300 Tdi electric vacuum pump retrofit
Results 1 to 20 of 26
    Modjadjiskloof
    Thanked: 147
    Default 300 Tdi electric vacuum pump retrofit
    This thread will eventually become a record of my attempt to retrofit an electric vacuum pump to the Tdi.
    Modjadjiskloof
    Thanked: 147
    We all know of the reliability issues surrounding the 300 Tdi vacuum pump. After hearing another story from my indy about a brand new unit failing, and experiencing my own vacuum pump beginning to weep after just 3000 km, I'm getting sceptical about keeping this unit long-term.
    There is a fix available, which involves replacing the pop-rivets with bolts and adding a thicker Welch plug.
    However, if you study the info on the internet about the working principle of this pump, the reason for failure of both the above is actually to do with the poor design of the piston, which causes oil to get into places it shouldn't and then get forced out of the Welch plug because it's got nowhere else to go.
    So, fixing this will buy you some time, but it's treating the symptoms and the unit is probably going to fail, eventually, catastrophically.
    Modjadjiskloof
    Thanked: 147
    A few guys overseas have fitted electric vacuum pumps. It seems that some of the modern cars have them, so you could get one from a scrap yard if you know what to look for.
    The solution I like, however, is this one from Ebay:
    http://www.ebay.co.uk/itm/3312749959...958%26_rdc%3D1
    Apparently it has a variable pressure switch, so you can set the amount of vacuum to the original spec of the system. Important because you don't want to over-do things and destroy your booster.
    Modjadjiskloof
    Thanked: 147
    One of my thoughts is to make a nice thick metal blanking plate for the existing vacuum pump. Then, by means of rubber shock mounts, attach the electric pump to the blanking plate and connect it up. This way, the vacuum pump still sits in the original location.
    The problem is that the pump may require shielding from engine heat. I need to go and measure the temperatures in that part of the engine bay.
    Otherwise, mounting on the firewall somewhere, or on one of the inside fenders, is probably the solution.
    Another advantage of this pump is that it would make the Tdi a bit quieter, especially at idle.
    Thanked: 1893
    Your best bet would be to install a Bosch Alternator that fits without mods, which has a vacuum pump on the back. Then you also solved the alternator problem.
    The Marelli is a really good unit, but it is not possible to really recondition it.
    1999 Discovery 1, 300 Tdi - "Tink Tanky"
    2004 Discovery 2 Td5 - "Blink Tanky"
    "Logic is a systematic method of coming to the wrong conclusion with confidence."
    "A technician will let a system degenerate to the level of his understanding and maintain it there."
    "...it is abundantly clear that you are an arrogant C-nut." - Estee. (I was overwhelmed. It was the nicest thing someone has said to me in a week!)
    Thanked: 461
    Anthony
    listen to Biltong's advise. He has got tons of experience with the D1 300Tdi.
    The 2.8 Powerstroke motor used such an alternator.
    George Bosch
    Distributor for:
    Thanked: 15033
    The old school Nissan diesels also had the same alternator/pump combo unit so finding one with the right pulley and so on shouldn't be hard.
    Jakes Louw
    Thanked: 1893
    Have you got a part number?
    Would be something that deserves to be a sticky.
    I also tried to find that Bosch alternator once. Apparently it does exist but I did not had time hunting it down.
    Mar 2014
    Brakpan
    Thanked: 141
    And how to get the revcounter working again. Its running of the alternator. Can it work?
    Four wheels move the body,
    Landys move the soul.
    0614512283
    Current: Discovery 1 V8i
    Next landy, D3 V8 HSE Previous one.D1 300 TDi donkey, D1 V8 Fuel THIEF!!! freelander 1, biggest pos known to man,
    May 2010
    Greenstone
    Thanked: 390
    Quote Originally Posted by Sam vd Merwe View Post
    That's strange I thought it came from the gearbox and not the alternator.
