Are you sure you are not trying to load the maps to the Nuvi's internal memory, rather than to the SD card? Are you using Mapsource? Connect the Nuvi to your pc with the USB cable, and browse the SD card with explorer to see what is on it. The SD card will show up as a removable drive (incidentally, so will the Nuvi's internal drive). The SD card drive will usually be called something like "Garmap" or "SASM", the Nuvi's internal drive will be called "Garmin".
