Weber Q gas braai - Page 14
Page 14 of 14 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14
Results 261 to 280 of 280
  1. #261
    Senekal
    Thanked: 91
    Default Re: Weber Q gas braai
    Thanks Andrew
  2. #262
    Jun 2008
    Hillrise, Kempton Park
    Thanked: 757
    This looks very good. Where is this supplier?
    Will be interested in the Q3000.
    Isuzu 300 d-tec
    MB Gwagen G350 Bluetec
    Nissan NP300 2.4 4x4
    BMW R1200GS & GSA
  3. #263
    Thanked: 736
    Alberton, will post prices later.
  4. #264
    Thanked: 736
    So was rather disappointed today. A couple of days ago I went in and bought accessories, spare gas cannsters at R 69.30, drip pans at R 34.30 per 10 etc. Spent R 1 200 on bargains. Was told that everything was 30% off.
    Today I get there and the manager is there and suddenly the discount has dropped to 20%. Anyways I bought my burgundy Q1200 for R 3 439.20 which is still a good deal.
    They have three Q3000's ranging in price (I think based on the stock value at the time), the manager did not want to commit to prices but there is a burgundy one that will probably go for R 7 400 and includes the LED light. A grey one that should go for circa R 6 500 without light and a black one with light for R 7 500.
    They have two electric Q1200 in size.
    There is a black Q1200 that will probably go for R 3 500.
    There is also a Q2200 that may go for R 4 600.
    I really don't know as she was all over the place with her pricing, she want to do the deal direct with the buyer and was reluctant to quote me firm pricing. Bit of a poor attitude.
    I can go in and firm up a price on one if attractive enough.
    The shop is;
    Tafelberg Furnishers
    Cnr Voortrekker and Redruth Street
    Literally 5 minutes from the Voortrekker off ramp.
  5. #265
    Jun 2008
    Thanked: 757
    Thanks Andrew for your effort.
    Pity she is jumping around.
    I will wait for the next one.
    Isuzu 300 d-tec
    BMW R1200GS & GSA
  6. #266
    Thanked: 736
    They are closing the branch, she is shortsighted ........ perhaps that's why they are closing the branch.
  7. #267
    Thanked: 736
    Quote Originally Posted by Toccata (Roelof) View Post
    Any luck with this, Andrew?
    I see Amazon stocks a stainless steel grid, but of course the price and shipping is rough.
    Weber Q2200 Flat Plate V2.pdf
    So Version 1 was about 5mm too small in both directions. I have altered the drawing and am confident that the new drawing is spot on. I would like to have it printed and to overlay the print on the grid to verify 100% so dont use the drawing just yet.
    The questions are;
    1. Do we retain the indents (lifting points) on the side that are used to pick up the grid or do we dispense with these and add two handles to the top of the plate?
    2. How does one retain the oils etc. that will be generated in the frying process or is this no of concern?
    3. What thickness would we want the plate to be?
    4. What material should the plate be made of, I prefer mild steel?
    5. Is there enough interest to do a group buy? If so I can give the .dxf file to a metal fabricator and they will cut this exactly to size.
  8. #268
    Jun 2012
    Thanked: 307
    Andrew,
    For simplicity, I would retain the indents and not bother with adding handles.
    Thickness... probably as thin (light) as possible without warping on heat. Not sure what that would be.
    The oils can drip through into the drip tray IMO.
    Make it happen!
    2018 Mobi Lodge
  9. #269
    Thanked: 736
    I completed the Q1200 template today.
    4mm may well work.
  10. #270
    Jun 2008
    Thanked: 757
    What is the purpose of this steel plate you guys are writing about?
    A cheaper solution with similar results IMHO is the braai mat.
    4mm th is quite heavy and in stainless quite expensive. Steel will rust in good time to take it with on camping I would opt for the braai mat.
    Isuzu 300 d-tec
    BMW R1200GS & GSA
  11. #271
    Jun 2012
    Thanked: 307
    I use and like braai mats. Haven't used it yet on the Q.
    Actually my goal may be different to Andrew's - I just want to get a much lighter grid than the supplied one. Something like this.
    New question:
    The Q2200 comes with an coupler to a 9kg cylinder. What is the best and safest way to also use it with a smaller 3kg cylinder for camping? Something like this?
