Fox suspension vs Old man emu
Results 1 to 20 of 28
    Jul 2013
    Postmasburg
    Thanked: 12
    Default Fox suspension vs Old man emu
    Het een van julle enige ondervinding hoe die Fox suspension vergelyk met die Old Man Emu's in n Toyota Hilux?
    2003 Jeep Grand Cherokee 4.7l V8 (HO) Overland
    Old Man Emu lift kit (80mm)
    Bulli Prop
    Jun 2008
    Thanked: 221
    I'd take fox over OME every day.
    Ironman Suspension
    40mm Body lift
    31x10.5x15 Cooper STTs
    Swakop
    Thanked: 474
    you not gonna beat fox
    "Meerkat"
    Namboyz
    modded 02' 105 series 4.5efi (big wheeled petrol thief)
    Kathu
    Thanked: 2365
    I have a Fox suspension in my project Ranger. Will take Fox every time.
    The Ausies will tell you OME is the best. In tests done in the States OME does not make the top ten. King and Fox rules
    Talk to DVR he imports FOX
    West Beach - Bloubergstrand
    Thanked: 121
    I have Fox in my Jeep.
    I dont have experience with OME, but EXTREMELY happy with my Fox shocks!
    2008 - Jeep Wrangler Rubicon JKU
    Thanked: 165
    If you see some of those monster jeeps out there they use fox. As well price them, fox is not cheap and they make grate stuff. If I had the ching fox will do all day long.
    2010 Toyota Fortuner 2 4x4.
    2001 Isuzu KB320 Frontier 4x4.
    2012 Polo GT White with community sticker.
    Thanked: 568
    OME can't compete with FOX. Compare the specs. But if you're lifting a Hilux then you're better off with OME. Although there are better options.
    Thanked: 165
    +1
    But for what it's worth the fox look so good 😁 and it's not as common as the rest.
    Thanked: 568
    Quote Originally Posted by Garreth G View Post
    +1 But for what it's worth the fox look so good dde01 and it's not as common as the rest.
    I've had both shocks but it's the lift that needs to be brought into the equation. Fox don't do lifts but OME do.
    If you want to lift a Hilux then google for an article describing the development of the RAW 4x4 system for a Hilux. It's also not as common but it's a better shock than OME.
    Kathu
    Thanked: 2365
    +1
    +1 and then I associate OME with famous brand 4x4`s
    Jul 2013
    Postmasburg
    Thanked: 12
    The front fox shocks on the hilux come with the coil springs. It lifts the front of the hilux with 50mm according to the supplier.
    I think you can adjust the height aswell, because it has rings that you can adjust.
    Bulli Prop
    Thanked: 568
    Quote Originally Posted by Stefan9006 View Post
    The front fox shocks on the hilux come with the coil springs. It lifts the front of the hilux with 50mm according to the supplier. I think you can adjust the height aswell, because it has rings that you can adjust.
    So the back will be lower than the front?
    Jul 2013
    Postmasburg
    Thanked: 12
    Hilux is always running nose down so will be level.
    Bulli Prop
    Jan 2009
    Ome's entry to the Bypass shock world. The BP-51, 51mm diameter bore. Available for the Hilux soon. Adjustable front for height and load, also adjustable for compression and rebound.
    Kathu
    Thanked: 2365
    Quote Originally Posted by Redlux View Post
    Good looking shocks. Bypass shocks are for serious off road racing.
    Other than good looks you will never be able to use the full ability on a standard vehicle.
    Jan 2009
    They made for on road and off road. Also made to work with the std lift that Ome will give that falls within the vehicle standaards.
    They got available for the L/C70 P/up, L/C200. Next the Hilux and Prado 150. Then they move on the the Ford etc.
    Jul 2013
    Postmasburg
    Thanked: 12
    Default Re: Fox suspension vs Old man emu
    Is daar iemand wat goeie ervarings het met fox op hulle hilux'e?
    Bulli Prop
    JHB
    Ongelukkig net op my bergfiets
    Wat kos vier van daai Fox shocks vir n Hilux ?
    Nov 2012
    Newcastle
    Thanked: 27
    Wat doen hierdie afterma4ket shocks? Ry hulle sagter want my hilux is maar hard
    2001 ISUZU KB 280 DT 4X4 LX (WIT WILLEM) - sold
    1990 WV JETTA-sold
    2004 MERC C180 will never sell
    2011 Amatrok BiTdi
    Jun 2012
    At the office
    Thanked: 76
    I priced 4 x entry level adjustable Fox shocks a few weeks ago and the quote from the distributor was +R20k !!! That was just shocks. I will be going for the adjustable foam cell Tough Dogs at half the price instead.
  1. Hilux Old Man Emu problems
    By Schalk Raath in forum Toyota
    Last Post: 2015/11/09, 09:48 AM
  2. Old Man EMU (Which one?)
    By Cabmaster in forum Toyota
    Last Post: 2015/05/16, 02:57 PM
  3. Replies: 1
    Last Post: 2012/08/20, 08:33 AM
  4. Old man emu 4 door Rubicon
    By pieter_fourie in forum Jeep
    Last Post: 2009/03/26, 06:19 PM
  5. Old man emu suspension
    By cmcs in forum Mitsubishi
    Last Post: 2007/02/17, 11:37 PM
