Results 1 to 17 of 17
    May 2013
    Default Rivnuts Problems on Trailer
    I am busy with some modifications on my trailer and looking for a company / engineering works in Gauteng area that can fit normal size Rivnuts for me into aluminium square tubing.
    Will be grateful for any info.
    Thanked: 524
    You can buy the tool... Last time I checked, Makro had the cheapest DIY tool at around R400.
    The industrial tools are very expensive...
    2017 Mitsubishi Triton 2.4 D/C 4X4 Auto Diesel
    Lynx Bashplate
    DIY Drawer system
    DIY Drop Fridge Slide
    My ULTIMATE dual battery box
    Thanked: 3285
    What size do you rate as normal, I've used 4,5and 6mm for general purpose fixing. Toset the rivnuts is easy you just need the setter tool that you can buy from makro or adendorfs. Up to 6mm the hand tool works well but from 8mm up you need some more persuasion.
    Have a look at this thread: http://www.4x4community.co.za/forum/...d.php?t=146539
    Henk
    Follow us on Facebook
    Thanked: 1167
    I have had too many rivnuts turning. So now I use wurth ratchet rivnut set. They are on special for 2995.
    http://www.wurth.co.za/?page_id=920
    Training: 4x4, bush mechanics, recovery, defensive, 4x4 trucks
    Angel Construction
    COMBAT19: Large scale fogging and decontamination
    [email protected]
    +27824453301
    Thanked: 524
    Quote Originally Posted by Marlin Magic View Post
    Or... You can ask somebody with a nice R2995 WURTH set to help you out ??
    I'm sure he'll take beer ??
    Lynx Bashplate
    DIY Drawer system
    Nigel
    Thanked: 2761
    I hate a rivnut. I even bought that big thing that can pull the 8mm rivnuts. But as Herman says, they turn.
    Eventually I just use a flat piece of steel on the back, with nuts welded on.
    Uniglide
    +27 zero eight 2 four 95 9252
    May 2013
    Guys I did buy the cheap tool from Makro maar hy werk nie. Those Rivuts turns like a All Black scrum before half time that's why I want to take it to someone with the correct tools. It is only 5mm Rivnuts I need to set.
    Henk do you have a tool the trailer is coming to you afterwards for the canvas kitchen still need to make a appointment with Jenny ?
    Thanked: 524
    The size of drill bit is VERY important !!
    Lynx Bashplate
    DIY Drawer system
    v-town
    Thanked: 34
    Quote Originally Posted by SinWolf View Post
    +1
    And a good quality Tool.
    I use a "Karat" 3-6mm never had a nut turn.
    Garsfontein
    Thanked: 3654
    Just try a washer and a couple of nuts. Works a dream...
    Ian de Villiers
    Nissan Patrol GRX 4.5
    May 2015
    Krugersdorp
    Thanked: 12
    We have used this a lot on all kinds of aplications. On sheetmetal we added some epoxy glue to the collar part of the nut. On thicker material, use a high grade lockset. This was for rivnuts where the bolts are being removed often for inspection panels etc. They never came loose.
    4 Ways
    Thanked: 41
    Rivnuts should not be smooth they should have splines on them to prevent turning, and should be seated firmly in place
    Who Dares Wins
    Logic will take you from A to B
    Imagination will take you everywhere
    Thanked: 1167
    jip, epoxy glues werk baie goed.
    Angel Construction
    [email protected]
    +27824453301
    Thanked: 3285
    I can set 6mm for you no problem, drill a 9mm hole and pull it until it squeaks
    Henk
    4 Ways
    Thanked: 41
    Default Rivnut
    Rivnut splines
    Who Dares Wins
    4 Ways
    Thanked: 41
    Rivnuts do not work well on Aluminium, the material is to soft, any stress will cause it to stretch and work loose.
    Who Dares Wins
    Nigel
    Thanked: 2761
    Go and buy a pneumatic pop riveter from Adendorfs and make a couple of tools that will work in that head. Then you pull them with the pop riveter
    Uniglide
  1. Modify old Venter trailer to use as a camping trailer
    By thejester in forum Trailers, Caravans, Towing etc
    Last Post: 2020/09/09, 11:50 AM
  2. Make your trailer invisible
    By staalwol in forum The 4x4 Pub
    Last Post: 2015/09/01, 01:54 PM
  3. Hand winch setup to get trailer in and out its parking spot.
    By bigboy529 in forum Trailers, Caravans, Towing etc
    Last Post: 2015/03/23, 08:16 AM
  4. Reversing with a trailer behind your 4x4?
    Last Post: 2013/02/04, 12:51 PM
  5. Nuwe Boswa
    By Bogaards in forum Camping, Fridges, Accessories
    Last Post: 2011/06/06, 11:26 AM
