Results 1 to 7 of 7
    Exclamation Alternator wire burnt off - please help
    Hello everyone,
    I have seen that this topic has been raised in previous threads, however i do not wish to jack someone else's thread so i have started a new thread. A few days ago my batteries stopped charging in my Toyota Fortuner. After a brief investigation i discovered that the wire connecting to my alternator has melted off. I cleaned the melted connection and re-crimped the wire onto the connector and rebolted it to the alternator. 2 days later it burnt off again.
    Can anyone please guide me to someone or somewhere that can help me fix this? I am not highly knowledgeable around engines and i'm scared of going to any random auto elec due to all the horror stories i've heard over the years.
    my setup it as follows:
    2007 Toyota Fortuner 4l v6
    National luna dual battery setup
    Main battery: 668
    Aux battery: 105ah DC
    i am currently driving on the aux battery power which by the looks of things won't last see the end of the day.
    if any can help, please pm me (or phone - my number is below). I am based in the East Rand area (GP) but will travel as far as PTA to get this sorted urgently (huge thank you in advance to anyone that can help).
    Mike.
    24/7: zero 82 9zero6 zero 216
    p.s I have emailed Uys from stofpad to ask ask for advice as well as I noticed that his comments on this topic in other threads seems highly knowledgable.
    Current: Tuna 4L V6 4x4 (reg virrie bos )
    Current: Astra Coupe Turbo (CCD tuned )
    no help or advice or recommendations ?
    :_(
    Pretoria North, Patryshoek
    Thanked: 3279
    You must not drive without a load on that alternator.
    But to replace that lug, should not be a major task.
    There are quite a couple of electric buffs here. So just sit tight. They will find you.
    +27 zero eight 2 four 95 9252
    Thanked: 5830
    Sorry, Uys has no advice on this one. Never heard off it. But to burn that wire off in 2 days there must be a serious fault! I'll take it to a Auto Electrician or Toyota themselves.
    Uys
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    083 399 2046
    Thanked: 3279
    ...........But to burn that wire off in 2 days there must be a serious fault!.........
    Not really. A bad connection will do that. Bad connection could just be that it was not tightened down properly. Or the crimping on the lug was not proper.
    Either way, it HAS to be attended to.
    Rangeview Krugersdorp
    Thanked: 2771
    Put meter on lug nut and wiggle it whilst revving. Might be loose inside alt body. Also check charge rate.
    Ford Figo 2016
    Harties
    Thanked: 1657
    Revert to the standard vehicle arrangement by disconnecting the Aux battery system.
    After that, if the problem goes away, sort out the Aux battery system.
    If the problem persists, find a good auto electrician.
  1. Burnt Valves - Ford Fiesta
    By astoltz in forum Vehicle & Technical Chat - General
    Last Post: 2014/09/05, 09:27 PM
  2. Burnt points
    By Wicd in forum The 4x4 Pub
    Last Post: 2013/11/27, 08:35 AM
  3. Burnt out relays?
    By Herminator in forum General 4x4 Discussion
    Last Post: 2013/02/03, 11:39 AM
  4. Jk burnt out
    By NEON DEON in forum Jeep
    Last Post: 2011/07/11, 11:18 AM
  5. Replies: 4
    Last Post: 2010/01/03, 10:14 PM
