Yet another trailer build
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 48
    Default Yet another trailer build
    I have decided to build my own trailer, can not afford a new one and got a lot of material lying around.
    First time round, it will be a big learning curve.
    Will post pictures as I progress........
ID:	376873   Click image for larger version.
ID:	376874   Click image for larger version.
ID:	376875   Click image for larger version.
    1985 Celica Supra
    1996 Land Cruiser 80 series 4.5
    2007 Isuzu KB250 (WORKHORSE)
    2007 Yaris 1.3 T5 (SWAMBO)
    2008 3.0 D4D 4x4 Hilux
    Thanked: 2322
    That looks super strong and heavy. Are you using a braked axle?
    How are you going about the licensing?
    At the moment it has a Burquip 2.5T unbraked axle. Will replace it next year with a braked axle.
    It should not be to heavy, the chassis is 100 x 75 lipped channel, frame 32sq tubing x 1.6mm and other plate is 1.2mm.
    Licensing....just keep all the slips and take it from there I hope!!
    1985 Celica Supra
    Nylstroom
    Thanked: 15
    Nice job Supra! Looks strong and well designed. Are you going to add a nose box?
    Toyota
    Jul 2015
    Thanked: 23
    I agree, It looks good.
    It would probably be a good idea to "brake" it sooner rather than later...
    2007 Nav 2.5dci 4x4
    Polo peeetrol saver
    XT120
    KTM 300, CBR600, CBR1000
    Thank you and yes Platjan, busy with the design of the nose cone.
    Want to make it out of aluminium and maybe add some isolation to it for an extra cooler box.
    1985 Celica Supra
    Nylstroom
    Thanked: 15
    Good luck and keep the pictures coming!
    Toyota
    Jun 2012
    Klerksdorp
    Thanked: 64
    Looking good! Are you going to add a trailer top tent to it? If so, I would make a solid top, no lid as it becomes very heavy with the tent on top. Then add more door access from the sides/back to compensate. Also then look at the trailer height requirement of the tent you intend to use as they do differ between brands (1.3m-1.6m).
    2009 Toyota Fortuner 3.0 d-4d 4x2
    Custom off-road trailer with Echo TTT
    I am adding a tent, got some beefy shocks to help me lift the top. But I'm pretty sure the top will hardly ever get used, it is just for a backup.
    Total height at the moment is about 1.4m. I still have to design a carrier for the tent.
    1985 Celica Supra
    Jun 2012
    Klerksdorp
    Thanked: 64
    Quote Originally Posted by supra_mkii View Post
    Good idea, that will help with access during the internal build. I always need to put drawer frames etc together in side as the door openings will be too small.
    If I could, I would have made my carrier in such a way to be able to store a table or something in there. Now, mine is just dead space...
    Quote Originally Posted by konstanddp View Post
    That is a good idea, thank you!
    1985 Celica Supra
    Jun 2012
    Klerksdorp
    Thanked: 64
    Glad to help.
    I would also recommend you give yourself something inside, where you intend to run electrical cabling, to attach the cables with cable ties. I used these square plastic clips with the double sided tape that you put the cable ties through, regularly used in electrical panels. when the trailer gets hot in the sun they all fall off .
    Will add that to the list, thanx.
    1985 Celica Supra
    Kuilsrivier
    Thanked: 108
    Nice going there!!!
    Also did mine some time back, so good luck.
    My biggest issue was the door seals. I tried the flat rubber strips, but that did not work too well for dusty roads.
    I have now changed to round rubber, but I had to do loads extra to make it work.
    I made the tent mount directly onto the trailer roof.
    No1 complaint I hear is that wind is coming though between the tent floor and the trailer roof.
    This give me extra 200mm height inside the trailer.
    Do you have a tent yet?
    I hated where the trailer tent is not 100% simmetrical on the trailer, but only afterwards figured out the mud guard might be an issue when the tent is open.
    Had to have the tent cut inside to fix this afterwards.
    Also have a good look at tent openings and your trailer doors. Does not help you have doors but cannot open them because the tent is in the way.
    I put my fridge inside the trailer, so at night I can have a drink without opening the tent
    It is a process, so enjoy !!!
    Really nice
    Dec 2012
    Secunda
    Thanked: 82
    Supra geniet jou projek dit lyk sterk and will go on for years to come
    Thanked: 38
    Subscribed
    2012 Ford Ranger 2.2 Diesel DC 4x4 6spd MT
    Virginia
    Thanked: 856
    Keep us posted!
    Like what you're doing!!!
    Awesome build!
    Good luck with the licensing. i just had a morning from hell trying to fix the GVM of my trailer that ive just purchased.
    During my running around i found that NRCS will do a compliancy test on your build at a cost of R1800. Keep the pictures coming!
    A litte bit of an update. Will probably fit the nose cone tomorrow. And asseble the doors.
    I only have a couple of days to finish her!
    1985 Celica Supra
  1. Code EB License
    By DETOUR-GP in forum Trailers, Caravans, Towing etc
    Last Post: 2017/02/01, 09:47 AM
  2. Suspension question on trailer build.
    By MarcoP in forum Trailers, Caravans, Towing etc
    Last Post: 2015/11/23, 06:09 AM
  3. Reversing with a trailer behind your 4x4?
    Last Post: 2013/02/04, 12:51 PM
  4. Is it Legal to Tow a Trailer Behind a Caravan?
    By Doepie in forum The 4x4 Pub
    Last Post: 2012/02/05, 07:17 AM
  5. Jurgens Camp Lite Trailer
    By Gumbie in forum Camping, Fridges, Accessories
    Last Post: 2011/03/22, 04:43 PM
