Results 1 to 16 of 16
    Jun 2008
    Default Fortuner aircon trouble
    The aircon on my 6 month old fortuner has packed up. The dealers say that 2 pipes are leaking and will have to be replaced (fortunerately under guarantee). Apparently they have had similar problems with at least 2 other fortuners. Anyone have a similar experience?
    Irene, Centurion
    Thanked: 8
    Default Aircon
    What I am noticing is a slight change in engine tone (almost roughness) when my aircon is on under certain driving conditions. I have repeatedly reported this to dealer, but according to them nothing is wrong.
    Kobus
    2021 Toyota Prado 2.8 VXL
    2007 Toyota Fortuner 3.0 D-4D 4x4
    Conqueror Companion
    Thanked: 5944
    Quote Originally Posted by tjoek View Post
    Yes - I know exactly what your talking about - specially when accelarating hard it sound like there is a different exhaust on the car for a couple of seconds. Apparently it is normal. I quite like the harsher sound, but must admit that it may become annoying on longer trips if it stays like that.
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    083 399 2046
    Irene, Centurion
    Thanked: 8
    Default Noise
    You are the first person to confim similar experience! Makes me feel much better.
    It is very anoying when you tow long distance, on ever uphill it comes and goes. I went to Namibia earlier this year, and it made me go nuts. I am at the point where I am considering selling by Fortuner as result of this.
    Are you sure it is normal? Does not sound healthy to me.
    Kobus
    Conqueror Companion
    Alicedale
    Thanked: 63
    strange its not picked up on the double cabs?
    '21 Hilux 2.8 Auto 4wd
    '20 Fortuner 2.8 Auto 4wd
    ’21 FJ Cruiser
    ‘24 Hilux Ext Cab 4wd
    Default Aircon Sound
    I experience the same sound, always on long distances at constant revs. Comes and goes in 1-2 min. cycles. Sounds pretty normal to me, like a compressor kicking in (aircon?).
    Hilux 2.5 D-4D 4x4 S/C
    Irene, Centurion
    Thanked: 8
    Default Aircon
    Hi B,
    I certainly feel better now that I know others experience the same noise. What I find strange though is that not all Fortuner owners experience the same, and mine is much too prominent not to be noticed.
    Not sure if it can be the aircon compressor, because it only occurs when you encounter an incline at high speed (i.e. 130kph).
    My service manager told me that there are 3 injection stages, and the sound is associated with the 3rd. This does not sound correct to me, as it never happens when the aircon is not on.
    Kobus
    Conqueror Companion
    Kloof, Durban
    Thanked: 417
    Glad in some ways that it isn't only me.
    My FT D4D 4.4 has 7000km on the clock.
    I have been concerned (and embarrased with colleagues in the car) by a very harsh noisy vibration that always seems to kick in whenever under load ...120Km/h accellerating uphill ....
    I first noticed it as it sends a vibration/grinding feeling via the accelerator pedal (at the same time being very noisy) right up my leg.
    To me it definately seems to be the aircon as switching the aircon off causes the noise and vibration to stop immediately. Switching it back on brings it straight back.
    It also comes and goes for differnet periods as something in the engine automatically switches whatever it is off and on.
    If you are cruising / not accelerating hard then it doesn't seem to be an issue.
    I was going to report it at my 10000km service.
    Please let us know if anyone finds a cure for this, it is very frustrating.
    PS: Is it particular to the D4D diesel model or are any of the 4.0 crowd having the same thing ?
    Peter
    Irene, Centurion
    Thanked: 8
    Default Noise
    I have been complaining about this from the time I had the car, but could not get any solution from the dealers thus far.
    See the below quote from a year-old message by me:
    I have a Fortuner 3.0D 4x4 with 2000 km on the clock. This past weekend was the first time that I towed a trailer. I mainly towed in 4th, and encountered a change in engine sound whenever I encountered a slight uphill or when accelerating, typically when RPM exceeds 2600. The engine sounded rough. It would stop when I decellerated. I did not notice any change in fuel consumption or loss in power.
    Is this normal? Anyone out there with similar experience?
    Any advice or comments would be appreciated.
    I suspect that is is only an unlucky few that experience this, because I ask every F owner I bump into, and no one so far confirmed a similar experience. It was only later that I realised it only occurs when the aircon is on.
    Kobus
    Conqueror Companion
    City
    Thanked: 35
    Default Aircon leaking
    I had an aircon issue on my Fortuner 3.0D4D - pipe to rear laking fluid. They replaced it under gurantee. Took 2 visiots and 6 hours of work.
    Seems ok now after all the trouble I went thru. My aircon was leaking the day I picked up my new Fortuner. Where is the quality control Toyota ?
    Irene, Centurion
    Thanked: 8
    Default Aircon
    I took my F in today for its 20,000 km service (with a different dealer I bought it from), and complained about the noise again.
    They just phoned to let me know that 2 of my injectors need replacement. Will be done tomorrow.
    Let's hope this solves the problem. Will report back.
    Kobus
    Conqueror Companion
    Jan 2009
    Mbabane
    I discovered this noise one day (after some 8,000km) when my phone rang and I had to switch off the radio. I studied it and noted that it most evident between 120-130km/h. As a fellow forumite noted it comes in cycles as the compressor swithes on and off. The problem with these noises they are so driver sensitive. Imagine rocking up at Toyota and going for a test drive with their chaps and they say they can't hear it
    Kaapstad
    Thanked: 17
    Hi guys,
    Sorry mods for resurrecting this one.
    I know this an veeeeerryyyyy old thread, but I want to know if someone has found an explanation for this. I experience the same @ +- 130 kph. The aircon compressor switches on and off at close intervals, when on the sound is a low frequnecy droning noise. Only happens at mentioned speed.
    cheers
    Thanked: 8
    Does this AC issue only affect D4D's?
    Thanked: 5944
    Quote Originally Posted by Ginger View Post
    Its not an issue - it is just a change in engine tone when the AC compressor connects.
    083 399 2046
    Bedfordview
    Hi Guys...
    I am glad that I have found this thread...
    A couple of weeks back, my Aircon just stopped blowing old air! So I took it in and The dealer had the problem sorted after having the car there for a week or so...
    I then went on holiday to the Mpumalange where I noticed the same intermittent noise at highway speeds...
    Has anybody found a solution to the problem? Is it the injectors or the aircon??
    ___________________
    Current 4x4's:
    2015 Fortuner EPIC 3.0 D4D 4x4 Auto (Family Bus)
    2003 Jeep Wrangler TJ (Project)
  1. Fortuner Towing with a Hilux or Fortuner
    By Uys in forum Toyota
    Last Post: 2014/10/13, 01:15 PM
  2. New Fortuner questions & comments
    By Marco79 in forum Toyota
    Last Post: 2013/06/09, 09:14 PM
  3. Fortuner aircon problem
    By NickR in forum Toyota
    Last Post: 2011/03/07, 10:07 PM
  4. Replies: 2
    Last Post: 2010/02/23, 06:42 PM
  5. KZTE aircon bearing trouble
    By stalmaat in forum Toyota
    Last Post: 2010/02/15, 05:30 PM