    Discovery Sport 2.0i D
    Defender 90 LE Puma 2.2TDCI
    Defender 110 DC Td5 (life partners)
    Discovery 1 200 Tdi Auto
    Thanked: 461
    Quote Originally Posted by Byron View Post
    Hi Byron
    there are 3 connections on the back of the Magneti Marelli alternator. The rev counter feed is connected to the middle one.
    George Bosch
    Distributor for:
    Modjadjiskloof
    Thanked: 147
    Some interesting info posted here already. Thanks guys.
    I've heard about the alternator mod. It's also attractive to have a Bosch alternator instead of the Marelli.
    BUT, the vacuum pump now runs very close to the exhaust manifold, and also on the wrong side of the engine (brake booster on other side, so you would need some more piping). And of course the rev counter issue.
    And the new pump would still need an oil feed, so more piping needs to be added and rerouted. Opening another oil path gives one more chance for something critical to go wrong.
    Hence the interest in going the electric route...
    Thanked: 461
    Hi Anthony
    Back in 2010 I had designed a kit for the Vacuum pump, that takes care of the cover coming loose and the bottom welch plug popping out. It contains 6 x 5mm ss bolts with a special metal lock nut, impervious to oil.
    It is available from British 4x4. Just ask Allan.
    George Bosch
    Distributor for:
    Thanked: 1893
    Correct. It certainly is a bit of work.
    That said, I also looked at an electrical vacuum pump unit and could not find something that made me happy. Very pricey for something of quality.
    Hence, I installed a new Wabco back then and kept the old one.
    Make no mistake, this is one of those thorny Tdi issues. Regardless of the way you go, you either compromise, pay or work.
    Tough one.
    If it was me, I would plumb in the oil feed and return from the turbo.
    Thanked: 15033
    Quote Originally Posted by biltong View Post
    and make sure the Madman/LBB was watching the oil pressure..........
    Jakes Louw
    Springs
    Thanked: 281
    there are 2 makes of vacuum pumps available for the 300Tdi - Wabco and Unipump
    I have stopped using Wabco as a result of comebacks
    fit a new Wabco and 3 weeks later the customer is back
    he demands a warranty replacement while the suppliers refuse
    guess who takes the knock to keep the customer happy?
    not 1 Unipump return is the past 2 years
    Thanked: 461
    Hi Landyluvver
    I have made the same observation. The 300Tdi Wabco unit is absolute rubbish, the quality control is non-existent.
    The Unipump I fitted after going through 3 "new" Wabco units in 2010.
    The Unipump was still working perfect after 120'000km when I sold the D1 earlier this year.
    George Bosch
    Distributor for:
    Thanked: 1893
    Great to know. Is so, then I would have no reservations going this option next time.
    What is the difference in cost?
    Springs
    Thanked: 281
    the last time I bought, the Unipump was actually a couple of bucks cheaper
    I got them from LP4A but think Dover stocks them now as well
    Modjadjiskloof
    Thanked: 147
    Default Re: 300 Tdi electric vacuum pump retrofit
    Reviving my old thread as I begin thinking about how to do my electric vacuum pump mod.
    I've attached an Audi/VW document I found on the internet, explaining a bit of how their system works.
    From this, I think I'm going to do the following:
    - look in scrapyards (or at Goldwagen) for a vacuum pump and pressure sensor
    - get an inline vacuum reservoir somewhere
    - build a circuit to monitor the pressure and toggle the pump as necessary. This should include a warning light/buzzer if the requisite amount of vacuum cannot be maintained
    By charlatan in forum Jeep
  2. 300 tdi Vacuum pump
    By faniedup in forum Land Rover
    Last Post: 2012/08/22, 09:18 PM
  3. Grand Cherokee Error code
    By Nick47 in forum Jeep
  4. Defender 200Tdi vs 300 Tdi Defender
    By LENLANDY in forum Land Rover
    Last Post: 2009/06/24, 11:37 AM
  5. electric fuel pump V6
    By chevy38 in forum Ford & Mazda
    Last Post: 2009/05/26, 08:42 PM
