Discovery 2: TD5 Head Gasket Again? - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 60 of 69
  1. #41
    Cape Town Southern Suburbs
    Thanked: 1134
    Default Re: TD5 Head Gasket Again?
    My Defender's (10P) motor cracked its head 2 months ago. Putting a new head on a block that has done 360 000+ didn't make sense to me. As I need the vehicle for my business, waiting to have it rebuilt would have cost too much in down-time.
    I found a company by the name of LDR Engines. Bad rep on Hello Peter, good rep on Google reviews. Their engines are sourced in the UK and (supposedly) all have less than 100K on. Took the plunge and bought one.
    Complete (15P) motor with Aircon, Alternator, Power steering Pump, Fan, Starter, Flywheel, clutch-plate, pressure-plate, the WORKS, literally plug and play. Cost me R29K with a 3 month guarantee (installed it myself. If they install it at a cost of 5.5K you get a 1 year guarantee).
    Have done just under 10 000 k's with it now and am VERY happy!
    That sounds like a seriously good value, isn't R29k pretty much the price you'd pay for just a new head and fitment?
    Plus you can still sell your old engine for parts with the extra ancillaries and recoup a good few thousand Rand.
  2. #42
    Jan 2018
    Waterfall
    the early TD5 had head dowel issues and the head would eventually shift
    which engine do you have? 10P?
    AFAIK they were not supposed to use silicone or any type of sealant on the head gasket, so the one who did it previously stuffed it up.
    Agreed.. this was before I owned her so I will be watching this repair closely
    Its time...
    1999 Mitsubishi Pajero 3500 GLS 24v V6 GROWING ON ME
    2004 Discovery 2 TD5 Auto 226000km SOLD KINDA MISSED
    2008 Freelander 2.2 SE SOLD MISSED
    2013 BMW F800 GS SOLD MISSED
    2005 FORD RANGER 2.5 TD DOUBLE CAB SOLD
    2016 SPECIALISED CAMBER CARBON COMP 29er
  3. #43
    Thanked: 1288
    Correct. A new ("naked") head would have been about R20K. Add valves, springs, valve stem seals, cotter pins, seating and grinding of valves, etc - plus you only get 12P and up - the 10P had its fuel return running inside the head (That was one of its weak points and also why they were prone to cracking) and 12P's return runs outside, so it would have entailed some modification as well.
    1959 SII 88"
    197? RRC
    2002 Defender Td5 D/C
  4. The Following User Says Thank You to EttiennedK For This Useful Post:
  5. #44
    Dec 2014
    Thanked: 1918
    I bought an AMC 10P head when I did my replacement, and, I had the choice of with or without valves, too. Granted, it is a few years, now.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  6. #45
    Jan 2018
    Waterfall
    Feedback from engineers: Head has no cracks and holding pressure. Exhaust valves on their way out so replacing those and adding a bit more engineering.
    Was wondering if there was anything else worth doing while the head is off?
    Its time...
  7. #46
    Thanked: 1270
    Quote Originally Posted by Ryanie View Post
    Did they check if the fuel rail is holding pressure or just the water jacket?
  8. #47
    Thanked: 14235
    good question, considering a lot of heads fail between the fuel rail channels and the valve galleries I think
  9. #48
    Jan 2018
    Waterfall
    Both and all good
    Its time...
  10. #49
    Thanked: 1270
    If you did not send injectors with they did not test the fuel rail, unless they have their own set of injectors to test with..
    If they don't have the injectors then I'd like to know how the tested the fuel rail..
    Are you sure you're not being given a BS story?
  11. #50
    Jan 2018
    Waterfall
    The repair is being done at a well known Indy and the head removed from the vehicle and stripped and sent away by them. Appreciate the heads up but I have received great service thus far.
    I presume they would have sent the injectors with but will ask to make sure
    Its time...
  12. #51
    Jan 2018
    Waterfall
    The Disco now has a surging problem that they can seem to troubleshoot.
    Need some advice dealing with the mental anguish of almost but not quite there.
    Its time...
  13. #52
    Feb 2012
    Thanked: 64
    Have they not maybe messed up with the Piping on the Turbo waste gate?
