FJ60 engine transplant - Page 2
Page 2 of 2 FirstFirst 1 2
Results 21 to 24 of 24
  1. #21
    Thanked: 19
    Default Re: FJ60 engine transplant
    Quote Originally Posted by zahd View Post
    Great info guys thanks a ton ... Or a 3 ton
    Marco, I like the sound of that - but has the 3.0 D4D got the muscle to pull this truck in all conditions?
    I assure you it will have more than enough muscle, just compare the kw and nm figures of your 2F against the D4D
    2F
    Power output 101 kW
    Torque output. 271 Nm
    3.0 D4D
    Power output 127 kW
    Torque output. 400 Nm
    Keep in mind you'll probably fit an decent stainless exhaust so you might as well go with some chip or software modification, this can get you very close to 150kw 500nm
    Nothing in the Toyota stabel will give you that power and consumption
    Admin removed
  2. #22
    Thanked: 9721
    Some light reading if the plan is still a diesel conversion:
    http://www.4btswaps.com/forum/forumd...Toyota-Diesels
  3. #23
    Dec 2014
    Thanked: 190
    I've looked at all the conversion options for my FJ62 and decided that the expense just doesn't warrant it. On the advice of some of the fine gentlemen on this forum I sprayed some carb cleaner down it's throat and have a set of extra leads in the cupboard.
    I've also got a powerflow exhaust and branch which sounds fantastic...
    They also suggested ditching the points and getting electronic ignition which is on my to do list. Honestly, as much as I'd like more power and better fuel consumption I'd rather wait and get a good 80 EFI or turbo diesel...
    "I am a hypocrite but i try not to be..."
  4. #24
    Nigel
    Thanked: 2034
    Now you are talking sense.
    Then, as soon as you take to the main road again, put some 2 stroke in the petrol. Those engines are prone to cokeing up the inlet valves. (Carbon on the intale valves and it greatly restricts the gas flow past those valves.)
    But, you want the engine to work hard. Get that carbon hot so it flakes off. Probably at about 300:1.
    3-4hrs of fairly heavy work will def deliver results.
    The alternative is to pull the cyl head and do a full decoke.
    +27 zero eight 2 four 95 9252
  1. How to service your vehicle yourself.
    Last Post: 2015/03/26, 11:43 AM
  2. My Gen1 Pajero Re-build (Di-D engine & more)
    Last Post: 2014/08/24, 08:36 PM
  3. Engineering Fundamentals of the Internal Combustion Engine
    By BlomCo in forum Vehicle & Technical Chat - General
    Last Post: 2014/04/26, 01:30 PM
  4. New Generation 2012 spec Discovery 4
    By Koos Best in forum Land Rover
    Last Post: 2012/08/23, 10:46 PM
  5. Inloop tydperk/Run in period
    By Bogaards in forum Volkswagen
    Last Post: 2011/11/11, 08:11 PM
