Renault Duster Problems - Page 3
Page 3 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 41 to 60 of 272
  1. #41
    Jun 2015
    JHB/ Roodepoort
    Thanked: 111
    Default Re: Renault Duster Problems
    Quote Originally Posted by Butch Dassie View Post
    Unless you've installed a black box to recalibrate for you, you need to apply a correction to your mileage at fill-up. Multiply the km by 1.0311 (2221/2154), then recalc your km/L. You might want to drop your speed 3% in a speed trap as well.
    Thank you very much, really appreciate it. I'll try that
    2015 Renault Duster 4WD
    1999 Jeep Cherokee Country XJ face lift
    Action Group member AG0029
  2. #42
    Sep 2015
    Thanked: 110
    OK – I finally got the details from my snap filling station mate
    Problem: Primary: smell of exhaust in the cabin
    Secondary: starting difficulty, rough idle, reduced engine performance was erratic (had a flat spot), reduced fuel economy
    At what KM did it happen: 19464
    What did you do: He took it to Tokai Renault (aka Tokai Multifranchise)
    Response from Renault: verbal quote starting at R1400 with no date of return
    Was it fixed with a smile or did you have issues? Issues - voided warranty as he placed some Holt’s fire gum on the exhaust manifold to EGR flex pipe joint where he noticed soot (It was the weekend, Tokai Renault wasn’t open and he had to be in the Cedarberg on Monday. The fire gum did not stop the smell.)
    What was the result: He took his vehicle to someone he felt more comfortable with. They found that the EGR solenoid valve was frozen solid. They surmised that this caused pressure on these “funny” French clamps that didn’t hold the pressure. Tokai Renault said that a new flex pipe, Renault Kit # 8201057571R, with the two clamps must be ordered at R1200. After 12 days, Tokai Renault contacted his shop and said that it was now on backorder with no expected date of delivery. My mate then ordered the two clamps (Renault clamp alone, possibly: 8200102150, 4619037 or 30010586) online and they were delivered from Poland in three days.
    According to the installer, the clamps need to be seated correctly off the vehicle and the whole thing (exhaust manifold and EGR housing) needs to be installed together. The flex pipe is only necessary to allow for the different expansion rates of the exhaust manifold’s and EGR housing’s metals (then, why does it leak?).
    He is actually glad his warranty is voided because no one now can think they can tell him he can’t have this size tyre or install that running board, etc.
    Oh! He also says that he has put off at least one potential Renault client due to Renault SA’s lack of spares in South Africa.
    Renault Duster 4WD Gen1: No Meow
  3. #43
    Jul 2010
    Plattekloof
    Problem: Right front side shaft seal leaking
    At what KM did it happen: From around 25000
    What did you do: Reported it to dealer before service.
    Response from Renault: Assisted without issues but waited for stock
    Was it fixed with a smile or did you have issues?: With a smile
    What was the result: Seal fitted as soon as stock arrived +-2 weeks
    Problem: Brake fluid leaking from reservoir when parked downhill
    At what KM did it happen: From around 5000
    Response from Renault: Inspected and found no problem
    Was it fixed with a smile or did you have issues?: Not fixed
    What was the result: Upon my own inspection it was found the breather hole in the reservoir cap will leak if not properly torqued.
    Ironically if the cap is torqued tightly the breather hole moves from the intended 12h position to 3h for example.
    Fix is to cut a thin gasket of same OD and ID, place behind OEM gasket to get the correct position of breather hole when torqued.
    Took me two beers to figure out.
    Problem: Gear lever reverse actuator broken, the little spring that returns lever to forward gears is missing
    At what KM did it happen: From around 35000
    Response from Renault: Will fix at next service
    Was it fixed with a smile or did you have issues?: Maybe
    What was the result: Not yet
    2016 Duster 4x4 + 2007 X5 3.0d
  4. The Following 2 Users Say Thank You to HiluxV8 For This Useful Post:
  5. #44
    Sep 2015
    Thanked: 110
    I've heard of the power steering sweating on the cap, but not a problem with the brake reservoir leaking. Thanks for sharing the fix.
