2007 Puma cooking floor
Results 1 to 19 of 19
    Ladismith western cape
    Default 2007 Puma cooking floor
    HI Guys
    If I drive my Puma open road the floor starts cooking so bad it burns your feet.
    Please give me your DIY's to solve this problem.
    On my previous Tdi's I stuck , cool room dense sponge, and on the other, house hold aluminium roof sealer.
    The sponge I recon worked a bit better.
    My Puma has rubber type matting and not material matts as my County had.
    Please advise.
    2007 Defender Puma
    1996 Tdi Defender ( Sold )
    2002 GLE Corolla
    Maun
    Thanked: 143
    Remove the CAT and middle silencer this will reduce the heat by 80 %.
  3. The Following 2 Users Say Thank You to Puma 130 ADJ For This Useful Post:
    Thanked: 76
    There was a whole thread about this some time ago
    Of course I cant find it now
    Aug 2014
    Oppi plaas
    Thanked: 862
    Quote Originally Posted by Puma 130 ADJ View Post
    +1
    I only removed the CAT, made a huge difference.
    2017 Amarok Extreme V6
    2014 Jeep Wrangler Rubicon
    2012 LR Puma 2.2
    2012 LR Puma 2.2 D/c
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
    Thanks guys.
    Never thought to remove the CAT.
    I'll give it a go.
    2007 Defender Puma
    2002 GLE Corolla
    Just took a look under her, there is no CAT, only the middle and back box.
    The heat is under the front seats feet floor, if I look under that area, its more the gearbox than exhaust or am I missing something?
    What if I fitted steam pipe lagging around the exhaust pipe?
    This would stop the heat radiating out to the body.
    The pipe will however itself become hotter as it will have not have any air cooling.
    Just thinking, this could cause the pipe to become hotter at the engine manifold?
    2007 Defender Puma
    2002 GLE Corolla
    Pta East
    I have the same problem with my puma. The handbrake lever also gets hot as hell too. I'm going to try the removal of cat converter and centre silencer route and give feedback on how effective this was on mine.
    Life's a garden, you just gotto dig it - Joe Dirt
    Sometimes you just gotto keep on keeping on - Joe Dirt
    Life's hard. Its even harder if you're stupid - John Wayne
    1998 Toyota Prado KZTE
    Thanked: 101
    Better to just remove the "honeycomb" inside the cat-housing, thus retaining all the heat shields. Few guys on the forum has complained about a humming sound when a straight pipe was used. I have no silencer boxes in my Puma's exhaust system, no difference in exhaust tone.
    2010 Defender 110 Puma HCPU (Bostrok)
    2015 Mercedes Benz GLA (Swambo's Glam)
    Jan 2010
    Fourways Gardens
    Thanked: 626
    Quote Originally Posted by Bostrok1 View Post
    +100000!
    Just remove the honey comb internals and leave everything else intact. SAME effect except you retain original heat shields and mountings and some rigidity in the pipe which prevents it from rattling on the flex joint and driving you nuts. The straight pipe also gave me a drone. Trust me I learnt the hard way and now busy preparing my second decat as decribed above.
    Look carefully its basically attached to the turbo. It does help, and while the pipes out I will also be wrapping it in exhaust fibre glass tape to further reduce heat transfer (last pic).
ID:	383211   Click image for larger version.
ID:	383212   Click image for larger version.
ID:	383213   Click image for larger version.
    Defender Puma Raw Limited Edition
    Series III 88"
    Scout Nomad
    Chop your own firewood and it will warm you twice
    Springs
    Thanked: 277
    1) you can wrap the front half of exhaust in ceramic heat wrap and tie into place with binding wire (not cable ties)
    2) you can install Dynamat on the floor inside the cab
    3) i've had a couple of Defenders rubberised inside and it help somewhat but over time still builds up heat.
    4) you could also buy offcut carpet and pad the floor
    5) you could also get your local exhaust place to slit a 76mm pipe in the length and use this as a shield above the existing exhaust pipe. place on top of the existing pipe and tack onto existing pipe like an umbrella.
    6) you could also replace the front section of pipe with stainless as stainless is a poor conductor of heat and tends to transfer the heat further back.
  12. #11
    So I see I do have a CAT!!
    Was looking for one that looked like the one that was on my Disco2.
    The position of the Puma CAT definitely looks like the cause.
    Removing the comb sounds like a good idea.
    I also like the idea of splitting a pipe to use as a heat shield.
    Will be doing both. will give feedback of results.
    Thanks Guys.
    2007 Defender Puma
    2002 GLE Corolla
  13. #12
    Quote Originally Posted by Landyluvver View Post
    1)
    Thanks Ladyluvver.
    Where can we find Dynamat? and what is the cost?
    2007 Defender Puma
    2002 GLE Corolla
  14. #13
    Nov 2006
    Lonehill
    Thanked: 197
    IIRC the exhaust is already stainless.
    Just remove or gut your cat. It will make a huge difference. It did on my Puma.
    BruceT
    ZS6EBT
  15. #14
    Sep 2008
    Big Bay / on a boat
    Thanked: 7
    same problem , thanks guys
  16. #15
    Bethlehem
    Thanked: 3638
    Default Re: 2007 Puma cooking floor
    VERY helpful stuff in here thanks.
    My voete was laas so warm toe ek in daai queue by die Dooie See gestaan en wag het om in te spring
    Of COURSE I have a Bad Habit. I take Tea at Three (Mick Jagger)
  17. #16
    Robertson
    Thanked: 14
    I removed my cat for the same reason, much better now, still gets warm on really hot days but nothing like it used to.
    2010 Defender Puma (Toolbox)
    2004 RAV4
    2017 BMW F700GS
    2013 Suzuki DR650 (back to basics)
  18. The Following User Says Thank You to Max Lange For This Useful Post:
  19. #17
    Bellville
    Thanked: 102
    I also temoved the CAT on my Puma. Huge difference with the heat inside the cabin.
  20. #18
    Thanked: 695
    Also, don't drive with any windows open, as this draws the hot air from underneath the vehicle into the cabin.
  21. The Following User Says Thank You to Orxy For This Useful Post:
  22. #19
    Springs
    Thanked: 277
    very successful mod is to modify the bonnet to incorporate an air scoop. the bonnet being steel is easy to convert
    you can buy some very nice air intakes off other popular Oriental pickups that will fit easily.
    just to test the effect remove your bonnet and drive a fair distance without and see what difference it makes.
    try it. contrary top popular belief, creating a draught down the back of the engine actually improved air flow through the radiator as well
  1. Defender 90 Puma 2007 diesel model. Should I?
    By geraas in forum Land Rover
    Last Post: 2011/05/16, 09:40 AM
  2. Concrete floor question.
    By RudolfD2 in forum The 4x4 Pub
    Last Post: 2011/01/11, 05:50 PM
  3. HID kit into a 2007 Defender Puma
    By ralton in forum Land Rover
    Last Post: 2010/04/30, 07:18 AM
  4. fitting a fridge transit slide lock
    By biltongvreter in forum Camping, Fridges, Accessories
    Last Post: 2009/08/04, 10:10 AM
