Breakdown thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 43
    Cape Town or Jansenville or missing...
    Thanked: 3060
    Default Breakdown thread
    Please list the vehicle breakdowns you have experienced in your lifetime, along with a short description of the cause (if you know what caused it)
    Just to be clear, a breakdown is when the vehicle leaves you by the side of the road and you are unable to repair it to continue your journey.
    I'll go first:
    1. 1998 Volvo S90, burst heater hose drained all the coolant, low coolant light alerted me and I could switch off immediately before further damage occurred. Technically the car could still drive but it would have overheated very quickly. The AA had to flatbed it to a garage.
    2. 1973 Citroen DS23 Pallas, burst hydraulic pipe leaked all the hydraulic fluid out, causing the suspension to drop. I could still drive it but the belly was scraping on the road. The AA dragged it onto a flatbed, damaging the underside in the process, but there wasn't really any other way.
    3. 2015 Corolla Quest, valve train failure caused by casting fault. The motor just stopped and couldn't restart. The AA flatbedded it to the dealer who accused me of over revving it
    Mar 2014
    Ermelo
    Thanked: 109
    Default Re: Breakdown thread
    And i will be the first sucker with a landy. My donnerse 300tdi blew a headgasket. I still love it
    Four wheels move the body,
    Landys move the soul.
    0614512283
    Current: Discovery 1 V8i
    Next landy, D3 V8 HSE Previous one.D1 300 TDi donkey, D1 V8 Fuel THIEF!!! freelander 1, biggest pos known to man,
    Wilderness
    Thanked: 1072
    Opel Monza- hole in block. Towed 20km home
    Isuzu 2.8 Blew engine up, heat seized. Melted 2 pistons. Towed 300 km home
    Jeep 2.7 GC. Starter packed up. Lowbed to Worcester.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Garsfontein
    Thanked: 503
    Uno Fire 1.1 - Cable from petrol pedal to throttle snapped. Rigged a spanner between the throttle and the alternator that held it at higher revs than idle so I could at least get to second gear, and not have to crawl along at near stall, and then drove to a garage a few km away
    Mar 2014
    Ermelo
    Thanked: 109
    Nissan 1400. Modded the hell out of it. A15 block. Gx head. Side draft webers. 300 cam and all. Revved it past 8000 and the fan went into the radiator. Towed it home. 1km. R600 for new radiator.
    0614512283
    Sep 2011
    Thanked: 26
    Landy had a flat battery at the checkers, 1km from home. Busy maneuvering the landy to be push started and I stripped the steering rod between the steering wheel and box. Flatbed home was quite embarrassing...
    '98 300 TDI "Lady Jane"
    '11 SX4 "Bazooki"
    Gaborone
    Thanked: 959
    Nissan Patrol 4.5GL
    Split engine block after con rod snapped.
    Towed it for 1000 kms then flat bedded it on trailer for another 1500 kms.
    North West Zambia to Gaborone via Lusaka (Thanks again HenriS)
    Edit:
    Ohh ... paid it myself including repair in RSA and return duty for parts into Bots. (unfortunately before TuffStuff offered services this side of the border)
    Kalahari Safari
    Nissan Patrol GU TB45
    E39 - 540i for the open roads
    Thanked: 3060
    I almost forgot about one.
    1994 BMW 325i, on my way from PE to CT, hit a buck just outside Mosselbay late at night doing about 160, the front of the car was quite mangled but after some roadside repairs it seemed driveable again. What I didn't know was that the impact bent a pulley. 10km before CT the pulley decided to seize up with a helluva noise. The AA flatbed took the car to a local garage in Observatory and R2000 later it was running again. Insurance later fixed the body damage.
    Thanked: 426
    1989 BMW 318i (M40 motor) ~80000km. Stripped cambelt on Good Friday 1992 at the bottom of Roeland St after driving down from Pretoria via Hermanus. Could only be repaired the next week (bent exhaust valves), still ran Two Oceans, but Otter Trail hike starting the Monday had to be cancelled. BMW still ran until 1998 when I sold it on 240000km, whereafter friends wife still ran it for several years.
    My other cars were Landy SII, Citroen Club, Peugeot 505, Ford Escourt, BMW 316, Isuzu 250D, Landy 110 V8, and Chrysler Voyager 3.3. None of them ever dropped me (touch wood, still have last two).
    '89 LR 110 V8
    Jan 2015
    Thanked: 40
    1973 VW Beetle
    Coil. Enough said.
    2008 Avanza:
    First week after coming back from the mechanics. Overheating. Suspect the thermostat was faulty. had to tow it with A-frame. Workshop covered the cost at least.
    Bellville
    Thanked: 727
    1. Broke a CV joint on a Golf Bakkie, while passing a bus outside Oudtshoorn. It was funny seeing the speedo climb off the dail when it let go at about 140 km/h in 4th
    2. RooiTjiep seized up due to sludge in the sump blocking the pick-up. Assumption is the mother of all Butterfly-ups After the Forum rebuild, I have covered roughly 60k km and the motor is as sweet as the day it left the factory.
