Amarok De-CAT - Page 6
Page 6 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 101 to 120 of 232
Thread: Amarok De-CAT
  1. #101
    Jan 2016
    Boksburg
    Thanked: 128
    Default Re: Amarok De-CAT
    Quote Originally Posted by JohnBoy View Post
    I finally got round to finishing my 76mm exhaust on the Amarok. When I got half way (just passed the transfer case), i took it for a drive to see if the sound was too harsh. Well, it was a bit much, and it resonated in the cab at higher speeds.
    I decided to put a freeflow silencer in the rear section whilst finishing it off.
    It is now dead quiet, can hardly tell the difference between standard and 76mm free flow.
    Cost wise it has worked out less than R1000 cheaper doing it myself than it would have if I took it to Viper Exhausts.
    Space is a bit tight down there, but with my 20mm body lift it all fits in rather well.
    Nice job John!
  2. #102
    Jun 2015
    That's some flippen nice welding!! Looks great John! Job well done!
    Sent from my iPhone using Tapatalk
    2011 VW Amarok BiTDi DC 4Motion
    Seikel Field & Forest Suspension
  3. #103
    Thanked: 41
    Great mods, think you can open a Rok performance centre soon.
    2017 3.2 Ford Ranger Wildtrak D/C
    Old Man Emu lift kit
    Stofpad Box rocksliders
    Aline Dagger
    BFG KO2 285-75-16
    Stanium aluminium canopy with some goodies and stuff inside
    and loads of attitude
  4. #104
    Sep 2013
    Thanked: 16
    Love it !
  5. #105
    JHB
    Thanked: 108
    Thanks guys.
    2012 Bi Turbo 4Motion, on Bilsteins with a 50mm suspension lift and 20mm body lift. 76mm pipe and software.
  6. #106
    Amorosa
    Thanked: 355
    Has anyone tested/checked if removing of the CAT makes a difference in terms of fuel consumption/power when towing?
    Would be nice if I can improve the fuel consumption a bit when towing. Currently is between 7 and 7.5 km/l for me.
    Bush Lapa Miskruier 586
  7. #107
    Vanderbijlpark
    Thanked: 703
    Quote Originally Posted by Bogaards View Post
    Ek het my werk Amarok se cat uitgehaal. Dis die 90kw.
    Geen verskil in brandstof verbruik, maar throttle response is baie beter, en hy begin vroeer boost.
  8. #108
    Super nice
  9. #109
    Addo
    Ek het my Cat ook laat uithaal vir R350. Nou is my brandstof verbruik effens hoer want ek houbvd Turbo fluit geluid dde01dde01dde01. As ek hom normaal ry is die verbruik maar die selfde dink ek, maar hy is defnitief meer 'responsive' binne sy 'power band'.
  10. #110
    Sep 2013
    Thanked: 16
    Quote Originally Posted by jdhvisser View Post
    Waar het jy dit gedoen? Ek neem aan in PE?
  11. #111
    Apr 2014
    Thanked: 17
    Very nice. I will have to come around and check it out some time.
    Mike
  12. #112
    Addo
    Hi,
    Had it done in Uitenhage, took the guy 2-3 hours. It is a very neat job
  13. #113
    Addo
    Default Amarok De-CAT
    As jy die nommer soek pm my.
  14. #114
    Dec 2010
    Kroonstad
    Is dit nie 'n opsie om net CAT se inhoud te verwyder nie? Dan is dit nie opsigtelik vir waarborg doeleindes.
    Sent from my "iPhone 6 Plus" using Tapatalk
  15. #115
    Vanderbijlpark
    Thanked: 703
    Quote Originally Posted by Hellish Handler View Post
    Dis wat Johnboy doen met die Amarok.
    Sent from my HTC One_M8 using Tapatalk
  16. #116
    Jan 2009
    Potchefstroom
    Thanked: 186
    Johnboy - have you ever done a 2.0 Caddy de-cat? I have the 103kW DSG and it went into limp mode once or twice already, showing the cat icon on the dash. I would also consider doing the 76mm pipe all the way through.
  17. #117
    Vanderbijlpark
    Thanked: 703
    Quote Originally Posted by Sias View Post
    I don't know Potch, but surely there is a reputable exhaust shop that can fit a down pipe for you.
    I am going the 76mm exhaust route on the Amarok. A local shop is going to fit a ready made De Graaf system for me. Maybe they make a similiar setup for the Caddy.
  18. #118
    Jan 2009
    Potchefstroom
    Thanked: 186
    Clubbie - I think the Caddy has a DPF and I don't really trust these "reputable" shops! It looks like Johnboy knows his way around a spanner and a welding machine and a VW.
  19. #119
    Vanderbijlpark
    Thanked: 703
    Ah ok.
    Thing is, I am in the motor industry myself, so lucky I know who to trust. And the guy doing my work is a real petrol head and has a performance shop himself.
    In your case, John is the man to go to. I have seen his work, and it is great.
  20. #120
    Jan 2009
    Potchefstroom
    Thanked: 186
    This is what it looks like at the back of the motor. That thing is the size of a small planet...
  1. 2016 Hilux vs Amarok
    By Boston in forum Volkswagen
    Last Post: 2016/06/16, 07:42 PM
  2. Amarok D cat, EGR blank and Software upgrade
    By Flanjet in forum Volkswagen
    Last Post: 2015/12/10, 08:22 AM
  3. Amarok 4x4 Day
    By Trebla in forum Volkswagen
    Last Post: 2014/10/27, 06:43 PM
  4. Ultimate T6 vs Amarok Real Life
    By Bergh in forum Volkswagen
    Last Post: 2014/08/17, 12:08 PM
  5. Ultimate T6 vs Amarok Real Life
    By Bergh in forum Ford & Mazda
    Last Post: 2014/08/01, 06:48 PM
