Defender raised intake - are the cheaper ones worth it? - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 58 of 58
  1. #41
    May 2010
    Greenstone
    Thanked: 298
    Default Re: Defender raised intake - are the cheaper ones worth it?
    and to stir the pot even more, Pete from BAS recommends that no RAI be fitted.
    From his own measurements on his dyno while developing his remaps, any RAI restricts the air flow and thus leads to a reduction in performance.
    however, because we tend to drive on gravel roads, I would seriously recommend a RAI. If you look at where the original intake is, it is in a prime spot to ingest dust coming off the front wheel.
    BAS advise that for a VNT turbo, I reckon in STD form it won't affect performance.
    Discovery Sport 2.0i D
    Defender 90 LE Puma 2.2TDCI
    Defender 110 DC Td5 (life partners)
    Discovery 1 200 Tdi Auto
  2. #42
    Thanked: 2100
    Guess who got a new toy.... Now to explain to management that this is extremely important to protect engine life blabla
  3. #43
    Fourways Gardens
    Thanked: 574
    Nice! Just in time for the weekend!
    Series III 88"
    Scout Nomad
  4. #44
    Thanked: 2100
    For those that fitted these before - is this angle normal when new so that you slightly bend / tension it straight to the A pillar? Doesn't seem right.
ID:	414948   Click image for larger version.
  5. #45
    Apr 2011
    Thanked: 973
    Can't remember any one of mine being like that but if it "pulls" towards the a-pillar with ease and doesn't look "scew" on the car I would not worry to much about it.
    Both of mine were pretty "straight" out the box....
  6. #46
    Thanked: 2100
    No its quite a pull with what I'd guess lots of tension on the 2 bolts in the pillar. A return trip to 4x4direct in the morning I guess :-(
  7. #47
    Apr 2011
    Thanked: 973
    Then it is definitely not right.
    I remember it being easy to move in and out of the two screws/rivits in the a-pillar and definitely no "force" was needed to get it in position.
    Rather return it.
  8. #48
    Fourways Gardens
    Thanked: 574
    Hmmm...mine was definitely straight
    Series III 88"
    Scout Nomad
  9. #49
    May 2010
    Greenstone
    Thanked: 298
    That's not right, I would also take it back.
  10. #50
    Fourways Gardens
    Thanked: 574
    Hmmm...mine was definitely straight out the box. Ask Debbie from Stone, they've probably sold hundreds
    Series III 88"
    Scout Nomad
  11. The Following User Says Thank You to ClaudeG For This Useful Post:
  12. #51
    Feb 2016
    Stellenbosch/Plett
    Thanked: 53
    That really looks off. I would take it back, or at least ask for some assistance in getting it aligned correctly. It might be a simple fix.
    2009 Land Rover Defender 110 Station Wagon - 12" Fox 2.0 shocks, Ashcroft Lockers Front + Rear, and a few other things
    2012 BMW R1200GS Adventure
  13. #52
    Betty's Bay, South Africa
    Thanked: 297
    HI George
    There is definitely something wrong with the snorkel. The snorkel has to rune up the A- pillar at the same angle and parallel to it as well. If you dont mind the look of the Mantec look-a-like, buy the Puma snorkel as they call it at 4x4 direct. We have had no problems with them . If you need the full installation instructions let me know and I will forward them to you.
    Our website
    Contact us
    Join us on Facebook
    Stone Accessories operates solely as an ONLINE BUSINESS
    1996 Defender 110 300 tdi
    Mantec snorkel
    Bash plate
    Roof racks
    Diff guards
    Corner protector/bumper steps
    Water tank
  14. #53
    Thanked: 2100
    Thanks. Got it replaced yesterday and fitted quickly. Just a mission getting a hand inside the wing for the nuts.
  15. #54
    Feb 2016
    Stellenbosch/Plett
    Thanked: 53
    I thought it was meant to be fitted with Rivnuts?
  16. #55
    Apr 2011
    Thanked: 973
    Quote Originally Posted by kmcoetzer View Post
    Yip, normally
    Was also a wee bit confused?
  17. #56
    Thanked: 2100
    It was me being idiotic. Starting working my hand in there to line the nuts up and then realized it's rivnuts. One of those duh moments where you look around your to make sure nobody saw you.
  18. #57
    Fourways Gardens
    Thanked: 574
    I tossed the rivnuts after pulling one right through the body!
    Used small nuts and bolts by sliding my arm into the wing through the intake cover plate.
    Series III 88"
    Scout Nomad
  19. #58
    Oct 2014
    JHB
    Thanked: 20
    Update: I got lucky and purchased a Genuine LR snorkel off a crashed car!
    No decrease in power or temps that I can see. The snorkel did stop highway wind from forcing itself inside the cabin at the door seals so it has been a big win for me.
    Took it to Landyworx for them to properly install (I cannot drill holes into my car...) and extremely happy with it.
  1. Defender Wheels24 Test
    By JohanJvV in forum Land Rover
    Last Post: 2015/08/07, 09:16 PM
  2. PLEASE PLEASE, don't mention Puma or Defender.
    By Fluffy in forum Land Rover
    Last Post: 2015/01/20, 10:52 AM
  3. What is my Defender 90 (TD5) worth?
    By Apocalypse in forum Land Rover
    Last Post: 2013/02/24, 08:00 AM
  4. Raised Air Intake - Worth It??
    By George1879 in forum Land Rover
    Last Post: 2011/04/12, 01:04 PM
  5. Whats this V8 Defender worth?
    By MikeHenry in forum Land Rover
    Last Post: 2009/08/28, 12:38 PM
