Weber Q gas braai - Page 9
Page 9 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 161 to 180 of 280
  1. #161
    Thanked: 1066
    Default Re: Weber Q gas braai
    You need to fit a pipe to the control valve part which is not a regulator, of which the fitting is a standard gas pipe fitting, and then you may want to fit a regulator at the gas bottle end. Below you will find pictures showing the set-up on my two Webers. The Q2000's sits on the gas bottle, wheras the Q1200's regulator sits in-line at the top.
ID:	494243 Click image for larger version.
ID:	494245 Click image for larger version.
  2. The Following 2 Users Say Thank You to Poen For This Useful Post:
  3. #162
    Sep 2013
    nashville ,Tn ,usa
    Thanked: 49
    Ek het n plaat vir myne gesny ,werk naoe lekkaClick image for larger version.
ID:	494310Click image for larger version.
  4. #163
    Jul 2018
    Seebots Distributors
    81 – 1st Avenue, Linden 2195, Johannesbug, Gauteng, RSA
    Tel: 011 888 3050 or 065 995 7159
    Sorted my Weber Q1200 out for me.
    Thank you for the contact, they provided me with all the bits I required for around R150.
  5. #164
    Jul 2018
    Thanks for the advice, I have installed the regulator at the bottles end.
  6. #165
    Sep 2008
    Mine was made up by the local gas shop. The fitting on the bottle side is a generic one, but the fitting on the regulator side is one with the same thread as that of the gas canisters.
    I am battling to get a gas shop that can do the conversion. Please give me details of the one that did it for you. You can SMS me on 0829072308
    Owen
    Owen Shaw
    [email protected]
    Get your priorities correct. It is all a our being in Africa. Too often people get their priorities wrong and the bling becomes all important. If you can do it in an old bakkie I have the utmost respect for you. On a bicycle even better!
  7. #166
    Thanked: 2168
    It is the same as the pipe supplied with the Safari Chef so ask them to look in a box for an example.
    Very much like this.
  8. #167
    Thanked: 1066
    Quote Originally Posted by Tabatwa View Post
    Owen
    These are the guys who helped me with mine. https://www.eddlesgas.co.za/
  9. #168
    Thanked: 348
    I need the opinions of the Q owners. For a family of 4 where this braai will be used at home at least 90% of the time, I guess the 2200 will be the better size more so than the 1200?
    2011 Fortuner 3.0 D-4D 4x4
    2008 Lexus IS250 V6
    Jaco
  10. #169
    Aug 2014
    Thanked: 138
    Quote Originally Posted by JacoE View Post
    It depends, I suppose, on your appetites. As a family of 4 we use the Q1200 without to much issue. Pizza becomes a problem though!
    2014 Toyota Hilux DC 4x4 - Legend 45
    2010 Jeep Wrangler Unlimited - Mountain Edition (Sold...)
  11. #170
    Thanked: 348
    I have my mind made up on the Q2200 with stand, but this is extremely tempting at R2,400
    https://www.takealot.com/weber-q1000...y/PLID32784099
    2008 Lexus IS250 V6
    Jaco
  12. #171
    Aug 2014
    Thanked: 138
    The lack of thermometer on the Q1000 is a big issue and I would fight the urge if I was you.8)
  13. The Following User Says Thank You to JeeperCreepers For This Useful Post:
  14. #172
    Thanked: 348
    Quote Originally Posted by JeeperCreepers View Post
    Was thinking that same thing yes and even the higher lid. Plus I know I want the bit bigger one and I cannot come up with a better solution than the weber custom stand as well that comes with them.
    2008 Lexus IS250 V6
    Jaco
  15. #173
    Feb 2016
    Brackenfell
    The Q2000 is quit a bit larger than the Q1000.
    Then the Q2200 has a higher lid and the thermometer.
    I have a Q1200 with the higher lid and thermometer which definitively is worth the additional cost.
  16. #174
    Aug 2014
    Thanked: 138
    Spot on!
  17. #175
    Mar 2011
    Walker Bay
    Thanked: 1034
    Thermometer is a must!
  18. #176
    Senekal
    Thanked: 91
    For 4 people I will definately choose the Q 2200 ,
    We have the Q1200 , for two of us it is mostly satisfactory , but braaing for four it gets a little bit to small , temperature drops to much with full load when high temerature is needed
    Kloppers always have reasonable prices on the Weber's
  19. The Following User Says Thank You to MonkeyPeeler For This Useful Post:
  20. #177
    Thanked: 348
    Quote Originally Posted by MonkeyPeeler View Post
    The 2200 with stand is currently for R6,000 yes
    2008 Lexus IS250 V6
    Jaco
  21. #178
    Thanked: 348
    https://www.takealot.com/weber-q3000...y/PLID32784111
    R6,000 for me. If only it was removable from the stand. 2200 is still the pick for me I think
    2008 Lexus IS250 V6
    Jaco
  22. #179
    Thanked: 1066
    I have both the Q 1200 and the Q 2200. If it was not used for camping I would only have had the Q 2200, which is too big to cart around. Please stay away from a Q without a thermometer. You will kick yourself later, since you are absolutely limited in what you can do with it. A trivet is a must, and indirect cooking is the way to bake.
  23. #180
    Thanked: 723
    Excuse my ignorance but why is the thermometer a must?
    FJC - Just Cruising
    By charlatan in forum Jeep
  2. Weber Braai - Turkey
    By LLTHB in forum Braai, cooking, recipies
    Last Post: 2015/12/21, 09:10 AM
  3. Gas Cooker in Conqueror Comfort Trailer
    By AndrewC in forum Camping, Fridges, Accessories
    Last Post: 2011/08/17, 06:47 AM
  4. Fridge on GAS, not working properly.
    By Hyades in forum Camping, Fridges, Accessories
    Last Post: 2011/01/31, 11:17 AM
  5. Braai
    By Bartho in forum Braai, cooking, recipies
    Last Post: 2010/08/27, 07:15 AM
