Deep Cycle or High Cycle with Solar - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 42 of 42
  1. #41
    Thanked: 491
    Default Re: Deep Cycle or High Cycle with Solar
    Quote Originally Posted by bokvirsports View Post
    High cycle is not advisable because it cannot handle the regular discharge and recharge cycles and will damage your battery.
    My understanding is also that high cycle batteries are ideal for shallow discharges.
    In a solar application where bad weather can regularly deplete the battery to cut-out depth of charge I think a deep cycle, or better still, lead crystal will have a much longer life span in a camping application.
    You are both correct in a way, but there is a good reason why high cycle is so often recommended.
    If ever you end up in the bundu, and for some reason your deep cycle battery is run down deeply (11V or thereabouts), and you do not have solar or a DC-DC charger, you are in for a nasty surprise. Your food and beer will both be doomed. Your happy holiday is over.
    A depleted deep cycle is a real sod to charge. You can drive for hours with that NL solenoid system or leave the vehicle idling for hours, but that battery only picks up a few Ah's. That is a lesson some of us have learned the hard way, and that is why so many folks recommend high cycle. They do not last as long as the deep cycle, but your fridge will be working and your holiday can continue.
    A lead crystal or AGM battery will also save the day to the same extent, or better, that the deep cycle does.
    Eggie.
    - apology to Edward Langley.
  2. #42
    Gautengeleng
    Thanked: 40
    This morning.
    The fridge worked the whole weekend, never opened, no lights and no inverter. Bakkie was parked in a warehouse.
    By 12:00
    Sent from my iPhone using Tapatalk
    Corne
  1. High Cycle or Deep Cycle for Aux Battery
    By Gerrit Loubser in forum Vehicle & Technical Chat - General
    Last Post: 2015/10/09, 04:05 PM
  2. Jeep Wrangler Check Engine Codes
    By JKUR in forum Jeep
    Last Post: 2014/12/16, 07:45 PM
  3. Deep Cycle or Semi Deep Cycle
    By COTTO in forum Camping, Fridges, Accessories
    Last Post: 2014/11/06, 11:55 AM
  4. It is official: the BEST school in Africa is.....
    By Vrystaat in forum The 4x4 Pub
    Last Post: 2013/08/05, 01:38 PM
  5. Alternator and a deep cycle battery
    By warrenaken in forum Toyota
    Last Post: 2009/08/17, 10:25 PM
