Fuel gauge reading empty
Results 1 to 7 of 7
Hybrid View
    Dec 2011
    cape town
    Question Fuel gauge reading empty
    Hi guys.
    I need some advice on how to fault find a fuel gauge that reads empty with the reserve light on.
    I have a defender td5 2000 110.
    I had no problems before and this just happened after a quick run to the shops.
    Many thanks in advance.
    Steff
    Land rover defender110 2000 td5 - sorted!
    Nissan champ 1992 1400
    ex 1999 Land rover defender 110 2.8i
    ex 1989 land rover defender 110 Nissan RD2.8
    Greyton westerncape
    Thanked: 36
    Whats the light ?
    Dec 2011
    cape town
    Dash board light for low fuel
    Die Groot Brug
    Happend to me when I still had my Freelander and had to take it to land rover to get it fixed.
    I think the float inside the tank is not work as it should.
    Orra Call Sign: X12
    Jul 2010
    Pinetown
    Thanked: 1182
    Most likely the sensor in the tank - just had the same problem on the old Suuz
    Platkar = Chevy Spark 1.2
    Jan 2010
    Petoorstown
    Thanked: 46
    Just fill it again and see, maybe just got stuck - happened to me on my Isuzu once. Dont know how but it did. After the fill up all was well again.
    2018 VW Amarok V6 TDi
    2015 VW Touareg V8 TDi Still learning..
    Dec 2011
    cape town
    Hi Guys
    Thanks for the advice.
    I fitted a new pump assembly complete. I tested the old fuel sender and it had an open circuit.
    So I started by cutting hatch to get access to the pump. After testing the old one, a complete unit was fitted. Some advice:
    Removal. Clean around the fitting before using a screw driver to knock the ring anticlockwise.
    Remove the fuel pump and be careful as it is spring loaded and take care when removing, as you don't want to hurt the float etc.
    Refitting. I tried to fit the seal to the pump first but it didnt want to work that way. So fitted the seal to the tank first, then dropped in the pump, (making sure to seat the pump in correct position) and fit the top ring collar. Clockwise with screw driver. ( keeping pressure on the top of the pump to prevent it from popping up and out of position.
    Here are some measurements for the hole. I only cut away half of both supports. The hole I cut is a tight fit. From the rear- from carpet holder to bottom cut is 3950mm and from the left looking to the front of landy is 3150mm. Then its pretty much a square from there, (measurements are for the bottom left corner. I made it 150mm high and 145mm wide.
    After testing to make sure all is ok and on leaks are found, once I filled her to the max, I will fit a flat piece of Ali with pop rivets to make a lid. Need a flat seal so it doesn't interfere with the sliding draw system.
    So after I did some tests I found it was leaking. removed the some diesel, as I have a long range tank. (releasing pressure on the seal) Then I tightened the Ring collar even more. Filled tank and drove to test. All Good. Then I sealed the hole with a plate with self tapper screws, ( to I don't have to drill out pop rivets) and put some gasket maker around the edges to stop water and dust getting in.
    Here is a picture of the hole.
    Problem was solved and the old pump and assembly was cleaned and packed away for travel spares. Price on the pump. OOCH! thats all i can say.
    Regards steff
ID:	382062   Click image for larger version.
  1. Gwm 2800tdi sailor
    By GOBAT-ZN in forum GWM / Haval
    Last Post: 2016/02/21, 08:50 AM
  2. Diesel fuel questions
    By XJ Junkie in forum General 4x4 Discussion
    Last Post: 2015/07/31, 03:44 PM
  3. carrying fuel in vehicles
    By OFFROAD ADDICT in forum General 4x4 Discussion
    Last Post: 2012/09/21, 09:34 PM
  4. Ford & Mazda Fuel Gauge Accuracy
    By Mulligan in forum Ford & Mazda
    Last Post: 2012/07/06, 04:37 PM
  5. Isuzu fuel gauge setting
    By dudley in forum Isuzu
    Last Post: 2010/10/28, 08:34 AM
