I have a safari snorkel on which was fitted from when I bought the vehicle so I cannot really comment on any performance changes with or without it.
Mine was however badly installed and butchered by the land rover mechie that did the job. I then opened everything and made sure all the pipe junctions were sealed. I used almost 4 tubes of silicone in the process of sealing everything.
Personally I prefer the look of the Mantec snorkels and one day I want to change mine for the mantec. I will then also seal it again with another 4 tubes of silicone
But that said, now that it is properly sealed, I have the peace of mind knowing that I can attempt up to 1.5m deep crossings. (If need be, I've been caught unawares and ended up 1.2m deep previously)
Land Rover Defender 90
Almost expedition ready...
Hi Donald I've had both Safari and Mantec snorkels installed. You really cannot feel any difference in performance nor change in fuel consumption.
The only difference is sound, you no longer here the induction sound from the intake, especially on the Safari which points away from the driver. The Mantec you can still here slightly because its sucks all around the 'mushroom' top. The Safari definitely had more wind noise compared to the Mantec which is almost 100% quiet, which suggests its more aerodynamic.
Installation is straight forward, although I need to fix mine like Partyranger mentioned.
Series III 88"
Scout Nomad
[QUOTE=InFront;3169279
I see on the UK and Australian forums they advocate the removal of the impeller and cut the inlet bigger on the air-box.[/QUOTE]
Excactly what I did to mine.
After repairs in the shop always check if all is 100 ok. Only trust yourself!
Some pictures of the airbox with modifications done and holes all sealed up.
Donald Peake
2005, Defender 110 Td5 SW
2012, Defender 110 Puma SW (SWAMBO's)
Some pictures of the prototype fender/intake adaptor.
The size of the air ducting will be 102mm id.
Donald Peake
Have at last received the correct inlet ducking.
Loading the pictures from my doesn't want to work. 😬
Donald Peake
Sent from my iPhone using Tapatalk
Donald Peake
Adaptor fitted in place.
Donald Peake
Nice work Donald, don't know why they don't manufacture something like this in the first place.
Series III 88"
Scout Nomad
Fitted the intake ducking. I must say fitting this 100mm hose is not for the faint hearted.
Donald Peake
Agree I had the same problem, I heard a roaring noise and the open filter box was the problem.
go and nail the dealer.
I had to fit a snorkel because the dust churned up by the front wheel would block my aircleaner in minutes, especially driving in burned veld. Asked the dealer to come to the party but not interested. I suggested they fit snorkels to all Defenders if they can tell they work in dusty conditions. My snorkel fixed that problem but not the other problems I had with my Defenders.
2018 Hilux Dakar fully kitted.
2016 Metalian Parthian
2021 Suzuli Swift 1.2 GLX Swambo's shopping trolley.
Intake ducting fitted. I must say fitting the 102mm hose is not for the faint hearted. It can be done and it looks good.
Donald Peake
