Page 2 of 2 FirstFirst 1 2
Results 21 to 30 of 30
  1. #21
    Smile Re: GWM idling problem
    Quote Originally Posted by pierre2013 View Post
    Ek sal nie worry oor die redline nie... dis baie konservatief vir n petrol.
    Maar hulle moet die engine so hoog laat ref, anders is daar net nie genoeg krag nie...
    I do believe mixing electricity and water is how you accelerate death.
    Dit het vir my gevoel asof hy 'n bietjie meer krag het as die revs normal is.
    Dalk verbeel ek my maar net. (All in the mind!)
  2. #22
    Mar 2007
    Thanked: 119
    Default Re: GWM idling problem
    Thre is a place in pretoria city center called Mandarin Spares .
    They sell all the gwm new parts at about 50- 60 % less than the agents.
    Give them a call.
    Company name
    Mandarin Parts Distributors
    Address
    42 Bosman St, The Orchards, 0201, Pretoria, South Africa
    Phone
    012 338 3761
    Fax
    012 325 0929
    - See more at: http://www.yellosa.co.za/company/180....z36gH9Mz.dpuf
    http://www.yellosa.co.za/company/180...s-distributors
    Company name
    Address
    Phone
    012 338 3761
    Fax
    012 325 0929
    - See more at: http://www.yellosa.co.za/company/180...h.z36gH9Mz.dpu
    Gerhardt Olivier
    GWM H5 2.4
    Gwm 2.2 d/cab
    Always carry a knife, in case there is biltong or you need to stab someone in the throat.
  3. #23
    Thanks FLOOI, I will check it out!
  4. #24
    Birch acres
    Thanked: 7
    I got a clucth plate from them and not a days issues from it. Much cheaper than the dealers
  5. #25
    Apr 2016
    Vaal Triangle
    Guys, I desperately need your help please. What would be the reason for the 2.2 MPi 2009 model to idle high and drop intermittendly? It causes the vehcile to flood. The engine light comes on. I've changed the Idle Air Control unit but it still does the same. The GWM Alberton told me it might be the MAP sensor? PLEEEEEEASE help
  6. #26
    Thanked: 1026
    It can not flood, its fuel injection.
    I think you should take your throttle body apart and clean your idle regulator valve.
    Sent from my HUAWEI P7-L10
  7. #27
    Apr 2016
    Vaal Triangle
    Hi Pierre,
    Dit is 'n splinternuwe throttle body wat ek vandag by MPD gekoop het. Sodra ek 'n ent ry dan rev die bakkie iets ergs, sak, rev, sak rev so gaan hy aan tot hy uiteindelik vrek. Ek weet nie meer wat die probleem is nie?
  8. #28
    Apr 2016
    Vaal Triangle
    Hi Pierre,
    sal jy nie asb jou nommer vir my PM nie. Ek sukkel my as af groot asseblief.
  9. #29
    Apr 2016
    Vaal Triangle
    Hi Pierre,
    Sal my my asb jou nommer PM. Ek sukkel my dood en is nou al goed moedeloos.
  10. #30
    Thanked: 1026
    Quote Originally Posted by Mielie82 View Post
    Hi Pierre,
    http://www.4x4community.co.za/forum/...d.php?t=252341
  1. Help: WJ Full Throttle/Load Problem
    By OceanWanderer in forum Jeep
    Last Post: 2012/07/22, 08:15 PM
  2. Ford 2.5tdi problem.
    By DJLSchoemm in forum Ford & Mazda
    Last Post: 2011/04/12, 04:44 PM
  3. 1996 Colt rodeo Idling problem
    By WarrenRS in forum Mitsubishi
    Last Post: 2011/04/05, 05:32 PM
  4. transmission problem
    By the_mog in forum Jeep
    Last Post: 2011/03/07, 10:50 PM
  5. Suzuki SJ410 Idling Problem
    By wclarke in forum Suzuki
    Last Post: 2011/03/04, 08:15 PM
