Rebuilding a Defender Series lll Double Cab
Results 1 to 20 of 21
    Oct 2014
    Witbank
    Default Rebuilding a Defender Series lll Double Cab
    I got a deal on a broke down Series 3 Land Rover Defender Double cab for R7500 and just couldn't look the other way. So I set out to build an Overlanding vehicle that I wouldn't feel bad to put through obstacles. I will be posting updates of what I already completed and then as the project comes along
    Oct 2014
    Witbank
    Default Re: Rebuilding a Defender Series lll Double Cab
    So here are a few pics when I received the Landy
ID:	399302   Click image for larger version.
ID:	399303   Click image for larger version.
ID:	399304   Click image for larger version.
    Oct 2014
    Witbank
    I received the Landy with a lot of incomplete parts, random parts on the back, an engine block on the front seat and incomplete diffs
ID:	399310   Click image for larger version.
ID:	399311   Click image for larger version.
    Oct 2014
    Witbank
    After some research, I decided that I will be replacing the old diffs with Land Cruiser diffs. With some patience I managed to get a set of diffs for R15500 including the leaf springs and both brakes being disk brakes
ID:	399313   Click image for larger version.
    Krugersdorp
    Nice one, looking forward to the updates as you progress with this build.
    Oct 2014
    Witbank
    Since the inside looked the worst, I decided that I will start with the chassis and suspension and all the mechanicals as the major priority, as it was also the place where most of the money will be spent. First things first, clean the cruiser diffs and repaint them.
    Oct 2014
    Witbank
    Getting rid of all the old rust...
ID:	399329   Click image for larger version.
ID:	399330   Click image for larger version.
ID:	399331   Click image for larger version.
    Nice project.
    LC axles are a good choice, MUCH stronger than most Series axles.
    Disk brake conversion would have cost around R10k just for the front anyway.
    Good engine choice on the S3 R6 is the Nissan RD28 diesel. There are gearbox adapters available from Giloeng and the engine is reasonably priced from Engines and More.
    The other options are one of Isuzu 4J turbo diesels (4JB1T or 4JG2T): conversion kits are available from the UK. The kits include adapter,engine mounts, clutch kits and spigot bushes.
    Oct 2014
    Witbank
    Diffs and leaf springs finally cleaned an painted
ID:	399335   Click image for larger version.
ID:	399336   Click image for larger version.
    Oct 2014
    Witbank
    Next part I will be doing is the engine bay area. Fixing the steering arms, cleaning the chassis and repainting it and refitting the diffs. Once done, I will post the pics
    Quote Originally Posted by Jaco Speedy Roos View Post
    While you're busy, install an LC power steering box.
    May 2010
    Greenstone
    Sounds like you building a Series into a Land Cruiser.
    Discovery Sport 2.0i D
    Defender 90 LE Puma 2.2TDCI
    Defender 110 DC Td5 (life partners)
    Discovery 1 200 Tdi Auto
    Jun 2012
    Pretoria East
    Very good deal you got there! Congrats!
    Sent from my SM-N915F using Tapatalk
    Dec 2014
    Won't it go backwards on those axles??
    Only if you fit them upside down
    Done that......decided to mod my Cortian bakkie into a Muscle.....got the rear diff wrong and had 1 forward and 4 reverses....
    That was about 30 years ago, I'm a bit wiser now...
    With all due respect, that front grill is a 110, not a Series 3.
    Witbank
    Very much a hybrid if you ask me.
    I don't know of a Series double cab. The wheel arches say Series, as does the windscreen. Body looks like a 109" station wagon. But the bonnet and grill is defender.
    Does the back of the cab look factory or modified afterwards?
    Hein
    Gandalf: '77 Series III 109" SW (He's old, he's grey, he smokes, but on an adventure you want him as companion...)
    HF, VHF, UHF
    Detroit Locker rear, Truetrac LSD front
    Hardened valve seat ULP conversion
    British cut cam shaft
    VW carb conversion, electric fuel pump
    G-Tech Electronic Ignition
    Hankook M/T 235/85/16
    Frodo: '12 Jimny (SWAMBO)
    Stofpad spacer lift and underbody protection
    Platkar (work): '15 Ranger 3.2 AT 4x4 with AluCab
    Jan 2014
    Looks like a 109 R6 Station wagon that got the back cut off
    Hey Guys
    I'm about to get (another) Series 3 Stationwagon, this one an R6....I never knew these came in a doublecab
    Is there a possibility of doing the conversion to a Doublecab FROM the wagon??
    I'm watching this rebuild intently!
    Lets have an update Jaco!!
    '82 Series III Ford 3.0 V6, BMW P/S, Freeflow S/S Side Pipes, AVM Freewheel Hubs, Warn M8000D1 Winch
    Moses of the Taxi Seas
    Ex: Series 111 S/W 2.5 L/R
    Ex: Series 111 S/W 2.5 Chevy
    Ex: Series 111 S/W 2.25 L/R
    Ex: Series 111 109 P/up Ford 3.0 V6
    Ex: 1988 Pajero 2.5D S/W Original
    SWAMBO: Mini Counryman
  1. Defender TD5 Double Cab
    By rssfeed in forum For Sale, Swop & Give-Away
    Last Post: 2015/09/11, 11:40 AM
  2. 2003 Defender TD5 double cab
    Last Post: 2015/08/16, 03:50 PM
  3. Landie Defender 2.8i Double Cab
    Last Post: 2015/07/24, 10:50 AM
  4. Defender Double Cab Sound system
    By Oldtimer in forum Land Rover
    Last Post: 2015/07/16, 01:36 AM
  5. Replies: 2
    Last Post: 2014/08/11, 09:31 PM