    Gary W
  14. #53
    Jan 2018
    Waterfall
    Shes back and pulling like a train and purring like a Persian...
    Its time...
  15. #54
    Thanked: 1134
    What was the problem?
    The pic shows as upside down from my side.
  16. The Following User Says Thank You to Skylark For This Useful Post:
  17. #55
    Jan 2018
    Waterfall
    Fuel regulator was leaking and replaced. Not sure if that was the cause of the surging but she is a different vehicle. Smooth as silk! Happy days. Time to put on some miles. Thanks for all the input.
    Now to test some of Markus' venues in KZN and beyond...
    Its time...
  18. The Following 2 Users Say Thank You to Ryanie For This Useful Post:
  19. #56
    Jan 2018
    Waterfall
    Thanks again
    Attachment 543379
    Its time...
  20. #57
    Feb 2012
    Thanked: 64
    So following up from my pressure in coolant system saga, 3 weeks ago on the way to Alberton the Td5 overheated and was pushing coolant out the cap. (Posted on another thread somewhere.) So this is now the 3 rd head repair due to overheating, well actually 2nd as the 1st job was botched by the Indie that did it. Landy has run for 4 years and 50 000 Km's since last gasket job.
    This time the gasket was definitely gone as even a short trip would have excessive water pressure and bubbles in the coolant.
    1. So the head was removed and it was confirmed head gasket had gone. Head was checked by a reliable engineering firm and it passed the pressure testing as well as no sign of any cracking or warping. Valve guides however were worn and a decision was taken to refurbish the head. (Car has 310000 km's on, so understandable.
    2. While at it, i took the injectors to a mate of mine who works at a very well know Diesel Shop in Randburg to check, and this is where the surprises came in. Injectors tested 100% (35 different test cycles IIRC) and this on a vehicle that has had 3x head gasket repairs done (Botch one included), has overheated 3x times in the last 6 years, and has 310 000 Km's on. They even ran the test 2x and everytime same result. As my mate said, this is a first for him. Told him must be the 2SO So based on this the Injectors were then also cleaned and refurbished and looking pretty damn smart.
    3. Now after a couple of beers and thinking that maybe I should make sure this is a proper job done it was decided, with much bad influence from a friend who I think was just looking for something to do, the engine block removed and will now be "refurbished" as well.
    Things I plan on doing:
    Hone cylinders and fit new STD pistons and rings (Sleeves still have original hone marks in them)
    Have the block face polished to ensure there are no issues.
    New Big end and main bearings
    Replace all gaskets
    The following was inspected and still seem Ok but not sure if it is worth replacing. (Checked and measured according to Hayness Manual)
    Oil pump
    Oil cooler
    Water pump
    What I am wondering is if it is worth re-sleeving instead of just a hone, or rather go over size.
    Gary W
  21. #58
    Thanked: 157
    I would change oil pump, water pump, timing chain as a matter of course. Also do oil cooler if not already done. Use OE.
    Darron John Misplon
    Land Rover Discovery 2 Td5 ES Manual (Loaded)
    BMW F30 320i Sport Auto
    BMW R1200 GS
    'One life-Make a difference"
  22. #59
    Nigel
    Thanked: 2311
    You guys might frown at me, but it works for me.
    I put a very thin sheen of Vicror Rhines silicone gasket sealer on a head gasket. But I repeat. Very thin.
    Works for me.
    Uniglide
    +27 zero eight 2 four 95 9252
  23. #60
    Thanked: 1134
    Works for me.
    On both sides?
  1. VG30 (Sani) Head gasket replacement
    By antvz in forum Nissan
    Last Post: 2016/02/29, 06:35 PM
  2. Pajero head gasket
    By Pierre in forum Mitsubishi
    Last Post: 2014/08/01, 07:34 PM
  3. Discovery 2: D2 Td5 blown head gasket question
    By Bunchat in forum Land Rover
    Last Post: 2013/10/11, 10:16 PM
  4. Colt 2.8tdi leaking oil at head gasket!!
    By Numbnut in forum Mitsubishi
    Last Post: 2012/08/14, 07:05 AM
  5. Discovery 2: Good buy head gasket?
    By RudolfD2 in forum Land Rover
    Last Post: 2010/06/20, 10:39 PM
