What have you done with your Isuzu today ? - Page 2
Page 2 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 21 to 40 of 188
  1. #21
    Boksburg
    Thanked: 9
    Default Re: What have you done with your Isuzu today ?
    Fun stuff. Clutch started slipping in Mthatha on Thursday. Nursed it back Friday (1000km no cruise control, 4th gear, very light foot).
    Was busy yesterday, today pulled gearbox to inspect. Agents want R8500 for clutch plate, pressure plate and thrust bearing. Luk kit difficult to find. R6500 for the 3.2 v6 kit, which is also a pull type, but I don't know if it will fit.
    Sent from my SM-G900F using Tapatalk
  2. #22
    Thanked: 13
    I took the Frontier to Wizerd for a dyno run, I dont know if I should be worried or exited, but I am a bit confused.
    SCAN_20160425_135255922.pdf
    According to the Kw graph the max Kw is around 77 and max torque 280
    According to the Nm graph the max Kw is arround 115 and max torque 420
    To give an idea I can Almost keep up with a +- 2000 SWB 3.2 diesel Pajero and a 3.0 D4D Hilux
    Has anyone done their car with similar power specs there?
    I would love to compare figures from that dyno.
    Regards, Erik.
  3. #23
    Jan 2009
    Germiston
    Thanked: 95
    The latter sounds way out. Is this power at the wheels? Factory was 74kw at the flywheel, 240nm. Looks optimistic.
    Sent from my D2005 using Tapatalk
    __________________
    '01 Isuzu Frontier LX 4x4 Diesel8) - For the brown Stuff
    '14 Renault Sandero 900cc Dynamique, small with a big heart
  4. #24
    Thanked: 13
    I dont know, he said the figures were at the wheels, I can beleive that the 77kw and 280 Nm are at the wheels, but definitely not 115 and 420.
    I did a dyno run at GnG Developments last year and got 62kw and 202nm at the wheels.
    I have since increased the boost to 1.1 bar from 0.7/8, adjusted the diesel pump and fitted a 63mm freeflow.
    I should maybe just have went there again, it would probably be better to test on the same machine and settings for a good comparison.
  5. #25
    Jan 2009
    Germiston
    Thanked: 95
    I agree. Do that. 62kw at wheels is pretty much in line with that I saw on other dynos on 280's. My 3.0 does 77kw on wheels. I have yet to find a 280 that can keep up with it. My dads 3.0 does quire a bit more 😉
    __________________
  6. #26
    Thanked: 13
    Sweeper where did you do your dyno run? Also at GnG?
  7. #27
    Jan 2009
    Germiston
    Thanked: 95
    Unichip pta
    __________________
  8. #28
    Oct 2012
    Thanked: 18
    Fitted a roll bar on my 250 dteq.
    Sent from my iPhone using Tapatalk
    Ex:07 Disco 3 TDV6 SE
    2011 Disco 4 SDV6 SE
  9. #29
    Amanzimtoti
    Fitted a nudgebar. Took about me about an hour.
    JP
    Isuzu KB300 D/C 4x4 (KB6)
  10. #30
    Thanked: 20
    looks very good!!
  11. #31
    Thanked: 167
    I done my rear brakes a few weekends ago.
    I also seen my rear diff seals are leaking on the drive shafts.... I hate this diff.
    Sent from my SM-N910F using Tapatalk
    2010 Toyota Fortuner 2 4x4.
    2001 Isuzu KB320 Frontier 4x4.
    2012 Polo GT White with community sticker.
  12. #32
    Jan 2009
    Germiston
    Thanked: 95
    Ai, time to invest in another one. Or better yet. Drop diff at gearmax
    __________________
  13. #33
    Thanked: 167
    Quote Originally Posted by sweeper View Post
    I know... this one is not packing up so.... I'm going to get another diff as this one is not worth fixing to me. It's seen better days.
  14. #34
    Jan 2009
    Germiston
    Thanked: 95
    I need to do my dads rear brakes. Need drums and linings. Will call around tomorrow
    __________________
  15. #35
    Jul 2013
    Westville
    Thanked: 16
    I had the "pleasure" of replacing a wheel cylinder and brake shoes on mine the other day. Everything that could go wrong did.....
    Springs jumping off, pistons popping out of the wheel cylinders, holes that wouldn't line up... Finally managed to get everything where it was supposed to be and then realised that I forgot to connect the handbrake cable!
    Got it all done eventually though! Van got a major service after that and a few upgrades. LED Festoon globes inside as well as an additional cigarette lighter socket in the centre console above the rear glass release button (Fitted it into the square blank)
    Also refitted my original spare wheel carrier bracket. Gave it an overhaul with new machined stainless steel pins, new DU Bushes in the hinges and a nice new set of machined tapered cups where the anti rattle cone rubbers sit (Mine didn't have any) and a new rubber insert by the lock.
    1998 Isuzu Frontier 280 DT 4x4
    Intercooler
    2" lift
  16. #36
    Mar 2007
    Thanked: 719
    Clocked in at home this afternoon.
    The new Isuzu now has 7500km on the odo after 5 weeks
    Johan 8)
    2011 Daihatsu Terios 4x4
  17. #37
    May 2016
    Oudtshoorn
    Co-op PJ
    Sent from my Nexus 7 using Tapatalk
  18. #38
    Mar 2007
    Thanked: 719
    Johan 8)
  19. #39
    Mar 2007
    Thanked: 719
    Had a 60 litre aux fuel tank fitted yesterday - so now I have some serious range ..... 600km in thick sand, and 1200km on gravel and open road
    Also fitted my Eazy Awn side awning.
    Johan 8)
  20. #40
    Cape Town, Plumstead
    Thanked: 148
    Quote Originally Posted by J Snyman View Post
    Johan 8)
    Which aux tank did you fit ? I'm also looking at doing the same.
    Safe Diving - Andy
    2013 Isuzu KB6 300 DC 4X4
    http://www.flickr.com/photos/andrews_underwater_images/
  1. Thank you for ??? today....
    By MariusFourie in forum The 4x4 Pub
    Last Post: 2015/11/28, 09:47 AM
  2. What have you done with your Isuzu today?
    By NeWKleaR in forum Isuzu
    Last Post: 2015/10/11, 11:05 AM
  3. Today only Light bar sale !!!
    By ExtremeLights in forum Commercial Member Adverts
    Last Post: 2015/04/09, 04:48 PM
  4. Vauxhall Frontera vs Isuzu Frontier
    By Chris_cross in forum Isuzu
    Last Post: 2013/08/23, 10:46 PM
  5. Images needed for Isuzu KB bakkies from 1979 to 1995
    By Victor Oscar in forum The 4x4 Pub
    Last Post: 2011/08/15, 03:32 PM
