Windhoek to Gabarone
Results 1 to 4 of 4
    Apr 2015
    Queenstown
    Thanked: 19
    Default Windhoek to Gabarone
    We are travel with a caravan from Windhoek (early April 2016) back home to the Eastern Cape. I have done the Windhoek / Upington / Home leg and was thinking, is there merit in driving via Botswana. I believe the road is good. Your thoughts please (Distance its a few hundred km extra, no big deal)
    Gaborone
    Thanked: 1014
    Default Re: Windhoek to Gabarone
    I see you are desperate.
    Now first the spelling, variation 3 (correct one) is GABORONE - right.
    You would be driving the Trans-Kalahari hi-way which as such is quite boring (flat) but has some merit with the rains passed so it will be full of blossoms.
    I like the WDH-Gobabis-Mamuno part which is quite scenic.
    Mind the wildlife in the Nam side and the cattle / donkeys on the Bots side and don't drive at night.
    Once you reach the Y-junction Ghanzi - Kang it is a matter of eating miles on a flat plate, so nothing spectacular apart from the wide skies and bush land.
    Jwaneng will show you the diamond mine installations in a distance then it becomes a bit more scenic from Kanye, towards Lobatse.
    Easy travel all in all and no hassle with border crossing.
    Right then, an alternative certainly to the known route via Upington.
    Rest stop at Kang is a good option.
    Kalahari Safari
    Nissan Patrol GU TB45
    E39 - 540i for the open roads
    Apr 2011
    Ghanzi, Botswana
    Thanked: 913
    I did Gaborone-Windhoek route in 2004, but that time I was using a car,so it was a bit quick. We left Gaborone at 0600 and we arrived in Windhoek around 1700. We had soo many breaks for pictures, especially after Kang, towards Ghanzi, thats a WMA(Wildlife Management Area), so you could be lucky for some few game viewing, Ostriches,Orynx, Hartebeest etc.
    The road is good all the way, few trucks from Namibia to overtakes, and speed traps in Mabutsane. But like you say, if you are going to Gabz, there is construction going on between Kanye and Moshupa, they are widening the Polokwe Viewpoint, situated about ten kilometres north of Kanye on the Thamaga road, which gives a breathtaking view of the northern valley, particularly at from Kanye.
    _______________________________
    2011
    VW Amarok BIturbo TDI 4Motion
    2019 Land Cruiser 79 4.2 S/C
    Maun Botswana
    Thanked: 439
    No need to go via Gabs, exit through Lobatse.
  1. NamibiŽ - 50 Doendinge
    By Spook in forum Namibia
    Last Post: 2017/12/13, 09:55 AM
  2. Windhoek to JHB
    By Landyluvver in forum Land Rover
    Last Post: 2015/01/21, 09:49 AM
  3. What to see in Namibia
    By 4x4 wanabe in forum Namibia
    Last Post: 2014/01/12, 08:25 PM
  4. Replies: 9
    Last Post: 2013/07/31, 05:55 PM
  5. Windhoek landy
    By RossJ in forum Land Rover
    Last Post: 2010/09/07, 05:56 PM
