270 degree awning on Conqueror
Results 1 to 20 of 23
    Sep 2013
    Ellisras
    Thanked: 73
    Default 270 degree awning on Conqueror
    Anyone thought of putting a eazi-awn bat 270 degree awning on their conqueror trailer?
    I have a conqueror compact 2 and it would be a pleasure to have a awning on the trailer that can be set up in a few minutes instead of the standard L-Shape awning from conqueror that takes quite a bit of time and effort?
    I am aware it wont be so strong and water proof as the orriginal L-Shape but if the weather gets bad you can still always then use the L-Shape instead of the eazi-awn?
    Your suggestions or experiance with this would be appreciated and might save me some school fees
    Jun 2015
    Thanked: 32
    Default Re: 270 degree awning on Conqueror
    We designed our trailer from the beginning to use a 270 degree awning.
    Anything can be made to work. just remember that you need a space, as long as the awning poles to attach it to, which is rigid and above your head.
    Sep 2013
    Ellisras
    Thanked: 73
    I also do have the standard 270 awning from conqueror. Bult like said it would be much easier with a eazi-awn bat 270 on it.
    Then you dont even have to put out poles and pens if the weather allows.
    Jun 2015
    Thanked: 32
    Ja our awning has a 2.6m radius, slightly bigger than the easy awn bat.
    But that said the bat 270 is a very good product. Manta gives a slightly bigger shade and ends square which might suit your needs better.
    Jun 2012
    Klerksdorp
    Thanked: 64
    How would you attach it to the trailer?? I would also like to do this, but trailers with trailer top tents do not have a high enough structure to fit a bat awning.
    2009 Toyota Fortuner 3.0 d-4d 4x2
    Custom off-road trailer with Echo TTT
    Jun 2015
    Thanked: 32
    That is why you sell your trailer and buy a LeBusha Overlander.
    Otherwise, I think you will be able to get away with some hinged struckture that will fold onto the TT when traveling but folds up and locks into position with pins.
    Hell I might even be able to build you one. Will be an interesting project and something there is a need for.
    If you don't want to buy my trailer you can still buy my awning. . .
    Jun 2012
    Klerksdorp
    Thanked: 64
    How do these bat awnings compare to the L shape awnings when it comes to size/coverage area and strength against storms?
    Jun 2015
    Thanked: 32
    They are pretty sturdy, depends more on your tent pens and poles and ropes.
    We have never had an issue with ours and I have had very windy trips.
    Jun 2012
    Klerksdorp
    Thanked: 64
    I quickly looked at the coverage of the eazi-awn bat, it seems like you are going to loose quite a lot of space in the shade compared to an L shape awning. For me that is a bit of an issue since we like to be spoiled with a spacious camp setup ("Dorp")
    Gaborone
    Thanked: 25
    I fitted a bundutec to my metalian trailer. Works awesome as it has 270 at the back and front and i did not loose much shaded area compared to my old fly sheet.
    The traer is too low, so i made a bracket where i collapse the frame to be ontop of the closed tent. It works well.
    I have one or two issues to sort out, but on December i stood in rain and very strong winds.
    Hennie
    Ford Ranger Wildtrak 4x4
    Disclaimer: The views expressed by me in the above thread and replies are based on my personal experience and perceptions, which may be subjected to change from time to time.
    ORRA Call Sign B165
    Jun 2012
    Klerksdorp
    Thanked: 64
    Quote Originally Posted by Smiles View Post
    Pics please??
    Gaborone
    Thanked: 25
    I wanted to add some but cant find it so i will have to take new ones tomorrow.
    Hennie
    ORRA Call Sign B165
    Gaborone
    Thanked: 25
    Ps, the bundutec was also the best price when i shopped around.
    Hennie
    ORRA Call Sign B165
    Sep 2013
    Ellisras
    Thanked: 73
    Hi Hennie,
    Remember those pics please.
    I also thought to make like a adjustable bracket then you can lower and lift the awning to the level you want it when stationary. They idea I have in my mind ''I think it should work perfectly on my trailer set up''.
    And when you get to haevy winds and storms you can still put on the orriginal awning from conqueror.
    The Batt 270 would just be a easy pack up and go and a easy way out for some shade.
    I found it as hard work putting up my L-Shape for one or two nights.
    Gaborone
    Thanked: 25
    Hi guys, i didnt forget, my trailer is just parked in. I will take it out tomorrow and get some photos.
    H
    Hennie
    ORRA Call Sign B165
    Jun 2012
    Klerksdorp
    Thanked: 64
    Dankie Hennie
    Sep 2012
    Canberra
    Thanked: 29
    Quote Originally Posted by konstanddp View Post
    I aw this once
    http://www.expeditionportal.com/foru...nd-Rig!/page23
    It looks like a EasyAwn Type awning that is used as a kitchen awning. It might be in the way when having you morning coffee and while still lying in bed though
    Sep 2012
    Canberra
    Thanked: 29
    Quote Originally Posted by willy_sa View Post
    T
    Would the Hindges from an folding aluminum ladder not work great for that ?
    Gaborone
    Thanked: 25
    Excuse the dirty trailer. I also need to get my tent cover repaired after a recent trip.
    The concept is as follows. The frame is horizontal on top of the tent. I then lift the frame to be vertical. It is kept in position with straps that can be adjusted. I found that if the trailer is not level, you can still adjust the awning. I have two straps on a side, one to keep it vertical and one to prevent it from collapsing/ pulling it down. I can also collapse it past verticle to get it out of the way when setting up my main tent.
    Its not perfect, but works well. I added a pipe to the frame for my main tent poles, I also strap my RV2 to it that I use as a add a room.
ID:	387888   Click image for larger version.
ID:	387889   Click image for larger version.
ID:	387890   Click image for larger version.
    Hennie
    ORRA Call Sign B165
    Jun 2012
    Klerksdorp
    Thanked: 64
    Looks like a great mod! You don't possibly have any pics from a recent camp where it is pitched? How does it compare with the standard awnings?
  1. Conqueror companion extended awning
    By CarloG in forum Trailers, Caravans, Towing etc
    Last Post: 2017/02/26, 02:04 PM
  2. Conqueror Comfort fold out awning
    By Henneri in forum Trailers, Caravans, Towing etc
    Last Post: 2016/08/29, 01:36 PM
  3. 270 degree awning
    By rssfeed in forum For Sale, Swop & Give-Away
    Last Post: 2015/05/28, 06:00 PM
  4. Quick awning for Conqueror Comfort
    By Airmatix in forum Camping, Fridges, Accessories
    Last Post: 2014/10/05, 06:21 AM
  5. Conqueror Conquest Kitchen Awning
    By marsian in forum Camping, Fridges, Accessories
    Last Post: 2011/05/04, 04:01 PM
