'n Q1200
    Geniet hom !!!!
    Waar kry jy so Adapter ?
    Thanked: 348
    Quote Originally Posted by 100bedonderd View Post
    Baie handig
    Jy reken?
    Te oordeel aan die deksel van daardie Weber het hy al vele male handig te pas gekom.
    Ek wou nog altyd een van hierdie braaiers he, maar nog nooit geweet of dit werklik die prys werd is nie, maar dit lyk my dis 'n lewenslange belegging.
    Tyd om bietjie daar by takelot te gaan loer...
    Edit: The same just happened again.... The price scared me away, once again!
    http://www.takealot.com/weber-q3000-...y/PLID32784111
    2011 Fortuner 3.0 D-4D 4x4
    2008 Lexus IS250 V6
    Jaco
    Thanked: 1071
    Ek stel belang in die Q 1200. Takealot is R 700 duurder as Tafelberg, met Builders Warehouse wat die duurste is - R 1501 duurder as Tafelberg. Die verskil in pryse is 'n grap!
    Sep 2013
    nashville ,Tn ,usa
    Thanked: 49
    Ek het 2 kleintjies en een groote almal tweedans gekoop .Twee van hulle was elektries wat ek opgebou het na gas
    Seker so $250 in al drie.Een kleintjie bly in die wa
    Thanked: 1071
    Hoe lyk dit met 'n paar resepte en wenke?
    Dec 2014
    somerset west
    If someone could help me with instructions on how to attach a pic, i will send u a photo of mine. I have a portable stand specially for weber q 2000 series. Bought it in NZ and brought it here. The aussie weber website has a good couple of recipes
    Senekal
    Thanked: 91
    Kyk bietjie na Kloppers se pryse , ek het myne paar jaar terug daar gekoop en hulle pryse was die beste , soos Poen se dit is byna ongelooflik dat pryse soveel kan verskil , dalk goedkoper om een te courier
    Die adapter het ek ook by hulle gekoop met regulator aan die een kant vir gasbotel en koper koppelstuk wat aan Weber vir klein gasbotteltjie vas geskroef word
    Kan nie onthou hoeveel braais ek uit die groot Webber gasbotteltjie kon kry nie
    http://www.kloppers.co.za/Search.aspx?q=weber%20q
    Loch Logan Waterfront, Henry Street, Bloemfontein:
    Tel: 051 400 5500
    Email: [email protected]
    Knysna Branch:
    Knysna, Main street
    Tel: 044 302 7800
    George Branch:
    Enterprise Road, industria
    Tel: 044 802 3900
    PE Branch:
    17 Quarter Shopping Centre, 17th Ave, Walmer
    Tel: 041 394 2900
    Thanked: 993
    Ek het die 200 vir kamp en 300 vir huis braai. Die goed is duur maar niks werk beter nie. Ek braai gas en start die vuur om cool te lyk! Tot Apoc gebruik al gas vir braai.
    Training: 4x4, bushmechanics, recovery, defensive, 4x4 trucks
    Angel Construction
    [email protected]
    +27824453301
    Senekal
    Thanked: 91
    Thanked: 1071
    Talking Re: Weber Q gas braai
    From a retired person's perspective the Q 1200 baby Weber makes a lot of sense.
    Bear in mind that we normally braai on Fridays, Saturdays and Sundays, and during the week as well. Now, please help me with my maths.
    1000 peaces of firewood costs R 1100. That is R 1.10 per piece. I use about 15 pieces per braai. 1.10 x 15 = R 16.50 per braai excluding firelighters.
    According to Weber's specifications one should get 45 braais from a 4.5 kg gas bottle or 179 g/h or 25 hours of braaing. Gas sells at around R 20 per kg. That is R 90 for a 4.5 kg refill. At 45 braais that works out to R 90 divided by 45 = R 2 per braai - R 14.50 less expensive than using firewood.
    OK, I have ignored the atmosphere and the standing around a fire throwing beer bottle tops and sigarette stompies into it - one of my pet hates! That in itself is good for my health.
    Just as a matter of interest - professional chefs prefer cooking on gas, so the wood smoke taste argument does not go down with them.
    Thanked: 2180
    I just yesterday looked at the bottom of the range q1000 for the odd times we want to have a midweek steak without waiting for coals etc. Don't need a fancy model. R2999.
    By charlatan in forum Jeep
  2. Weber Braai - Turkey
    By LLTHB in forum Braai, cooking, recipies
    Last Post: 2015/12/21, 09:10 AM
  3. Gas Cooker in Conqueror Comfort Trailer
    By AndrewC in forum Camping, Fridges, Accessories
    Last Post: 2011/08/17, 06:47 AM
  4. Fridge on GAS, not working properly.
    By Hyades in forum Camping, Fridges, Accessories
    Last Post: 2011/01/31, 11:17 AM
  5. Braai
    By Bartho in forum Braai, cooking, recipies
    Last Post: 2010/08/27, 07:15 AM
