Amarok De-CAT - Page 12
Page 12 of 12 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12
Results 221 to 235 of 235
Thread: Amarok De-CAT
  1. #221
    Jan 2008
    Vanderbijlpark
    Thanked: 708
    Default Re: Amarok De-CAT
    Ek het my werk Amarok na Speedy toe gevat en hulle het dit vervang met n gewone pyp. Ek weet een van die Powerflow plekke by julle doen sulke tipe werk.
  2. #222
    JHB
    Thanked: 108
    Good news for the Capetown (or any area infact) is that I have sourced a few pipes to build “floating” decatted/downpipes! I can courier the pipe down, and then you send your original back to me.
    Or like mentioned, who can say no to a visit to Capetown, maybe time for a roadshow!
    2012 Bi Turbo 4Motion, on Bilsteins with a 50mm suspension lift and 20mm body lift. 76mm pipe and software.
  3. The Following User Says Thank You to JohnBoy For This Useful Post:
  4. #223
    Jun 2015
    Umhlanga
    I had my Amarok de catted by John yesterday. We were driving from Umhlanga to Kruger Park and diverted to Joburg with the de cat as one of the main reasons.
    This should be a “must do” for all Amarok owners!
    Even though my Amarok (2016) is still under warranty I would have no hesitation in recommending it. I noticed a difference immediately. The engine feels more lively/willing and the auto box more responsive. The Amarok smile on your face will be a bit wider!
    Expert workmanship at at no expense, with a chance to chat to an Amarok specialist.
    Thanks John!
    Amarok 2016 Auto
    Seikel Snorkel
    Iron Man suspension
    RSI Signature Canopy
    Eezi Awn Roof racks and Awning
    Howling Moon RTT and Annex
    Stofpad Bashplate
  5. The Following User Says Thank You to BAT737 For This Useful Post:
  6. #224
    Apr 2015
    Witsand
    Ek het onlangs my 2015 132kw 4Motion laat re-map deur Force Maps in Kaapstad. Noise Boys in Kuilsrivier het my aanvanklik R560 gekwoteer oor foon om 76mm downpipe in te sit.Toe ek daar stop toe vra hulle my skielik R2000. Natuurlik het ek vir hulle gese wat kan hulle met hulle self gaan doen. Op hierdie stadium is ek baie gelukkig met die re-map maar kort nog die de-cat en 76mm downpipe. John wat gaan jy my vra vir 'n 76mm downpipe en dit vir my te koerier Stilbaai toe? Ek stuur my ou pyp vir jou terug.
    PM my jou nr of jy is welkom om my te kontak op 0826671897.
  7. #225
    Oct 2012
    Thanked: 219
    Quote Originally Posted by JohnBoy View Post
    So JohnBoy, there seem to be enough guys interested in your services here in Cape Town. As Willem said, we can all contribute to your fuel bill, or, if you tell us what tools you will need, we can see how we can get that together. I can get you a return air ticket...somebody can set you up with accommodation etc. Stay a week...do some EGRs etc....
    Shall we get a list of interested owners
    1. Snyks
    2.
    3.
    That Mighty Amarok
    Swart Tires wat ek self gekoop het
    Pull over wat my ouma gebrei het
    Vensters waar deur ek kan sien
    Engine voor
    Exhaust agter
  8. #226
    JohnBoy also removed my cat and installed a 76mm DP. Great work!
  9. #227
    Aug 2019
    Amanzimtoti
    Anyone got a number for john boy ..need to decat my rok
  10. #228
    JHB
    Thanked: 108
    Quote Originally Posted by Shaunm194 View Post
    Morning Shaunm194. Pm sent.
  11. The Following User Says Thank You to JohnBoy For This Useful Post:
  12. #229
    Sep 2019
    When I contacted JohnBoy to arrange for the de-cat of my 2011, I happened to also mentioned that I am using a little water and I suspect the EGR to be the culprit.
    The response from JohnBoy was that he would immediately get all the needed items to safely bypass the suspected EGR and at the same time, could perform the de-cat.
    Both projects took him under two hours with amazing workmanship. He's a wealth of Amarok knowledge to soak up too!
    I am no longer stressed about the fallout from a cracked EGR and now have slightly more "whistling" Amarok with a little more Pep.
    Thanks again JohnBoy.
Name:	EXH Before.jpg
ID:	541627Click image for larger version.
ID:	541624Click image for larger version.
ID:	541625Click image for larger version.
ID:	541626Click image for larger version.
Name:	EXH After.jpg
  13. The Following 2 Users Say Thank You to DustySprocket For This Useful Post:
  14. #230
    Jan 2010
    Petoorstown
    Thanked: 46
    I forgot when i were at JohnBoy to ask if he could before closing my CAT box weld in a straight pipe inside the CAT space..still wonder if it will make any difference..8)
    Mine a bit more noisier engine wise as if the pipe blow out somewhere at the front.
    2018 VW Amarok V6 TDi
    2015 VW Touareg V8 TDi 8) Still learning..
  15. #231
    Apr 2019
    Ruimsig
    @johnboy .... please send me your details
  16. #232
    Jul 2017
    Quote Originally Posted by DustySprocket View Post
Name:	EXH After.jpg
    Was the EGR cooler bypassed as well as the EGR valve itself?
  17. #233
    Thanked: 11
    Thank you so much John! My Rok is driving so much more effortlessly through the rpms with a lot less turbo lag.
    Will log the performance stats to show the difference in performance, before and after.
    Currently my Rok is on 160k and it has increased avg EGT's by 5%, up to 45 degrees with a drop in performace, before fitting the downpipe. This has improved a lot, just to get the numbers now!
ID:	545070Click image for larger version.
    2014 AutoAmaRock
    Pirelli Scorpion ATR 265/70 R17
  18. #234
    Oct 2019
    Standerton
    Can I also have his number, Want/Need to do mine too please.
  19. #235
    Thanked: 831
    I did my cat removal and EGR blank at Johns place on Monday evening. He is a fantastic bloke. Proper redneck who has bikes, lathes and pretty much every tool you can think of in his garage, and all this inside a complex in Greenstone. I was very impressed with his Tig Skills. Mine are rubbish.
    I must say my cat was not looking too bad which was unexpected after 280k km. The front face was a bit gungy, but the rear surface was pretty clean and uncoloured. I am not sure if this is down to my slow driving style, or trying to exclusively use 10ppm diesel? Either way it was not as bad as I was expecting.
    I have not noticed a huge difference in performance, but I usually change gears around 2000rpm, so not really pushing it hard. This weekend or next I will hook up the boat and then it will have to work hard so may show more difference. If you are getting anything done by him, you should also check out the intake mods he has done and he is busy with a snorkel made from Stainless as well. He also has a stainless catch can under construction.
    All very cool fabrication in my view and a very nice guy.
  1. 2016 Hilux vs Amarok
    By Boston in forum Volkswagen
    Last Post: 2016/06/16, 07:42 PM
  2. Amarok D cat, EGR blank and Software upgrade
    By Flanjet in forum Volkswagen
    Last Post: 2015/12/10, 08:22 AM
  3. Amarok 4x4 Day
    By Trebla in forum Volkswagen
    Last Post: 2014/10/27, 06:43 PM
  4. Ultimate T6 vs Amarok Real Life
    By Bergh in forum Volkswagen
    Last Post: 2014/08/17, 12:08 PM
  5. Ultimate T6 vs Amarok Real Life
    By Bergh in forum Ford & Mazda
    Last Post: 2014/08/01, 06:48 PM
