wheel/Lug nut torque specs?
Results 1 to 20 of 21
    Thanked: 218
    Default wheel/Lug nut torque specs?
    What would the torque specs be for a Defender with steel rims?
    The web says 100nm, and there were bulletins going out from land rover saying 170nm
    I'm on 130nm, but I have heard of stories that these rims like to rattle loose..
    also, the alloy rims torque spec will be higher due to the softness( disco 2)??
    Thanked: 8
    Default Re: wheel/Lug nut torque specs?
    Hier is die Rave manual (The workshop manual 3rd Edition with the amendment wrt the wheels torque spec) en ook die Land Rover spec sheet (Released 09/2011)
    The Heavy duty Steel wheel (Wolf Rim with the holes in) I use 170NM as per manual and Never have problems on my 2x HT that the wheels rattle loose
    Edit: Spelling
    Edit : Added pics of the wheels
    Heavy Duty Steel wheel
Name:	heavy duty steel wheel.png
    Standard Steel wheel
Name:	Standard Steel wheel.jpg
Name:	wheel nuts rava manual 300Tdi 3rd Editon - Amendment.JPG
ID:	391567   Click image for larger version.
Name:	Wheel nuts rava manual 300Tdi 3rd Editon.JPG
ID:	391568   Click image for larger version.
Name:	Weheel Nuts 2007 on.jpg
    -Abrie-
    http://www.myjourney.co.za
    1997 Land Rover Defender 110 HT 2.8i (BMW M52)
    2009 Land Rover Defender 110 HT 2.4 TDCi(Puma)
    2010 Land Rover Defender 110 HCPU 2.4 TDCi(Puma)
    Thanked: 218
    cool, thanks!
    Feb 2016
    Thanked: 719
    Odd, my Puma's handbook specifies 133Nm for the wheels, but the workshop manual says 130Nm!?
    Tshwanetoria
    Thanked: 708
    That 3Nm won't really make a difference. Go for the safer option.
    Feb 2016
    Thanked: 719
    I'm assuming tighter/133Nm is the safer option?
    Tshwanetoria
    Thanked: 708
    Jip
    Feb 2016
    Thanked: 719
    I've ordered a set of solid wheel nuts from Auto Excellence (they order from LP4A?) , and also a set of these from the US for my RRS:
    https://www.amazon.com/gp/product/B01N14W0VF/
    Also bought a torque wrench, was on special for R350 at Midas.
    Thanked: 218
    thats a bargain, what make, I paid 3.5k for my Gedore, did it come with the calibration certificate?
    Tshwanetoria
    Thanked: 708
    With that Torque Wrench, you certainly do not have to worry about a few Nm either way
    Feb 2016
    Thanked: 719
    Quote Originally Posted by D-tox View Post
    No, it's an Autocraft brand. The Gedore was R1700 IIRC.
    Thanked: 218
    oh okay cool..
    I have the Gedore 4550, as it goes up to 250nm, my unimog lugs are at 400nm per owners manual, but that is insane..
    https://onlinetoolshop.kiloton.co.za...waAqBIEALw_wcB
    Tshwanetoria
    Thanked: 708
    Good torque wrenches are very expensive - but worth while. And even they don't remain accurate.
    May 2013
    Thanked: 24
    Torque wrenches should have a calibration check every 12 months
    2007 Discovery 3 V8 SE
    2015 Hyundai IX 35 Limited Edition
    Feb 2016
    Thanked: 719
    Quote Originally Posted by mcboss View Post
    Where can one have this done?
    Thanked: 967
    Cheapies work for 3 or 4 years and then give up the ghost. It happened with two of mine and when I complained, the shop owner said to me that that was unfortunately the nature of the cheapies....
    Malcolm van Coller - retired 2013 but remained in Johannesburg (maybe will look at moving south, Robertson or Wellington type of town, once the wife retires)
    Ex 2011 Conqueror Supra II
    Ex 1995 Sani 3.0 V6 Exec
    Nov 2011
    Langebaanweg
    Thanked: 1053
    We have an in-house metrology section and they checked mine once. Maybe you can search for something similar.
    But after that I sommer used our digital torque meter. (Which is calibrated every 6 months)
    I took 3 readings on each setting and printed it out and stuck it onto the wrench.
    As you can see I'm overdue for another check, but if I need it I'll quickly redo it.
ID:	549716   Click image for larger version.
    Thanked: 218
    also... you can torque the wheels correctly, but ever wondered if the Indie torqued the hubs when they replaced the discs,were the calipers torqued etc, were new bolts used where stretch bolts are required, or even torque to yield bolts ..
    so paranoia can get you going ... my discs were recently replaced and all 4 wheels were under torque by quite a bit ..
    Cape Town Southern Suburbs
    Thanked: 1095
    To my mind even a uncalibrated but high quality torque wrench is better than nothing, as long as it gets you into the correct ballpark of the required torque for most purposes that's sufficient. Wildly under or over torqued is what gets you into trouble.
    Thanked: 1095
    What about those torque wrenches that are basically a spring beam with a scale indicator, they have no adjustment as far as I can see and should remain reasonably accurate for the life of the wrench, as long as they aren't dropped or otherwise abused?
  1. Wheel nut torque settings
    By Poen in forum Trailers, Caravans, Towing etc
    Last Post: 2014/09/09, 08:22 PM
  2. Engine Torque specs
    By Wrangler66 in forum The 4x4 Pub
    Last Post: 2013/01/11, 08:56 PM
  3. New Generation 2012 spec Discovery 4
    By Koos Best in forum Land Rover
    Last Post: 2012/08/23, 10:46 PM
  4. 3.9 V8i Torque Curve
    By JurgenSteyn in forum Land Rover
    Last Post: 2011/11/11, 06:06 PM
  5. 2.5 Falcon Engine Torque Specs
    By Bullet in forum Land Rover
    Last Post: 2008/04/26, 07:59 AM
