Echo TTT Awning sag
Results 1 to 4 of 4
    Klerksdorp
    Thanked: 64
    Lightbulb Echo TTT Awning sag
    I am sure most people using trailer top tents with awnings have experienced sagging, especially on the corner of the L awning. Dropping the height of the corner tent pole or the two poles next to it (either put them at an angle or use telescopic poles) helps a bit, but in heavy rain it still sags quite a lot, especially if your stand is not level and the drop is not sufficient.
    So I tried to devise a support from the tent corner to the corner pole to lift the awning a bit and it works quite well and decided to share it here for others.
    Made a telescopic pole that can expand over 3m. Added a tip with a hole to fit over corner pole's pin.
    At the other end I used a normal pole tip with a pin and one with a hole on the short pole to connect them at a right angle. the short pole is then fitted to the tent's frame with a 10mm bolt.
    The water now flows to the corner pole and runs off quite fast!
    Any further recommendations welcome!
ID:	397975   Click image for larger version.
ID:	397976   Click image for larger version.
ID:	397977   Click image for larger version.
    2009 Toyota Fortuner 3.0 d-4d 4x2
    Custom off-road trailer with Echo TTT
    Piet Retief
    Default Re: Echo TTT Awning sag
    That's a good idea. The sag when raining is always a problem. Especially if you have to get up in the middle of the night, whilst its raining because your awning has collapsed.
    Klerksdorp
    Thanked: 64
    yes, done that too, but because of storm winds. this will also help for strength in storms, maybe then add a strip of velcro in the middle to go around the pole.
    Jul 2009
    Thanked: 300
    Nice one thanks for sharing. Been thinking of ways to do this nicely.
    Riku
    2011 Echo4 with Blinkgat Nose cone and
  1. 1,35m Tentco TTT op 1,5m ECHO 1 wa?
    By ockert in forum Trailers, Caravans, Towing etc
    Last Post: 2013/04/29, 12:13 PM
  2. Echo Kitchen Awning
    By Jannie Kubu4x4 in forum Trailers, Caravans, Towing etc
    Last Post: 2013/04/27, 09:39 PM
  3. Echo 4 new awning
    By Serf in forum Trailers, Caravans, Towing etc
    Last Post: 2013/03/17, 12:00 PM
  4. Echo 4 u-shape awning wanted
    By Marnitz in forum Trailers, Caravans, Towing etc
    Last Post: 2012/01/25, 08:48 AM
  5. Echo awning and rain! Wat nou?
    By candoza in forum Camping, Fridges, Accessories
    Last Post: 2010/02/04, 01:12 PM