  6. #45
    Mar 2014
    Boksburg
    Good day
    I need to replace my rear shocks. Dealer quoted me R3000 and something. Now I would like to know what my other options are?
  7. #46
    Mar 2014
    Boksburg
    I have a 2014 4WD model
  8. #47
    Sep 2015
    Thanked: 110
    Default Renault Duster Shocks
    Original shocks usually don't last more than 50k kms and cost more than Monroe.
  9. #48
    Mar 2014
    Boksburg
    Thank you ordered some Monroe shocks today. I am also going to replace the front shocks.
  10. #49
    Sep 2015
    Thanked: 110
    Default Monroe
    Pleasure - part numbers please. This one is on my list as well.
  11. #50
    Mar 2014
    Boksburg
    Wil give it tomorrow.
  12. #51
    Mar 2012
    Thanked: 9
    I still have one service left for duster, dealer told me if i put the monroe shocks my warranty will expire. i told them i have 30 000km on and the shocks are finish, now they force me to buy the crappy shocks again.
    PLAN = put the monroe on keep originals and before service will put them back on the car then just swop them after service, do the balance and alignment again
  13. #52
    Mar 2014
    Boksburg
    Thanks for the tip
  14. #53
    Sep 2017
    Problem - Did my wheel alignment and was told spacers at the back was also required
    At what KM did it happen - 15600
    What did you do - Took it to TWT in Centurion
    Response from Renault - Should have touched base with then but did not
    Was it fixed with a smile or did you have issues? - R1800 I was not smiling
    What was the result - Two days later I was in a car accident so hopefully while at the panel beaters they wil check and confirm that it is still fine
    Does anyone know where I can possibly get hold of a sump guard, bash plate for my 2016 1.5dci 4x2
  15. #54
    Mar 2014
    Boksburg
    Front shocks part number: G7372 Price: R1650
    Rear shocks part number : G7386 Price : R1880
  16. The Following 2 Users Say Thank You to GHOER For This Useful Post:
  17. #55
    Mar 2014
    Boksburg
    This was at supa quick
  18. #56
    Jun 2015
    JHB/ Roodepoort
    Thanked: 111
    Thanks GHOER. I now have 114447km on and still haven't replaced my shocks. Kan rrally feel that it's finished and neefs replacing. Other than that I've only had a faulty door lock and a glo-plug light that came on and the Dusty lost power, so far. No other complaints or issues.
    I'm happy so far!
    Avarage combined fuel consumption is 14.4km/L
    Changed the standard 215/65/16 tyres for 215/70/16
  19. #57
    Sep 2015
    Thanked: 110
    Default Tyre Correction Factor
    Quote Originally Posted by Duster Jack View Post
    ...Avarage combined fuel consumption is 14.4km/L
    Is that 14.4kml after you have applied the correction factor for the tyre size difference?
  20. #58
    Jun 2015
    JHB/ Roodepoort
    Thanked: 111
    Default Re: Tyre Correction Factor
    Nope as is. Maybe you can help?
  21. #59
    Jun 2008
    JHB
    Question Re: Renault Duster Problems
    I'm happy so far!
    Duster Jack- what was the solution to the glow plug light, the loss of power was probably "limp mode"
  22. #60
    Jul 2013
    centurion
    Thanked: 13
    Quote Originally Posted by AntZ View Post
    I had the same error this week. Then switched off the car and all gone
  1. Renault Duster
    By dieOrg in forum Softroaders
    Last Post: 2020/03/26, 06:54 PM
  2. Advice on Maintenance Plan - Renault Duster
    By dt.2507 in forum Vehicle & Technical Chat - General
    Last Post: 2018/06/28, 10:42 AM
  3. Renault Duster Sub section
    By Sergey in forum General 4x4 Discussion
    Last Post: 2015/06/26, 10:15 AM
  4. 2015 Renault Duster
    By rssfeed in forum For Sale, Swop & Give-Away
    Last Post: 2015/02/18, 10:30 AM
  5. Renault problems! Arggg! Mad! Help!!!
    By Die Skim in forum General 4x4 Discussion
    Last Post: 2012/03/03, 10:02 PM