    I still want to use it at home on the 9kg, so both options must be available. Is there some quick-swop option?
    Make it happen!
    2018 Mobi Lodge
  12. #272
    Jun 2008
    Thanked: 757
    High pressure quick release coupling
    Isuzu 300 d-tec
    BMW R1200GS & GSA
  13. #273
    Thanked: 736
    Johan,
    Couple reasons.
    The flat plate makes a nice stir fry option and in my opinion will also be much cheaper than buying two of the Weber issue plates. This remains to be seen though.
    The second is the same as Roelof. When one requires real portability, substituting the heavy grids for a light weight SS grid makes a significant difference to the total weight of the unit. The only issue I see with this is that one would need to fabricate an angle shield / suitable shield to cover the burners to a) stop fat from dripping directly onto the flames (burner holes) and b) to provide indirect heat to avoid possible burning. The current pattern of the cast iron grid protects the burner to a large degree.
    Finally I wanted the outline to build a spit attachment such that one can use the standard commercially available portable spit arrangement rather than Weber's expensive option. I believe that this is possible but again one must fabricate a protective cover for the burner. So the theory would be to remove the cart iron plates and have the spit shaft protrude through the slots each side of the lid. I use a spit a lot and have gotten too lazy to tend the fire.
    It's nice to play around with stuff like this.
  14. #274
    Jun 2008
    Thanked: 757
    I understand.
    Received a one half Weber plate as a Christmas present and used it once.
    Ok results. A bit of a schlep though to find convenient storage for it in the Commander.
    Now with the braai sheet the braai results are similar and I assume the Weber plate will stay home...
    Isuzu 300 d-tec
    BMW R1200GS & GSA
  15. #275
    Thanked: 736
    Hi,
    So as near as dammit is to swearing I have scale drawings which will suffice as a template for anyone wanting to cut a flat plate, fit an alternate grid etc. This is for both the Q1200 (and Q1000) and the Q2200 (and Q2000). I cannot attach .pdf's in these posts so if you want scale .pdf's to use as templates then please PM me with an email address and I will forward these to you.
    For those who cannot decide between the Q1200 and the Q2200 here is a scale drawing showing the relative size, area and heat capability.
Name:	Q1200 vs Q2200.JPG
  16. #276
    Thanked: 87
    Hi,
    Andrew do you perhaps have drawings for the Q3000?
    Cobus
    Land Cruiser 200 4.6
    Imagine Comfortvan
  17. #277
    Thanked: 736
    Quote Originally Posted by saskia View Post
    I don't as I don't have one in my stable. If I did I would gladly produce drawings for you.
    If you take a couple of measurements we could give it a go. Will cost you R 25 to print at post net, cut it out and fit it then we make the necessary alterations and it should be spot on. You keen to have a go?
  18. #278
    May 2007
    Welgelegen, Cape Town
    Thanked: 136
    Good morning all
    I have a Q2000, of late, when I close the lid, the flames closest to the front all go out, when I lift the lid they burn, close the lid they die, why is that?
    Toyota D4D Legend 45
    Nissan Kingcab 2007 4x4
    Bushlapa Vlooi 652
  19. #279
    May 2007
    Thanked: 136
    I have also noticed that my Q2000 does not have this regulator...i only have the brass part where the gas hose is connected.
    Bushlapa Vlooi 652
  20. #280
    Thanked: 736
    So you have a regulator at the bottle?
    You have a control knob to vary the heat of the flame?
    Your burner tube with all the holes in is clean and all the holes are unobstructed?
    You bought it brand new?
    By charlatan in forum Jeep
  2. Weber Braai - Turkey
    By LLTHB in forum Braai, cooking, recipies
    Last Post: 2015/12/21, 09:10 AM
  3. Gas Cooker in Conqueror Comfort Trailer
    By AndrewC in forum Camping, Fridges, Accessories
    Last Post: 2011/08/17, 06:47 AM
  4. Fridge on GAS, not working properly.
    By Hyades in forum Camping, Fridges, Accessories
    Last Post: 2011/01/31, 11:17 AM
  5. Braai
    By Bartho in forum Braai, cooking, recipies
    Last Post: 2010/08/27, 07:15 AM
