Results 1 to 5 of 5
    Default Need help with broken fuel gauge willys cj6
    Hi We are busy repairing our CJ6 jeep and while taking out the speedo we managed to destroy the fuel gauge. There was a rusted old nut on one of the 3 back terminals and while trying to loosen it, the wires and mechanism inside the gauge broke.
    Can anyone give a suggestion on how/where to fix it or where we can buy another one?
    There is also a small hole in one of the fuel tanks. What would be the best way to fix this?
    I am from the western cape. (Cape Town, Gansbaai)
    Thanked: 17989
    Midas will have a selection of analogue fuel gauges. Smith gauges would be the best, I reckon.
    Take the fuel tank to Silverton Radiators, don't try weld a fuel tank yourself unless you like dying.
    Jakes Louw
    Thanks for the advice jelo.
    [Take the fuel tank to Silverton Radiators, don't try weld a fuel tank yourself unless you like dying.[/QUOTE]
    At least I can say that I thought about that one
    We have taken out the gearbox as the reverse was jumping out and are getting a new gear machined. Attached is a pic of the broken gear.
    Also a pic of the Jeep. Still running but in need of some TLC. I think its a CJ6 but have to check VIN number.
ID:	380019   Click image for larger version.
    Apr 2015
    Thanked: 61
    Not all sender units work on the same resistance range. Unless you buy a gauge/ sender unit set, it is better to buy the original gauge. I have twice imported a gauge only to find that I had the wrong sender unit for the gauge. Very expensive school fees.
    Jun 2012
    Pretoria East
    Thanked: 291
    Phone Mickey Harris from Jeep Spares for both the gear and the gauge -0125677516.
    The reverse gear often does not go so he may have a new/used good one which is preferable to welding.
    Replace the synchros and all needle bearings while you are in there to avoid having to do so in future.
  1. Gwm 2800tdi sailor
    By GOBAT-ZN in forum GWM / Haval
    Last Post: 2016/02/21, 08:50 AM
  2. Colt 2.8tdi cold start issues?
    By Hanman1 in forum Mitsubishi
    Last Post: 2014/04/01, 10:16 PM
  3. Replies: 0
    Last Post: 2011/06/27, 09:26 PM
  4. Isuzu fuel gauge setting
    By dudley in forum Isuzu
    Last Post: 2010/10/28, 08:34 AM
  5. Ford/Mazda fuel gauge inacurate.
    By Vastrap in forum General 4x4 Discussion
    Last Post: 2007/12/09, 11:15 AM
