OpenStreetMap Topo - BaseCamp, Garmin and Android
Results 1 to 20 of 32
    Gaborone, Botswana
    Thanked: 843
    Default OpenStreetMap Topo - BaseCamp, Garmin and Android
    Here is how I installed OpenStreetMap Topo Southern Africa on my Garmin GPS, Android Tablet and BaseCamp for Windows. It is free
    Download from : http://www.gmaptool.eu/en/content/af...-topo-routable.
    Bottom of the page....
    You will need something like 7zip to extract the .7z files
    To be continued .....
    Kobus
    HDJ81 VX
  2. The Following User Says Thank You to KobusDJ For This Useful Post:
    Gaborone, Botswana
    Thanked: 843
    NOTE: You need to have Garmin BaseCamp installed + your Garmin GPS connected.
    You should now see the following extraxted files....
    Execute the install batch file.
    The OpenStreetMap Topo map should now be available in BaseCamp.
    With you Garmin GPS connected, select "Install Maps" (see image above). Follow the instructions until it is done with the installation/ transfer.
ID:	379394   Click image for larger version.
    Kobus
    HDJ81 VX
    Gaborone, Botswana
    Thanked: 843
    Browse the [GPS]\Garmin folder. You should see the new map.
    You are now done with the GPS. The new map should be available from your map setup.
    Make a copy of that .img file and paste it somewhere (Desktop). Disconnect GPS.
    Kobus
    HDJ81 VX
    Witbank
    Nice, Kobus, thanks.
    Is it worth doing? I'm running a Montana with Garmins topo maps (and T4A).
    Hein
    Gandalf: '77 Series III 109" SW (He's old, he's grey, he smokes, but on an adventure you want him as companion...)
    HF, VHF, UHF
    Detroit Locker rear, Truetrac LSD front
    Hardened valve seat ULP conversion
    British cut cam shaft
    VW carb conversion, electric fuel pump
    G-Tech Electronic Ignition
    Hankook M/T 235/85/16
    Frodo: '12 Jimny (SWAMBO)
    Stofpad spacer lift and underbody protection
    Platkar (work): '15 Ranger 3.2 AT 4x4 with AluCab
    Gaborone, Botswana
    Thanked: 843
    @ZS6HDV - If you already have the Garmin Topo maps, it is not worth it. The mountains and rivers will not move soon.
    Kobus
    HDJ81 VX
    Gaborone, Botswana
    Thanked: 843
    Now for you Android device . Obviously it need to have built in GPS.
    Download and install OruxMaps from Google Play
    To be continued ..... (ek gaan nou eet )
    Kobus
    HDJ81 VX
    Gaborone, Botswana
    Thanked: 843
    Once you have OruxMaps installed, plug in the USB to PC cable connection.
    From Explorer (on PC) browse the Android for ...\oruxmaps\mapfiles. Copy that .img file (from Desktop) and paste into the 'mapfiles' folder. Disconnect when done.
    Open the OruxMaps App. Select the flaggy thingy and then "Switch Map"
    Change from "online" to "offline".
    Select the "Africa South OSM Topo".
    Done!
    You now have OpenStreetMap Topo maps on your Android.
    Fin
ID:	379413   Click image for larger version.
ID:	379414   Click image for larger version.
    Kobus
    HDJ81 VX
    Apr 2011
    Thanked: 16
    Subscribed!!
    Guillaume
    Fortuner Epic 4.0 V6 AT
    Friemersheim, Southern Cape
    Thanked: 2021
    Dankie Kobus
    Werk soos 'n droom....nou ook op my tab
    Gaborone, Botswana
    Thanked: 843
    @ Prof... Thanks.
    If you really push it you can get your old garmin .gpx tracks into OruxMaps . If needed I can assist.
    Kobus
    HDJ81 VX
    Thanked: 845
    Default Re: OpenStreetMap Topo - BaseCamp, Garmin and Android
    This seems great!
    What do you do if you don't have the garmin for those first steps?
    Gaborone, Botswana
    Thanked: 843
    Quote Originally Posted by Rustie View Post
    This seems great!
    You only want the .img file to install on OruxMaps ?
    Create a folder on a USB flash drive and name it : Garmin . Open Basecamp and make the OSM Map the active map. Then "Install Maps". BaseCamp will send it to the Garmin folder on the USB Flash drive.
    Kobus
    HDJ81 VX
  14. The Following 2 Users Say Thank You to KobusDJ For This Useful Post:
  15. #13
    Oct 2008
    East Rand
    Thanked: 38
    very informative. Thanks for the share...
    To Operate Your Own Terrific Automobile AKA TOYOTA
  16. #14
    Mar 2011
    Walker Bay
    Thanked: 861
    Kobus - Many thanks for posting this.
    I am surprised at the detail on these Open Street maps == street names - restaurants etc. Far superior to Google on the few instances I have looked at and compared.
    I installed on Base Camp on the PC and the tracks work fine in my 6 year old Garmin.
    I could not install Open Street maps to the card in the Garmin as Windows 10 says the tiny SD card is write protected?
    There is no switch on the side of these small cards. Any advice will be appreciated.
  17. #15
    Mar 2016
    cape town
    Thanked: 37
    Load JaVaWa GMTK and JaVaWa device an dyou can sort it all out. Move maps onto JaVaWa then insert a new Sd card into your GPS and load the maps back onto the new card.
    Then download any maps ie: OSM topo Africa routable and load onto Basecamp. Connect GPS and add the OSM or any other to the new card on the GPS.
    But keep a full backup of maps on JaVaWa
  18. #16
    Mar 2016
    cape town
    Thanked: 37
    Once done JaVaWa gives you the facility to move your saved maps from GPS card into the device hardware or visa versa. Plus onto any new SD card
  19. #17
    Mar 2011
    Walker Bay
    Thanked: 861
    Many thanks - will do.
    Just wondering why I have a locked card --Does Garmin Topo./ Street maps/T4A lock these cards?
    Quote Originally Posted by Dirtrob1 View Post
  20. #18
    Thanked: 423
    Hi,
    Unzippef and when I click on the .bat file it throws up as dos screen.
    Unknown mapset nothing installed.
    Must I have basecamp open?
  21. #19
    Mar 2011
    Walker Bay
    Thanked: 861
    If I recall mine was open.
    Hi,
  22. #20
    Thanked: 2021
    From post #2
  1. T4A Android & tablets
    By wschulte in forum Tracks4Africa ONLY
    Last Post: 2014/04/01, 10:26 AM
  2. Monterra - New Garmin Outdoor Handheld with Android OS
    By PieterOos in forum GPS & Mapping
    Last Post: 2013/06/25, 10:02 AM
