Results 1 to 8 of 8
    Apr 2011
    Thanked: 243
    Angry My Colt thinks it's a Brit
    Hi all Mitsu Fans!
    My Colt has developed a nasty oil leak - seems like over night. It's leaking from the transfer case where the prop shaft comes out.
    I have replaced the rear transfer case seal... twice! (first time I thought I might have damaged the seal - 2nd time I was extra careful, even added a bit of sealant)
    3rd time my mechie checked it out, found nothing wrong, knipped the seal spring to make it shorter and seal more tightly - still leaking
    It's getting really annoying - my friends don't allow me to park at their place anymore...
    My theories:
    1) I fitted remanufactured gearbox mountings, the rubber seems quite soft and they put extra stress relief holes in the rubber. Now there is quite a bit of left-right movement if I wiggle the transfer box by hand (the transfer case anti-roll mounting is not installed on my Colt). This causes noticeable in and out movement of the prop shaft as the transfer case moves side to side. I think this might put extra strain on the oil seal...?!
    2) There is a bushing inside the rear part of the transfer case housing which captures the prop shaft end. There is slight but noticeable play (up-down-left-right) if I move the prop shaft end (yoke - i think it's called) around in the transfer case - nothing alarming according to my mechie. This movement could be so much (or at least on the threshold) that the oil seal cannot get a tight enough "grip" on the yoke and there's the leak.
    Any thoughts or experience from anyone with a similar issue?
    Thanks!
    '14 Isuzu KB300 4x4
    '12 FJ Cruiser
    SOLD: '99 Defender 90 TD5
    SOLD: '02 Mitsu Colt V6 4x4
    SOLD: '97 Mitsu Pajero V6 GDi SWB
    SOLD: '08 Audi A5 3.2 Quattro
    SOLD: '07 Audi A4 2.0 TDI
    SOLD: '04 Mazda RX-8
    Orkney
    Thanked: 33
    Default Re: My Colt thinks it's a Brit
    I believe your theories are right,
    That movement is not good for that seal...
    2006 Colt 3000i V6 D/C 4X4
    2013 Nissan Navara V9X 3.0 V6 diesel D/C 4X4
    2018 Hyundai Creta 1.6
    2008 Gypsey Romany
    2009 Explorer
    Thanked: 115
    Your theory no 2 is spot on. The slight movement on the splines is enough to allow oil seepage. I have exactly the same problem on the Triton front diff sideshaft.
    Your mountings will not effect the oil seal at all unless it put a load on the shaft by exceeding the universal joint's working angles. Highly unlikely scenario.
    Triton DC, Jimny and K1200GT scooter.
    pretoria
    Thanked: 14
    check the gear levers dust covers, had the same problem replaced the oil seal 3 times, i decided there must something else wrong, removed the plastic covers around the hand brake etc, and found that one dust cover was torn, repaired the dust cover, and oil leak gone.
    John Joubert
    Old Wheeler
    Apr 2011
    Thanked: 243
    Thanks for the input gents!
    Looks like I'll have the transfer case housing re-sleeved then. My mechie told me that's what he had done on his Pajero, still waiting for results.
    Watch this space
    '14 Isuzu KB300 4x4
    '12 FJ Cruiser
    Apr 2011
    Thanked: 243
    UPDATE:
    So I had the transfer case output housing re-sleeved and the yoke checked and polished, no more play on the shaft inside the housing.... but I still found traces of oil - I just hope it's some spillage from when they assembled everything again. I'm still monitoring.
    Thought inbetween: what are the chances that the yoke will have developed a crack or hole somewhere outside the housing where oil can leak through??
    Happy Friday!!
    '14 Isuzu KB300 4x4
    '12 FJ Cruiser
    Apr 2011
    Thanked: 243
    So it was STILL leaking at the seal...
    More work carried out: remove the prop-shaft again, have it balanced, fitted new centre bearing and mounting, refitted. After 100km test drive there was no oil leak to be detected... holding thumbs....
    Theory: when the centre bearing / mounting gets old, some vibrations (not the good ones) are transferred to the slip yoke in the transfer case which puts stress on the seal. And apparently one does not notice these vibrations in the cab.
    We'll see!
    UPDATE: So far so good. All is still dry and leak free Seems to me the above work has done the trick!
    Cheers!
    '14 Isuzu KB300 4x4
    '12 FJ Cruiser
    Orkney
    Thanked: 33
    That is good news.
    I'm glad you found the problem.
    Please keep us updated...
    2008 Gypsey Romany
    2009 Explorer
  1. Mitsubishi Colt Owners Club SA Facebook Page
    By Eugenevw in forum Mitsubishi
    Last Post: 2015/07/03, 08:45 AM
  2. Colt 2800 Tdi Clubcab diesel usage
    By Eltekon in forum Mitsubishi
    Last Post: 2012/12/11, 07:24 AM
  3. 1997 colt rodeo 3000 V6 4X4
    By Clay in forum Mitsubishi
    Last Post: 2009/12/23, 12:04 PM
  4. Colt Safety
    By rules in forum Mitsubishi
    Last Post: 2009/08/10, 10:57 AM