    Everything else was fixable at the road side (including a head gasket replacement on a 2.3 Chevair motor.)
    Jun 2007
    Pietermaritzburg
    Thanked: 138
    1974 Series 2A Land Rover
    Main gearbox shaft snapped.
    Towed it home about 30 KM.
    The one and only time the Landy ever let me down and we did many miles together.
    Gen 4 Pajero GLX 3.2 DiD
    Forum Radio Licence 1037
    Thanked: 7
    Land Rover Defender 130 2.2 Puma - cracked oil cooler resulting in a cracked block and blown top...plus other goodies. In the middel of Zim. Good friends, lots of towing, flatbeds, etc
    VW Golf 1 Shuttle 1.3 - CV joint cage broke. Same car had various fuel issues too. In Bots, and Witbank, RSA.
    '11 Toyota LC 79 4.0 V6 Meano D/C - current
    '12 Defender 130 Puma 2.2 - 2015
    '06 Defender 130 TD5 - K.I.A.
    V51R
    Langs die rivier, op n berg
    Thanked: 2462
    V8 disco 1. Waterpomp opgepak op eerste dag wat ek hom gekoop het. Gelukkig was my buurman agter my in my patfinder, hy het my gaan aflaai toe ek disco gaan koop het.
    Ingesleep, waterpomp vervang. Was maar net die begin van baie baie breakdowns in daardie landy...
    Thanked: 193
    Disco 1 V8 308000km
    Heater pyp het gebars, het dit nie agter gekom tot dit te laat was nie. Hy het die headgasket geblaas. Het verder gery tot in warmbad en weer terug.
    Disco 2 V8 236000 km
    Waterpomp het opgepak oppad terug vanaf Landy fest af. Flatbed het ons kom haal
    Ratkas se clutch packs het gebrand en langs die pad gelos so 4km van die huis af.
    Ratkas gefix (letterlik 16:30 klaargemaak en 17:00 gery) en eerste trip met Landy na ratkas episode oppad na Emperors palace en daar begin die ding net opref in drive. Stop langs die pad. Hy wil nie vorentoe of agtertoe of eers stilstaan in park nie. Alles hardloop deur jou kop want jy het nou net aan daai ding gewerk. Bel n flatbed om te kom haal. By die huis peuter ek hier en daar toe ek agter kom die transfer case het net uit Hi-Range gespring
    2 Weke later ry ek om 'n bumper vir die series te gaan haal by Captain Chaos, toe kom die ratkas se overheat liggie aan. Die main shaft op die transfer case se locknut het afgekom en hy het letterlik deur die anderkant van die casing geboor en gecease. Propshafts afgehaal in die reen en terug gesleep huis toe. Gelukkig het ons n spaar Transfer case gehad so die volgende dag het hy al weer geloop.
    Series 2A V8
    Het gaan staan sonder petrol X2
    Petrolpompie se fuse het geblaas en ek het nie n spare by my gehad nie. 600M van die huis af. Lekker gedraf daai dag.
    Het hom verdrink by Groenkloof. Tegnies nie n break down nie. Hy het gevrek in die water en soos enige ding wat warm is en vining afkoel het hy water deur die olieseels getrek
    2005 Land Rover Discovery 3 V8 (Will allways end up with an V8)
    1967 Land Rover Series 2A 3.5 V8 (The Green Machine)
    196? Land Rover Series 2 V8 100" (The Coiler)
    2007 Subaru Forester XT 2.5T (The Daily)
    Ex.
    1996 Land Rover Discovery 1 Tdi
    1997 Land Rover Discovery 1 V8
    2001 Land Rover Discovery 2 V8
    2006 Land Rover Discovery 3 TDV6
    2007 Land Rover Freelander 2 TD4
    Jhb, Lesotho
    Thanked: 137
    Jaguar 1959 Mk 1 3.4l - ran out of fuel M1 highway. I was a student no money for fuel......
    Jan
    1988 110 CSW V8
    1961 S2 SWB
    Strand
    Thanked: 217
    Nissan Sentra 160GX. Bubble shape. Timing chain se tensioner het gebreek op pad Kroonstad toe van Parys af op n Vrydag middag. Moes Sondag terugry Kaap toe. Gelukkig net die timing chain moes vervang. Niks anders gebreek nie. Dink ons het op die ou end die Dinsdag eers kon ry.
    Thanked: 3060
    No one else had a vehicle break down?
    Come on don't be shy
    Jan 2007
    Thanked: 301
    I've been relatively lucky so far. I'm not complaining about the trifling issues I've had.
    Just in case...
    Thanked: 3060
    I'm trying to gather some data for statistical purposes.
    Like, if we have 100 broken down Toyotas but only 50 Landys, you should get a GWM
  1. East London Event Thread
    By MariusFourie in forum Eastern Cape
    Last Post: 2017/11/13, 01:28 PM
  2. Replies: 19
    Last Post: 2015/12/19, 06:10 PM
  3. Thread size in SFA hilux chassis??
    By Barto in forum Toyota
    Last Post: 2011/08/24, 05:22 AM
