Results 1 to 20 of 28
    Jul 2010
    Pinetown
    Thanked: 2685
    Default White deposit on negative terminal?
    Can the guru's please advise - What is the cause of a white deposit (powder) forming on the negative terminal on a battery?
    This is happening on my auxiliary batteries in the Isuzu.
    Is it a problem or should I just clean it off?
    What can I do to prevent it forming in the first place?
    Does it have any effect on the performance of the electrics?
    Peter Hutchison
    Platkar = Chevy Spark 1.2
    Quote Originally Posted by Peter1949 View Post
    Mix a teaspoon of bicarb with a tablespoon of grease.
    Clean the terminals.
    Smear the muti on and it should not corrode again.
    .... or buy a tube of "No Corrode" or similar.
    Sent by 4e, from my iPad using Forum Runner
    "Two things are infinite. The universe and human stupidity. ..... and I'm not so sure about the universe"
    Albert Einstein
    If you see spelling mistakes in my posts, use as many of the goodies below as required to fix it!
    ABCDEFGHIJKLMNOPQRSTUVWXYZ
    abcdefghijklmnopqrstuvwxyz0123456789
    Jul 2010
    Pinetown
    Thanked: 2685
    Default Re: White deposit on negative terminal?
    Thanks 4e, I was wanting to know the cause and effect though.
    I will certainly clean it off. I like things to be working correctly and properly - that's just me.
    Peter Hutchison
    Gordon's Bay
    Thanked: 4378
    I presume it's a lead acid battery? it's a reaction of the lead with the hydrochloric acid - a tiny amount will make it's way past the seal ESPECIALLY if the terminals are abused (i.e. tightened or loosened with a lot of force)
    um. I forget what it is. probably lead sulphate or sulphite or something like that, I know the reaction releases hydrogen from the sulphuric acid, which can go bang very easily.
    as 4e says.... Bicarb washes it off, and grease prevents it reforming.
    Harties
    Thanked: 673
  6. The Following User Says Thank You to PRA For This Useful Post:
    Jul 2010
    Pinetown
    Thanked: 2685
    Thank you all. Got it.
    Peter Hutchison
    Rangeview Krugersdorp
    Thanked: 1721
    Enos then petroleum jelly
    Ford Figo 2016
    Thanked: 330
    I remember putting a 2 cent coin on the battery .All the acid would collect on the coin .When full of acid just turf the coin and replace with new one
    Jan 2014
    Muldersdrift
    Thanked: 51
    Quote Originally Posted by smarty View Post
    There must be cheaper ways....
    2002 - Defender 110, TD5
    2016 - Duster
  11. The Following User Says Thank You to LR110 For This Useful Post:
    Thanked: 509
    Guys a head scratcher here:
    Resurrecting this post, I have an Optima 48 Ah battery fitted to my gate motor. The gate motor started messing around this morning, indicating battery not fully charged.
    On inspection the battery, the negative (earth) pole was white with powder. I checked the charge voltage, 13.6 V. I disconnected the terminals, the battery showed 12.5 V.
    I did not have any Bicarb around, so I gave the terminal a good wire brush clean up, reconnected but the gate motor still gave the low battery alarm and only worked once. I checked the battery voltage again, still 12.5 V.
    Then I resorted to swapping the electric fence battery (exactly the same make and size battery). Before connecting I checked its voltage, 12.5 V.
    I connected, tested and problem gone! Bamboozles me how that was solved, but so be it. The other battery now connected to the electric fence.
    So why would the negative pole build up with powder, and not the positive, which is normally the case? Bad pole connection?
    Platkar 1: BMW 118 (SWAMBO)
  13. #11
    Thanked: 19358
    You need to do a load test to see how fast the voltage drops as far as I know.
    Jakes Louw
  14. The Following User Says Thank You to jelo For This Useful Post:
  15. #12
    Jan 2020
    Thanked: 203
    If the terminal is dry, sometimes corrosion builds up . Clean terminals with bicarb as stated in the thread earlier. Apply grease or Q20 and make sure the lug is also clean cut off and crimp new lug onto it and reconnect. M2cw
  16. The Following User Says Thank You to Wylie E For This Useful Post:
  17. #13
    Wartburg
    Thanked: 2668
    I bet the battery is shot. Check the volt drop of the current battery when you open or close the gate. Now connect the old battery and repeat. Yu will probably see a much bigger volt drop
    Mike Lauterbach
  18. The Following 2 Users Say Thank You to mikeml For This Useful Post:
  19. #14
    Klerksdorp
    Thanked: 20
    I've seen this alot on batteries of especially gate motors. No idea why the negative connection always does that. But DC is a strange thing. When n get callouts for gate motor issues it is usually dead batteries or corrosion on the negative terminal and the batteries dont last long after that
    "Blue Thunder"
    Gert Ferreira
  20. The Following User Says Thank You to BansheeZA For This Useful Post:
  21. #15
    Thanked: 1096
    Spot on.
    I find it every day when gate PCBs miss behave that clients test either with the charger connected and/or on no load. As soon as a load is applied the batteries tend to collapse.
    Normal response is I did test while gate moving and I got a reading above 12V.
  22. #16
    Jan 2019
    Otjiwarongo
    Thanked: 401
    Interesting read on Battery terminal corrosion.
    https://www.caringlyyours.com/corros...tery-terminal/
    Jörg Reddig
    1995 Discovery V8 ( Thor intake system , controlled by Spitronics Mercury 2)
    Land Rover 3.9 V8 " Defender 90 " Under Construction
    2021 Hilux Legend D/CAB ( Company Vehicle)
  23. The Following 2 Users Say Thank You to JWR For This Useful Post:
  24. #17
    Thanked: 1192
    Pete I dont know what the cause is but I used to pour Hot water on the terminal which sorted it for months after
  25. #18
    Donkerhoek, Pretoria
    Thanked: 26
    Without reading any of the links, my cruiser has a short somewhere and the battery cakes up in no time at all, never had this problem before the short.
    *** Removed ***
  26. #19
    Centurion, Pretoria, SA
    Thanked: 657
    I noticed a build up on the neg terminal on a battery and nothing on positive. I also noticed and concluded that the negative terminal was weeping acid / leaking around the negative terminal.
    Peter
    SOMETIMES I WAKE UP GRUMPY,
  27. #20
    Jul 2010
    Pinetown
    Thanked: 2685
    This is a very old thread that has somehow been revitalized.
    However, whatever the cause, I have discovered that a little Coke poured over the terminal clears it quickly, rinse with some window spray or even water and some Q20 or similar seems to hold it at bay for a while.
    It seems that a slightly loose or cracked terminal clamp can also cause this. I don't actually think it is a battery acid leak issue.
    Anyway for the last couple of years I have no longer experienced this problem.
    Peter Hutchison
  1. The white cloud out the exhaust??
    By Lord Farquart in forum Nissan
    Last Post: 2014/08/21, 10:51 AM
  2. Triton White Smoke & Limp (What I learned)
    By Papsak in forum Mitsubishi
    Last Post: 2014/07/21, 10:51 AM
  3. White farmers are not land thieves
    By FLOOI in forum The 4x4 Pub
    Last Post: 2014/07/01, 09:15 PM
  4. White Fortuner
    By Bogaards in forum Toyota
    Last Post: 2014/02/22, 08:17 PM
  5. Zim parks deposit
    By Password1 in forum Zimbabwe
    Last Post: 2011/05/01, 03:09 PM
